Jpsy
(Jörg Wagner)
March 17, 2022, 7:54am
1
The CLI compile command…
esphome compile mynode.yaml
…does not compile into the same path as the web frontend of HA’s ESPHome add-on does. Instead it compiles into a sub-path “.pioenvs
”. Both compilation ways obey my build_path
setting, but the CLI version adds that sub-path below it.
As a result the CLI compile does not see the web frontend’s compile results. It downloads and compiles nodes again that have already been processed through the frontend.
Funny enough, the frontend seems to see the CLI compile results, although they are not in its normal compile destination. Nodes compiled through CLI are NOT marked with “Update available” any more in the frontend. They are shown as “Online” (= up-to-date).
Any ideas how I can force both worlds to use an identical compile path?
Jpsy
(Jörg Wagner)
March 17, 2022, 12:34pm
2
Hmmm. Looks my analysis was not correct:
After a run of CLI compile…
[build_path]/src/esphome contains the sources of all dependencies
[build_path]/.pioenvs/[nodename]/src/esphome contains the binaries of all dependencies
After a run of frontend compile…
So where are the binaries in the second run?
Jpsy
(Jörg Wagner)
March 24, 2022, 8:17pm
3
I opened up an issue for this:
opened 08:14PM - 24 Mar 22 UTC
### The problem
I use two ways to compile my ESPHome YAML nodes:
1. through … the web frontend of the ESPHome add-on for HA and
1. through CLI
**The problem:**
If I switch between both methods the compile goes through all files again. It does not seem to find any existing compile results and repeats all the work which takes a lot of time. I think this is because both methods store their compiled files in different folders.
I tried to compare the output of both compiles and upload runs. Here are the important lines from both versions.
They differ mainly in the leading /data/smoke-eg-flur/ of the web version. But the final "INFO Uploading" line differs only in a leading /data/.
Hint: My node YAML contains `build_path: "smoke-eg-flur"` for these examples.
Output of install OTA through **HA add-on web frontend**:
INFO Reading configuration /config/esphome/smoke-eg-flur.yaml...
INFO Deleting /data/smoke-eg-flur/.pioenvs
Compiling /data/smoke-eg-flur/.pioenvs/smoke-eg-flur/src/esphome/components/adc/adc_sensor.cpp.o
Compiling /data/smoke-eg-flur/.pioenvs/smoke-eg-flur/src/esphome/components/api/api_connection.cpp.o
Compiling /data/smoke-eg-flur/.pioenvs/smoke-eg-flur/src/esphome/components/api/api_frame_helper.cpp.o
Linking /data/smoke-eg-flur/.pioenvs/smoke-eg-flur/firmware.elf
RAM: [==== ] 43.2% (used 35420 bytes from 81920 bytes)
Flash: [==== ] 44.7% (used 466485 bytes from 1044464 bytes)
Building /data/smoke-eg-flur/.pioenvs/smoke-eg-flur/firmware.bin
esp8266_copy_factory_bin(["/data/smoke-eg-flur/.pioenvs/smoke-eg-flur/firmware.bin"], ["/data/smoke-eg-flur/.pioenvs/smoke-eg-flur/firmware.elf"])
INFO Uploading /data/smoke-eg-flur/.pioenvs/smoke-eg-flur/firmware.bin (470640 bytes)
Output of compile and upload OTA through **CLI**:
INFO Reading configuration smoke-eg-flur.yaml...
INFO Deleting smoke-eg-flur/.pioenvs
Compiling .pioenvs/smoke-eg-flur/src/esphome/components/adc/adc_sensor.cpp.o
Compiling .pioenvs/smoke-eg-flur/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/smoke-eg-flur/src/esphome/components/api/api_frame_helper.cpp.o
Linking .pioenvs/smoke-eg-flur/firmware.elf
Building .pioenvs/smoke-eg-flur/firmware.bin
esp8266_copy_factory_bin([".pioenvs/smoke-eg-flur/firmware.bin"], [".pioenvs/smoke-eg-flur/firmware.elf"])
INFO Uploading smoke-eg-flur/.pioenvs/smoke-eg-flur/firmware.bin (470640 bytes)
### Which version of ESPHome has the issue?
2022.3.1
### What type of installation are you using?
Home Assistant Add-on
### Which version of Home Assistant has the issue?
2022.3.7
### What platform are you using?
ESP8266
### Board
Wemos D1-mini
### Component causing the issue
_No response_
### Example YAML snippet
```yaml
# Doesn't depend on concrete YAML content.
# Might be relevant that I use:
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
