Hi, I have not upgraded my HA/ESPhome for some time. Compilation of yaml config fails. I tried to simplify the config as much as possible but still get errors. Was there anybody in similar situation?
config file:
esphome:
esp8266:
board: nodemcuv2
restore_from_flash: true
framework:
version: 2.7.4
wifi:
ssid: "Mydlinka"
password: "secretpassword"
manual_ip:
gateway: 192.168.88.1
subnet: 255.255.255.0
static_ip: 192.168.88.84
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "secretpassword2"
ota:
- platform: esphome
password: "secretpassword3"
log:
INFO ESPHome 2024.12.2
INFO Reading configuration /config/esphome/kamerka.yaml...
WARNING The selected Arduino framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
INFO Generating C++ source...
INFO Compiling app...
Processing kam (board: nodemcuv2; framework: arduino; platform: platformio/[email protected])
Library Manager: Installing esphome/ESPAsyncTCP-esphome @ 2.0.0
INFO Installing esphome/ESPAsyncTCP-esphome @ 2.0.0
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.2.2
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.2.2
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
Compiling .pioenvs/kam/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/kam/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/kam/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/kam/src/esphome/components/api/api_pb2_service.cpp.o
In file included from src/esphome/components/api/api_connection.h:8:0,
from src/esphome/components/api/api_connection.cpp:1:
src/esphome/components/api/api_server.h:140:96: error: invalid use of '::'
Trigger<std::string, std::string> *client_connected_trigger_ = new Trigger<std::string, std::string>();
src/esphome/components/api/api_server.h:140:96: error: expected ';' at end of member declaration
src/esphome/components/api/api_server.h:140:102: error: expected unqualified-id before '>' token
src/esphome/components/api/api_server.h:141:99: error: invalid use of '::'
Trigger<std::string, std::string> *client_disconnected_trigger_ = new Trigger<std::string, std::string>();
src/esphome/components/api/api_server.h:141:99: error: expected ';' at end of member declaration
src/esphome/components/api/api_server.h:141:105: error: expected unqualified-id before '>' token
src/esphome/components/api/api_server.h:140:83: error: template argument 1 is invalid
src/esphome/components/api/api_server.h:141:86: error: template argument 1 is invalid
Compiling .pioenvs/kam/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/kam/src/esphome/components/api/list_entities.cpp.o
cc1plus: warning: unrecognized command line option "-Wno-nonnull-compare" [enabled by default]
*** [.pioenvs/kam/src/esphome/components/api/api_connection.cpp.o] Error 1
In file included from src/esphome/components/api/api_server.cpp:1:0:
from src/esphome/components/api/list_entities.cpp:3:
*** [.pioenvs/kam/src/esphome/components/api/list_entities.cpp.o] Error 1
*** [.pioenvs/kam/src/esphome/components/api/api_server.cpp.o] Error 1
========================= [FAILED] Took 21.13 seconds =========================
