New post for problem with new code:
I live in Finland, Tampere region and finally got HAN enabled meter from utility company. Bought Slimmelezer+ several years ago and was hoping to have easy integration to HA. Sadly, DSMR did not work and after few hours of debugging and scratching head, needed just to do all parsing bymyself with own code.
So, if you live in Finland in Tampere region (maybe someone elsewhere in the world can use same code too, let me know!) and you can read unencrypted uart-data, here’s one example of esphome code:
esphome:
name_add_mac_suffix: false
platform: ESP8266
esp8266_restore_from_flash: true
board: d1_mini
project:
version: "2024.11.0"
api:
encryption:
key: **your*encryption*key*here*
wifi:
ssid: !secret wifi_ssid
ap:
ssid: slimmelezer
manual_ip:
static_ip: 192.168.1.200
gateway: 192.168.1.1
subnet: 255.255.255.0
safe_mode:
captive_portal:
logger:
baud_rate: 0
ota:
platform: esphome
dashboard_import:
package_import_url: github://zuidwijk/dsmr/slimmelezer.yaml@main
import_full_config: true
web_server:
port: 80
uart:
- id: uart_bus
baud_rate: 115200
rx_pin: D7
rx_buffer_size: 1700
debug:
direction: RX
dummy_receiver: true
after:
delimiter: "\r\n"
sequence:
- lambda: |-
std::string data(bytes.begin(), bytes.end());
// Helper function to extract a numeric value safely
auto extract_value = [&](const std::string& key, float& result) -> bool {
size_t start = data.find(key + "(");
if (start == std::string::npos) return false;
size_t end = data.find(')', start);
if (end == std::string::npos) return false;
std::string value_str = data.substr(start + key.length() + 1, end - start - key.length() - 1);
char* end_ptr;
result = strtof(value_str.c_str(), &end_ptr);
return end_ptr != value_str.c_str(); // Ensure valid conversion
// Helper function to extract a string value
auto extract_string = [&](const std::string& key, std::string& result) -> bool {
result = data.substr(start + key.length() + 1, end - start - key.length() - 1);
return true;
float value;
std::string str_value;
// OBIS codes and sensor publishing
if (extract_string("0-0:1.0.0", str_value)) { // Timestamp
id(timestamp_sensor).publish_state(str_value.c_str());
if (extract_value("1-0:1.8.0", value)) { // Active energy import
id(active_energy_import_sensor).publish_state(value);
if (extract_value("1-0:2.8.0", value)) { // Active energy export
id(active_energy_export_sensor).publish_state(value);
// OBIS Code: 1-0:1.7.0 (Active power import)
if (extract_value("1-0:1.7.0", value)) {
id(active_power_import_sensor).publish_state(value);
// OBIS Code: 1-0:2.7.0 (Active power export)
if (extract_value("1-0:2.7.0", value)) {
id(active_power_export_sensor).publish_state(value);
// OBIS Code: 1-0:3.7.0 (Reactive power import)
if (extract_value("1-0:3.7.0", value)) {
id(reactive_power_import_sensor).publish_state(value);
// OBIS Code: 1-0:4.7.0 (Reactive power export)
if (extract_value("1-0:4.7.0", value)) {
id(reactive_power_export_sensor).publish_state(value);
// OBIS Code: 1-0:5.7.0 (Apparent power)
if (extract_value("1-0:5.7.0", value)) {
id(apparent_power_sensor).publish_state(value);
// OBIS Code: 1-0:6.7.0 (Active energy)
if (extract_value("1-0:6.7.0", value)) {
id(active_energy_sensor).publish_state(value);
// OBIS Code: 1-0:7.7.0 (Reactive energy)
if (extract_value("1-0:7.7.0", value)) {
id(reactive_energy_sensor).publish_state(value);
// OBIS Code: 1-0:8.7.0 (Apparent energy)
if (extract_value("1-0:8.7.0", value)) {
id(apparent_energy_sensor).publish_state(value);
// OBIS Code: 1-0:9.7.0 (Power factor)
if (extract_value("1-0:9.7.0", value)) {
id(power_factor_sensor).publish_state(value);
// OBIS Code: 1-0:10.7.0 (Voltage L1)
if (extract_value("1-0:10.7.0", value)) {
id(voltage_L1_sensor).publish_state(value);
// OBIS Code: 1-0:11.7.0 (Voltage L2)
if (extract_value("1-0:11.7.0", value)) {
id(voltage_L2_sensor).publish_state(value);
// OBIS Code: 1-0:12.7.0 (Voltage L3)
if (extract_value("1-0:12.7.0", value)) {
id(voltage_L3_sensor).publish_state(value);
// OBIS Code: 1-0:13.7.0 (Current L1)
if (extract_value("1-0:13.7.0", value)) {
id(current_L1_sensor).publish_state(value);
// OBIS Code: 1-0:14.7.0 (Current L2)
if (extract_value("1-0:14.7.0", value)) {
id(current_L2_sensor).publish_state(value);
// OBIS Code: 1-0:15.7.0 (Current L3)
if (extract_value("1-0:15.7.0", value)) {
id(current_L3_sensor).publish_state(value);
// OBIS Code: 1-0:16.7.0 (Power demand)
if (extract_value("1-0:16.7.0", value)) {
id(power_demand_sensor).publish_state(value);
// OBIS Code: 1-0:17.7.0 (Maximum power demand)
if (extract_value("1-0:17.7.0", value)) {
id(max_power_demand_sensor).publish_state(value);
// OBIS Code: 1-0:18.7.0 (Energy import in last 15 minutes)
if (extract_value("1-0:18.7.0", value)) {
id(energy_import_15min_sensor).publish_state(value);
// OBIS Code: 1-0:19.7.0 (Energy export in last 15 minutes)
if (extract_value("1-0:19.7.0", value)) {
id(energy_export_15min_sensor).publish_state(value);
// OBIS Code: 1-0:20.7.0 (Energy import in last 60 minutes)
if (extract_value("1-0:20.7.0", value)) {
id(energy_import_60min_sensor).publish_state(value);
// OBIS Code: 1-0:21.7.0 (Energy export in last 60 minutes)
if (extract_value("1-0:21.7.0", value)) {
id(energy_export_60min_sensor).publish_state(value);
// OBIS Code: 1-0:22.7.0 (Total energy import)
if (extract_value("1-0:22.7.0", value)) {
id(total_energy_import_sensor).publish_state(value);
// OBIS Code: 1-0:23.7.0 (Total energy export)
if (extract_value("1-0:23.7.0", value)) {
id(total_energy_export_sensor).publish_state(value);
name: "Active Energy Import"
unit_of_measurement: "kWh"
state_class: total
device_class: energy
accuracy_decimals: 3
name: "Active Energy Export"
state_class: total
name: "Active Power Import"
unit_of_measurement: "W"
accuracy_decimals: 2
name: "Active Power Export"
name: "Reactive Power Import"
unit_of_measurement: "var"
name: "Reactive Power Export"
unit_of_measurement: "VA"
unit_of_measurement: "kvarh"
unit_of_measurement: "kVAh"
unit_of_measurement: ""
unit_of_measurement: "V"
unit_of_measurement: "A"
name: "Maximum Power Demand"
name: "Energy Import in Last 15 Minutes"
unit_of_measurement: "Wh"
name: "Energy Export in Last 15 Minutes"
name: "Energy Import in Last 60 Minutes"
name: "Energy Export in Last 60 Minutes"
name: "Total Energy Import"
name: "Total Energy Export"
text_sensor:
- platform: wifi_info
ip_address:
name: "SlimmeLezer IP Address"
ssid:
name: "SlimmeLezer Wi-Fi SSID"
bssid:
name: "SlimmeLezer Wi-Fi BSSID"
- platform: version
hide_timestamp: true
