Esphome + climate + fujitsu IR AC
Hello, I 've a problem with ir fujitsu climate; so I see the climate card in the lovelace and the card work correctly, but the ir code probabily is not right for the split. In the configuration I create 2 button to send two code that i found with the original remote AR-DB1 and all button work. So can someone help me to understand the card send the wrong code?
this is yaml file per esphome:
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "1xxxxxxxxxxxxxxxxxxxxxxxx111"
wifi:
  ssid: !secret wifi_ssid
# Directly connects to WiFi network without doing a full scan first
  fast_connect: true
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.63
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
    ssid: "Trasmettitore-Ir"
    password: "UXvJOYuKa43J"
#web server
web_server:
  port: 80
  auth:
    username: !secret web_server_username
    password: !secret web_server_password
captive_portal:
#sensor
  - platform: homeassistant
    name: "Temperatura soggiorno"
    entity_id: sensor.temperatura_soggiorno
status_led:
  pin: GPIO4
# Example configuration entry
remote_transmitter:
  pin: GPIO14
  carrier_duty_percent: 50%
remote_receiver:
  pin:
    number: GPIO12
    inverted: true
    mode:
      input: true
      #pullup: true
  dump: all
climate:
  - platform: fujitsu_general #heatpumpir
    #protocol: panasonic_dke
    #horizontal_default: auto
    #vertical_default: auto
    #max_temperature: 30
    #min_temperature: 16      # adjust to match your AC unit!
    visual:
      min_temperature: 16
      max_temperature: 30
      temperature_step: 0.1
    name: "Fujitsu soggiorno"
    receiver_id: ricevitore
    sensor: sensortempsogg
# Individual switches
button:
    on_press:
      - remote_transmitter.transmit_aeha:
          address: 0x28C6
          data: [0x00, 0x08, 0x08, 0x3F, 0x10, 0x0C, 0x81, 0x40, 0xC0, 0x00, 0x00, 0x00, 0x52]
    on_press:
          address: 0x28C6
          data: [0x00,0x08,0x08,0x40]
You probably need to configure a DIY thermostat using the temp sensor and on/off codes rather than using the Fujitsu one.
You might want to consider combining the on/off codes into a template switch and using that.
You might want to repeat sending the codes a few times.
I actually have a door sensor on the flap of my Aircon to confirm it’s on/off state. The remote with repeat if the target on/off state isn’t confirmed after a few seconds.
