I have the following configuration in ESPHome and when I compile I get the warning messages:
/config/esphome/bath_drawer.yaml: In lambda function:
/config/esphome/bath_drawer.yaml:101:26: warning: ‘void esphome::cover::Cover::stop()’ is deprecated (declared at src/esphome/components/cover/cover.h:146): stop() is deprecated, use make_call().set_command_stop() instead. [-Wdeprecated-declarations]
id(win_open).stop();
/config/esphome/bath_drawer.yaml:104:27: warning: ‘void esphome::cover::Cover::close()’ is deprecated (declared at src/esphome/components/cover/cover.h:140): close() is deprecated, use make_call().set_command_close() instead. [-Wdeprecated-declarations]
id(win_open).close();
/config/esphome/bath_drawer.yaml:109:26: warning: ‘void esphome::cover::Cover::stop()’ is deprecated (declared at src/esphome/components/cover/cover.h:146): stop() is deprecated, use make_call().set_command_stop() instead. [-Wdeprecated-declarations]
/config/esphome/bath_drawer.yaml:112:26: warning: ‘void esphome::cover::Cover::open()’ is deprecated (declared at src/esphome/components/cover/cover.h:134): open() is deprecated, use make_call().set_command_open() instead. [-Wdeprecated-declarations]
id(win_open).open();
Can someone assist to correct my config.
esphome:
platform: ESP8266
board: d1_mini
on_boot:
then:
- switch.turn_off: win1
- switch.turn_off: win2
wifi:
ssid: "xxxxxxxxx"
password: "xxxxxxxx"
ap:
ssid: "Bath Drawer"
password: "judy1234"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
output:
- platform: gpio
pin: D2
- platform: gpio
pin: D1
switch:
- platform: output
output: 'win_1'
- platform: output
output: 'win_2'
- platform: restart
- platform: gpio
pin: D7
inverted: True
cover:
optimistic: true
assumed_state: true
open_action:
- switch.turn_on: win1
- delay: 14s
close_action:
- switch.turn_on: win2
- delay: 14s
stop_action:
binary_sensor:
- platform: gpio
pin: RX
device_class: door
on_release:
then:
- platform: gpio
pin: D5
name: "drawer Control Button"
filters:
- invert:
- delayed_on_off: 50ms
on_press:
then:
- lambda: |
if (id(win_open).position == cover::COVER_OPEN) {
if (id(win1).state){
// drawer is opening
} else {
// drawer is open and not moving
} else {
if (id(win2).state){
// drawer is closing
} else {
// win is closed and not moving
dallas:
- pin: GPIO2
- platform: dallas
address: 0x9203139779F68228
- platform: wifi_signal
name: "Bath Drawer RSSI"
update_interval: 120s
