ESPHome Causing Connection Loss
Hi all
I am trying to flash my first ESP32 device, but whenever I get to the “compile” stage, my browser loses connection to HA.
This happens regardless of the method I choose (from browser, manual etc.)
I am running HA on a Raspberry Pi 3
Access is local and via Chrome
The Rasp Pi needs a power cycle to recover from this loss of connection.
Any thoughts as to what is going wrong?
I should also say I am extremely new to HA so not sure how to access logs or diagnostics etc.
This is the point where it loses connection. Logs from compile below:
INFO Reading configuration /config/esphome/nspanel-garage.yaml...
INFO Updating https://github.com/esphome/esphome.git@pull/2956/head
INFO Detected timezone 'Europe/London'
WARNING GPIO4 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing nspanel (board: esp32dev; framework: arduino; platform: platformio/espressif32 @ 3.5.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- <WiFi> 1.0
|-- <ESPmDNS> 1.0
|-- <Update> 1.0
|-- <WiFiClientSecure> 1.0
|-- <HTTPClient> 1.2
Compiling /data/nspanel/.pioenvs/nspanel/src/esphome/components/adc/adc_sensor.cpp.o
Compiling /data/nspanel/.pioenvs/nspanel/src/esphome/components/api/api_connection.cpp.o
Compiling /data/nspanel/.pioenvs/nspanel/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/nspanel/.pioenvs/nspanel/src/esphome/components/api/api_pb2.cpp.o
Anyone know how I could program this device without using Home Assistant? Is there a standalone compiler and flashing tool?
How do you know? I don’t see anything in the logs that indicates a problem. (But I would be the last person on these forums to trust to interpret the log files).
Have you successfully flashed any other devices, or is this the first?
Thats the point at which “Connection Lost. Reconnecting…” appears in the bottom left (sreenshot).
This is my first foray in to ESP32
That is the least of your problem, are you losing connection to HA only while compiling in esphome?
ConfigurationSettingsLogs
You can use Python on a PC, see Installing ESPHome Manually, then upload with ESPHome Web, or esphome-flasher.
Yep. Only when compiling. And happens every time without fail at the same point.
Power or resource issue?
Again.
No - first ESP32 experience
Resource is my first instinct too, but Rasp Pi 3 should be ok for this right?
I am the wrong person to ask this. I haven’t used a Raspberry Pi for years.
Compiling is generally CPU intensive, so a marginal power supply could cause it to brownout or reboot. Which would disconnect the browser.
Do you have any other ESP boards? My go-to board is the Wemos D1 Mini ($5 at Amazon). I have a couple of ESP32 boards in my workshop, but I haven’t put any of them into a project.
I would get another board and create a “new device” in ESPHome. Don’t add any code, just install it. Does the problem repeat?
Not necessarily, as @stevemann mentioned “Compiling is generally CPU intensive”, it’s been quite a few years since I upgraded from a Pi3, but I do remember I it had countless issues, what is the PSU power rating used for the Pi?
Have you had a look at your logs, or the CPU usage history for the time frame during compiling?
You can try a new yaml file with just the basics and see if it compiles, in Esphome, click “New Device”, enter any name, choose your board type, and install.
Another thing to try is, keep a constant ping on the Pi and see if it times out while compiling, this will tell you if the Pi is rebooting or if HA is just hanging, also, you should be able to tell by checking your “last boot /uptime sensors”, assuming you have integrated your system sensors.
Which ESP32 board are you using specifically?
Thanks for advice guys. That gives me a few things to check and try this evening.
If this turns out to be an under-sized PSU issue that would be a nice easy fix. If its CPU… well… time to try something new.
Whats annoying is the Pi3 was my back-up choice. I had already built a HA system on my server running as a virtual machine, but I couldn’t get my conbee stick to pass through and work on that!
This is the Sonoff NSPanel that I want to flash with ESP Home. But obviously I haven’t yet got to the point of connecting that to the PC yet!
So the ping never drops out during compiling even when the browser reports a connection loss.
I have also used a beefier PSU for the Pi and that has not helped.
Seems it is resource.
How can I compile this externally to HA?
Also logs:
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:412
Integration: Recorder (documentation, issues)
First occurred: 10:09:30 AM (1 occurrences)
Last logged: 10:09:30 AM
Ended unfinished session (id=52 from 2022-04-08 09:05:31.693657)
Source: components/recorder/util.py:254
First occurred: 10:09:28 AM (1 occurrences)
Last logged: 10:09:28 AM
The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
I had the same issues with my Pi3. It worked for a minimal YAML (but already took AGES), but once I started adding features the Pi always crashed during compiling. I’m now using the esphome commandline on a windows 10 laptop, I outlined my setup in I have ESP32 connected to my win10 via USB and connection works - now what? - #3 by Lakini
This looks like exactly what I need!
I’ll give this a whirl and report back!
Thank you!!!
hi. did you find the cause of the problem?
I have the similar problem.
I have six nspanel with the same problem… every about two hours, they disconnect from network and after 10 minutes they reboot… They are connect to different wifi network but the problem is same…
This is a verbose log by serial usb:
14:00:57.258 -> [6264794][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: bssidNetwork, Reason: 200
14:00:57.258 -> [6264796][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:00:57.305 -> [6264803][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 200 - BEACON_TIMEOUT
14:00:57.305 -> [6264810][D][WiFiGeneric.cpp:966] _eventCallback(): WiFi Reconnect Running
14:00:57.305 -> e[0;33m[W][wifi:125]: WiFi Connection lost... Reconnecting...e[0m[6264818][V][WiFiGeneric.cpp:97] set_esp_interface_ip(): Configuring Station static IP: 0.0.0.0, MASK: 0.0.0.0, GW: 0.0.0.0
14:00:57.305 ->
14:00:57.305 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:00:57.352 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:00:57.352 -> [6264856][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:00:57.352 -> [6264858][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:00:57.352 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:00:57.433 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:00:57.433 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:00:57.433 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:00:57.433 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:00:57.433 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:00:57.480 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:00:57.480 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:00:57.480 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:00:57.480 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:00:57.480 -> [6265015][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:00:57.480 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:00:57.480 -> [6265020][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:00:57.480 -> e[0;37m[V][component:200]: Component wifi took a long time for an operation (0.21 s).e[0m[6265028][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:00:57.527 ->
14:00:57.527 -> e[0;37m[V][component:201]: Components should block for at most 20-30ms.e[0m
14:00:57.527 -> e[0;33m[W][api.connection:058]: Home Assistant 2023.2.3 (::FFFF:192.168.178.126): Network unavailable, disconnectinge[0m
14:00:57.527 -> e[0;37m[V][api:114]: Removing connection to Home Assistant 2023.2.3 (::FFFF:192.168.178.126)e[0m
14:00:59.916 -> [6267439][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:00:59.916 -> [6267440][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:00:59.916 -> [6267448][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:00:59.916 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:00:59.963 -> e[0;33m[W][wifi:559]: WiFi network can not be found anymore.e[0m
14:00:59.963 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:00:59.963 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:00:59.963 -> [6267487][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:00:59.963 -> [6267490][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:00:59.963 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:00.056 -> e[0;37m[V][component:200]: Component wifi took a long time for an operation (0.13 s).e[0m
14:01:00.056 -> e[0;37m[V][component:201]: Components should block for at most 20-30ms.e[0m
14:01:04.844 -> e[0;37m[V][sensor:076]: 'Workroom NSPanel target_temperature': Received new state 20.600000e[0m
14:01:04.844 -> e[0;36m[D][sensor:127]: 'Workroom NSPanel target_temperature': Sending state 20.60000  with 1 decimals of accuracye[0m
14:01:05.078 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:05.078 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:05.078 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:05.078 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:05.078 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:05.078 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:05.078 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:05.126 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:05.126 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:05.126 -> [6272648][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:05.126 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:05.126 -> [6272653][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:05.126 -> [6272660][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:05.126 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:07.525 -> [6275069][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:07.559 -> [6275070][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:07.559 -> [6275077][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:07.559 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:07.559 -> e[0;33m[W][wifi:559]: WiFi network can not be found anymore.e[0m
14:01:07.606 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:07.606 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:07.606 -> [6275117][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:07.606 -> [6275119][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:07.606 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:07.687 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:07.687 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:07.687 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:07.687 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:07.720 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:07.720 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:07.720 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:07.720 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:07.720 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:07.767 -> [6275275][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:07.767 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:07.767 -> [6275280][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:07.767 -> [6275287][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:07.767 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:10.160 -> [6277696][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:10.160 -> [6277696][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:10.206 -> [6277704][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:10.206 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:10.206 -> e[0;33m[W][wifi:559]: WiFi network can not be found anymore.e[0m
14:01:10.206 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:10.206 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:10.206 -> [6277743][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:10.206 -> [6277746][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:10.253 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:10.346 -> e[0;37m[V][component:200]: Component wifi took a long time for an operation (0.13 s).e[0m
14:01:10.346 -> e[0;37m[V][component:201]: Components should block for at most 20-30ms.e[0m
14:01:15.330 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:15.330 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:15.330 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:15.330 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:15.330 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:15.330 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:15.330 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:15.377 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:15.377 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:15.377 -> [6282904][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:15.377 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:15.377 -> [6282909][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:15.377 -> [6282916][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:15.377 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:17.796 -> [6285325][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:17.796 -> [6285325][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:17.796 -> [6285333][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:17.844 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:17.844 -> e[0;33m[W][wifi:549]: Error while connecting to network.e[0m
14:01:17.844 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:17.844 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:17.844 -> [6285369][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:17.844 -> [6285371][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:17.844 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:17.932 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:17.932 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:17.978 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:17.978 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:17.978 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:17.978 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:17.978 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:17.978 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:17.978 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:17.978 -> [6285527][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:18.025 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:18.025 -> [6285532][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:18.025 -> [6285539][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:18.025 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:20.397 -> [6287948][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:20.431 -> [6287948][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:20.431 -> [6287956][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:20.431 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:20.431 -> e[0;33m[W][wifi:549]: Error while connecting to network.e[0m
14:01:20.479 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:20.479 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:20.479 -> [6287992][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:20.479 -> [6287995][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:20.479 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:20.572 -> e[0;37m[V][component:200]: Component wifi took a long time for an operation (0.12 s).e[0m
14:01:20.572 -> e[0;37m[V][component:201]: Components should block for at most 20-30ms.e[0m
14:01:20.572 -> e[0;37m[V][text_sensor:016]: 'Workroom NSPanel thermostat_mode': Received new state heate[0m
14:01:20.619 -> e[0;36m[D][text_sensor:067]: 'Workroom NSPanel thermostat_mode': Sending state 'heat'e[0m
14:01:25.564 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:25.564 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:25.610 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:25.610 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:25.610 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:25.610 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:25.610 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:25.610 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:25.610 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:25.610 -> [6293158][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:25.657 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:25.657 -> [6293163][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:25.657 -> [6293170][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:25.657 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:25.892 -> e[0;37m[V][sensor:076]: 'Workroom NSPanel WiFi Signal': Received new state 0.000000e[0m
14:01:25.892 -> e[0;36m[D][sensor:127]: 'Workroom NSPanel WiFi Signal': Sending state 0.00000 dBm with 0 decimals of accuracye[0m
14:01:26.590 -> e[0;37m[V][adc:132]: 'ntc_source': Got voltage=1.7950Ve[0m
14:01:26.590 -> e[0;37m[V][sensor:076]: 'ntc_source': Received new state 1.795000e[0m
14:01:26.590 -> e[0;36m[D][sensor:127]: 'ntc_source': Sending state 1.79500 V with 2 decimals of accuracye[0m
14:01:26.590 -> e[0;36m[D][resistance:039]: 'resistance_sensor' - Resistance 13358.1Ωe[0m
14:01:26.590 -> e[0;37m[V][sensor:076]: 'resistance_sensor': Received new state 13358.138672e[0m
14:01:26.638 -> e[0;36m[D][sensor:127]: 'resistance_sensor': Sending state 13358.13867 Ω with 1 decimals of accuracye[0m
14:01:26.638 -> e[0;36m[D][ntc:026]: 'Workroom NSPanel Temperature' - Temperature: 18.6°Ce[0m
14:01:26.638 -> e[0;37m[V][sensor:076]: 'Workroom NSPanel Temperature': Received new state 18.623339e[0m
14:01:26.638 -> e[0;36m[D][sensor:127]: 'Workroom NSPanel Temperature': Sending state 18.62334 °C with 1 decimals of accuracye[0m
14:01:26.638 -> e[0;37m[V][component:200]: Component adc.sensor took a long time for an operation (0.06 s).e[0m
14:01:26.673 -> e[0;37m[V][component:201]: Components should block for at most 20-30ms.e[0m
14:01:28.035 -> [6295579][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:28.082 -> [6295579][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:28.082 -> [6295587][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:28.082 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:28.082 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:28.082 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:28.129 -> e[0;33m[W][wifi:549]: Error while connecting to network.e[0m
14:01:28.129 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:28.129 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:28.129 -> [6295658][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:28.129 -> [6295659][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:28.129 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:28.223 -> e[0;37m[V][component:200]: Component wifi took a long time for an operation (0.12 s).e[0m
14:01:28.223 -> e[0;37m[V][component:201]: Components should block for at most 20-30ms.e[0m
14:01:33.224 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:33.271 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:33.271 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:33.271 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:33.271 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:33.271 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:33.271 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:33.271 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:33.271 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:33.271 -> [6300823][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:33.318 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:33.318 -> [6300828][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:33.318 -> [6300835][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:33.318 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:35.705 -> [6303243][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:35.705 -> [6303244][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:35.740 -> [6303252][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:35.740 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:35.740 -> e[0;33m[W][wifi:559]: WiFi network can not be found anymore.e[0m
14:01:35.740 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:35.787 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:35.787 -> [6303291][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:35.787 -> [6303294][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:35.787 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:35.868 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:35.868 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:35.868 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:35.868 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:35.868 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:35.915 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:35.915 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:35.915 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:35.915 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:35.915 -> [6303450][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:35.915 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:35.915 -> [6303455][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:35.915 -> [6303462][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:35.962 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:38.323 -> [6305870][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:38.369 -> [6305871][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:38.369 -> [6305879][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:38.369 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:38.369 -> e[0;33m[W][wifi:559]: WiFi network can not be found anymore.e[0m
14:01:38.369 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:38.369 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:38.416 -> [6305919][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:38.416 -> [6305921][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:38.416 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:38.510 -> e[0;37m[V][component:200]: Component wifi took a long time for an operation (0.13 s).e[0m
14:01:38.510 -> e[0;37m[V][component:201]: Components should block for at most 20-30ms.e[0m
14:01:43.488 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:43.488 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:43.535 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:43.535 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:43.535 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:43.535 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:43.535 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:43.535 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:43.535 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:43.535 -> [6311084][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:43.582 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:43.582 -> [6311089][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:43.582 -> [6311096][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:43.582 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:45.954 -> [6313505][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:46.000 -> [6313506][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:46.000 -> [6313513][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:46.000 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:46.000 -> e[0;33m[W][wifi:559]: WiFi network can not be found anymore.e[0m
14:01:46.000 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:46.047 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:46.047 -> [6313553][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:46.047 -> [6313555][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:46.047 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:46.141 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:46.141 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:46.141 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:46.141 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:46.141 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:46.141 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:46.141 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:46.188 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:46.188 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:46.188 -> [6313711][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:46.188 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:46.188 -> [6313716][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:46.188 -> [6313723][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:46.188 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:48.595 -> [6316131][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:48.595 -> [6316132][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:48.641 -> [6316140][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:48.641 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:48.641 -> e[0;33m[W][wifi:549]: Error while connecting to network.e[0m
14:01:48.641 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:48.641 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:48.641 -> [6316175][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:48.641 -> [6316178][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:48.688 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:48.735 -> e[0;37m[V][component:200]: Component wifi took a long time for an operation (0.12 s).e[0m
14:01:48.782 -> e[0;37m[V][component:201]: Components should block for at most 20-30ms.e[0m
14:01:53.770 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:53.770 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:53.770 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:53.770 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:53.770 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:53.770 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:53.770 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:53.817 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:53.817 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:53.817 -> [6321340][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:53.817 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:53.817 -> [6321345][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:53.817 -> [6321352][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:53.817 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:56.216 -> [6323760][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:56.263 -> [6323761][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:56.263 -> [6323769][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:56.263 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:56.263 -> e[0;33m[W][wifi:559]: WiFi network can not be found anymore.e[0m
14:01:56.263 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
14:01:56.263 -> e[0;37m[V][wifi_esp32:041]: Disabling STA.e[0m
14:01:56.263 -> [6323808][V][WiFiGeneric.cpp:341] _arduino_event_cb(): STA Stopped
14:01:56.310 -> [6323811][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 3 - STA_STOP
14:01:56.310 -> e[0;37m[V][wifi_esp32:464]: Event: WiFi STA stope[0m
14:01:56.404 -> e[0;32m[I][wifi:257]: WiFi Connecting to 'wifiNetwork'...e[0m
14:01:56.404 -> e[0;37m[V][wifi:259]: Connection Params:e[0m
14:01:56.404 -> e[0;37m[V][wifi:260]:   SSID: 'wifiNetwork'e[0m
14:01:56.404 -> e[0;37m[V][wifi:265]:   BSSID: Not Sete[0m
14:01:56.404 -> e[0;37m[V][wifi:283]:   Password: e[5m'wifiPassword'e[6me[0m
14:01:56.404 -> e[0;37m[V][wifi:290]:   Channel: Not Sete[0m
14:01:56.404 -> e[0;37m[V][wifi:295]:   Manual IP: Static IP=192.168.178.186 Gateway=192.168.178.1 Subnet=255.255.255.0 DNS1=0.0.0.0 DNS2=0.0.0.0e[0m
14:01:56.451 -> e[0;37m[V][wifi:299]:   Hidden: NOe[0m
14:01:56.451 -> e[0;37m[V][wifi_esp32:039]: Enabling STA.e[0m
14:01:56.451 -> [6323967][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
14:01:56.451 -> e[0;37m[V][wifi_esp32:444]: Event: WiFi readye[0m
14:01:56.451 -> [6323973][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
14:01:56.451 -> [6323979][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
14:01:56.451 -> e[0;37m[V][wifi_esp32:459]: Event: WiFi STA starte[0m
14:01:58.847 -> [6326388][V][WiFiGeneric.cpp:360] _arduino_event_cb(): STA Disconnected: SSID: wifiNetwork, BSSID: 00:00:00:00:00:00, Reason: 201
14:01:58.847 -> [6326389][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
14:01:58.893 -> [6326396][W][WiFiGeneric.cpp:950] _eventCallback(): Reason: 201 - NO_AP_FOUND
14:01:58.893 -> e[0;33m[W][wifi_esp32:491]: Event: Disconnected ssid='wifiNetwork' reason='Probe Request Unsuccessful'e[0m
14:01:58.893 -> e[0;33m[W][wifi:559]: WiFi network can not be found anymore.e[0m
14:01:58.893 -> e[0;33m[W][wifi:585]: Restarting WiFi adapter...e[0m
