Not sure if this is the correct forum. I am trying to replace a thermostat for a HVAC system with an NodeMcu. I have successfully used the Climate Bang Bang in ESP home and a thermostat card in lovelace. It works great, except I can’t work out how to create a time lock to delay the signal going from heat to cool. ie I would like a delay of say 5 minutes before a heat signal is sent after a cool signal has been sent and visa versa. Also is this the correct method of using Esphome and Lovelace?
Search esphome github repository of issues. I believe this feature is requested already. You can upvote there and increase the chances of a feature like that to be implemented
Hi Mark, I would be interest to see your esphome yaml and lovelace yaml for the Bang Bang, if you could post it? I messed around with the Bang Bang thermostat and couldn’t get it to function properly and put it aside till later.
In regards to a delay, almost every air conditioner I’ve work on in 20 years has a delay on break timer fitted to stop a quick change between modes of heat and cool, and restarts, it’s usually just a solid state device to the relay that controls the compressor in the outdoor unit. (Excluding new fancy electronic controlled units, for which it is unlikely you would be using a Bang Bang thermostat on.)
Please note, I am still in beta stage, so code is very rough. I am passing the temperature from Home assistant, because the temperature is coming from a different NodeMcu.
ESPhome.yaml
I am now thinking of going a different direction. That is to use the climate function in home assistant, using the ESPhome switches. having two thermostat,s but with a button, that displays the relevant heat or cool thermostat.
api:
ota:
dallas:
- pin: D1
- platform: homeassistant
name: "Input Boolean From Home Assistant"
entity_id: sensor.bom_melbourne_air_temp_c
- platform: dht
pin: D2
temperature:
name: "upstairs temp d2"
humidity:
name: "upstairs hum d2"
update_interval: 60s
model: dht22
- platform: dht
pin: D5
temperature:
name: "upstairs temp d5"
humidity:
name: "upstairs hum d5"
model: dht22
- platform: dht
pin: D6
temperature:
name: "upstairs temp d6"
humidity:
name: "upstairs hum d6"
model: dht22
- platform: dallas
address: 0xFB011448396CAA28
- platform: dallas
address: 0xF1011447E3DCAA28
name: "Temp dallas 2"
switch:
- platform: gpio
pin: D3
- platform: gpio
pin: D7
climate:
- platform: bang_bang
visual:
min_temperature: 12 °C
max_temperature: 25 °C
temperature_step: 0.1 °C
sensor: temp_dallas_1
default_target_temperature_low: 12 °C
default_target_temperature_high: 22 °C
heat_action:
- switch.turn_on: Heating_D3
idle_action:
- switch.turn_off: Heating_D3
- switch.turn_off: Cooling_d7
cool_action:
- switch.turn_on: Cooling_d7
LoveLace
- entity: climate.esp_climate
type: thermostat```
type or paste code here
@Mark53 Are you using SSR or mechanical relays on your heating/cooling pins? also, are you controlling the fan with it?
Hi Evban,
I have changed my config. I am using ESPhome for the relays, not SSR and using home assistant withy generic climate to contrl the rest. I have two thermostat cards, one for heating and one for cooling, using a conditional card to display the card that is required. Yes the relays control the fan. I found the bang bang controller made is two dfiffciult, it is must easier with home assistant. It looks like they may have released a fix for the bang bang controller, but I had an issue where both heating and coling were on.
I think it was two years ago now, but before they had implemented the bang bang platform, I was working on an air conditioner config that would do the minimum delay functionality. It involved a few global variables, but allowed me to set my AC to run the compressor for a minimum on time of two minutes, and I think I got it to respect a minimum off time as well. If not, it would be a simple matter to imlement the pattern I used a second time.
You can see the scripts file specifically in the repo: https://github.com/jptrsn/esphome_aircon/blob/0c7c1f88f10c0b718ce31b3d969dfd4d2e9e43b6/scripts.yaml
That might be helpful.
Cheers
