I’m trying to set icons for the night on my display. I need to check if the sun is below horizon to display night icons. I’m using the sun component, but get errors compiling
The error I get
ha-panel.yaml: In lambda function:
ha-panel.yaml:1154:19: error: 'class esphome::sun::Sun' has no member named 'is_below_horizon'
Here the config
sun:
latitude: 51.521159
longitude: 4.271538
lambda: |-
std::string state = id(ha_weather_cond).state.c_str();
if (id(my_sun).is_below_horizon()) {
if (state == "SUNNY") {
return std::string("$night");
} else if (state == "PARTLYCLOUDY") {
return std::string("$nightpartlycloudy");
if (state == "RAINY") { return std::string("$rainy"); }
else if (state == "CLOUDY") { return std::string("$cloudy"); }
else if (state == "PARTLYCLOUDY") { return std::string("$partlycloudy"); }
else if (state == "SUNNY") { return std::string("$sunny"); }
else if (state == "FOG") { return std::string("$fog"); }
else if (state == "HAIL") { return std::string("$hail"); }
else if (state == "HAZY") { return std::string("$hazy"); }
else if (state == "LIGHTNING") { return std::string("$lightning"); }
else if (state == "LIGHTNINGRAINY") { return std::string("$lightningrainy"); }
else if (state == "NIGHT") { return std::string("$night"); }
else if (state == "NIGHTPARTLYCLOUDY") { return std::string("$nightpartlycloudy"); }
else if (state == "PARTLYRAINY") { return std::string("$partlyrainy"); }
else if (state == "PARTLYLIGHTNING") { return std::string("$partlylightning"); }
else if (state == "PARTLYSNOWY") { return std::string("$partlysnowy"); }
else if (state == "PARTLYSNOWYRAINY") { return std::string("$partlysnowyrainy"); }
else if (state == "POURING") { return std::string("$pouring"); }
else if (state == "SNOWY") { return std::string("$snowy"); }
else if (state == "SNOWYHEAVY") { return std::string("$snowyheavy"); }
else if (state == "SUNSET") { return std::string("$sunset"); }
else if (state == "TORNADO") { return std::string("$tornado"); }
else if (state == "WINDY") { return std::string("$windy"); }
else if (state == "HURRICANE") { return std::string("$hurricane"); }
return std::string("$happyface");
on_value:
then:
- logger.log: id(weather_condition_icon).state.c_str()
- lvgl.label.update:
text: !lambda return id(weather_condition_icon).state.c_str();
