Hi all,
I’ve beenn going around in circles here and not sure where else to go.
Currently I have HA on Proxmox on my main network and all my IoT devices on another network. Up till now I’ve been using MQTT which is working fine but now I’ve added an ESP8266 node to WIFI (not MQTT), I just can’t add the integration.
A static IP was created in my router and now in the yaml code
Code can be uploaded OTA
In espHome config - ping status has been turned on
But it still shows the node as being offline and I can’t add the integration, as I get the following;
Now, when I first tried to add, it said to add the key - so I closed the box, went to espHome and copied the key but now whenever I search for the node IP in the integrations, all I get is this error.
esphome:
friendly_name: TheosButton
platform: ESP8266
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "********"
ota:
password: "***************"
wifi:
ssid: !secret wifi_ssid
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.10.63
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.10.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
ap:
ssid: "Theosbutton Fallback Hotspot"
password: "**********"
captive_portal:
#binary_sensor:
# - platform: gpio
# pin:
# number: GPIO12
# mode: INPUT_PULLUP
# inverted: True
# name: "Theo's Button"
# on_press:
# - switch.toggle: theos_light
switch:
- platform: gpio
pin:
number: GPIO12
icon: "mdi:gate"
on_turn_on:
- delay: 500ms
- switch.turn_off: light
