I have the following configuration:
climate:
- platform: thermostat
name: "Vloerverwarming controller"
sensor: vloerverwarming_aanvoer
min_cooling_off_time: 300s
min_cooling_run_time: 300s
min_idle_time: 30s
cool_action:
- switch.turn_on: vloerverwarming_pomp
idle_action:
- switch.turn_off: vloerverwarming_pomp
default_preset: Home
preset:
- name: Home
mode: cool
default_target_temperature_high: 24°C
My dashboard in HA is reporting that the preset is correctly taken;
Temperature is also above the setpoint to start cooling, but my switch is not turned on.
What am i missing? I am trying to create something that turns ON a switch when the temp > 24 and turn it off when temp is <=24.
Since the sensors are currently above the values, should i put the termostat (one-time) manually to COOL mode in HA?
