Hi!
I have esphome climate working nice, but I would like to restore the default climate preset after 24 hours if any manual changes have been made, but do not know how to do it inside esp.
Example:
If someone changes preset to another preset than the new preset stays, but if someone changes temperature manually (for example from 22C to 15C), than after 24 hour the default preset (22 C) should be returned.
Any ideas?
Thank you!
Try this for climate thermostat
component.
interval:
- interval: 24h
then:
- climate.control:
preset: your_preset_name
or just set target temperature, not using presets:
- climate.control:
target_temperature: your_target_temperature
Thank you for reply, but such uses preset every 24h, not since the last change and does not consider if the the temperature change was made manually or another preset was applied/
Easy
climate:
on_control:
- lambda: |-
if (x.get_target_temperature().has_value()
& (*x.get_target_temperature() != id(climate_pid).target_temperature)
id(climate_temperature_changed).execute();
script:
- id: climate_temperature_changed
mode: restart
then:
- delay: 5s
- climate.control:
target_temperature: 21
on_control
fires on any change of mode or target temperature(s),
then if target temperature changed (x.get_target_temperature().has_value()
new temperature *x.get_target_temperature()
not equal current id(your_climate_id).target_temperature
- script gonna to be started.
mode: restart
will ensure delay after last of change,
mode: single
from first one.
Super cool!
works like a charm!
Thank you a lot!
Please check small change in code to prevent script starting on other actions like ON/OFF, but only target_temperature
changes.
Did not get what should I check, could you post full script with changes?
This one edited to check only control event with new target temperature.
You are absolutely right! Now it works as it should, restores only when temperature is change. Script does not work when ON|OFF.
Thank you once again!
Just one more thing - at the end of script it is better to use custom_preset instead of target_temperature
It depends on Your need: change target temperature or activate preset, no problem. Or do whatever else.
Nice to help. See ya.
As topic author - mark as solution, please.
It can help other to see is discussion is in progress or finished.
