I’ve created a native ESPHome component for Culligan CS Meter Soft water softeners that communicates directly via Bluetooth Low Energy.
Features
- Auto-Discovery - Automatically finds your water softener by Bluetooth name (no need to find the MAC address)
- 30+ Sensors - Real-time flow, water usage, salt level, battery, cycle times, and lifetime statistics
- 12 Adjustable Settings - Control hardness, regeneration schedule, cycle times, salt alerts directly from Home Assistant
- Device Control - Buttons for immediate/scheduled regeneration, time sync, counter reset
- Display Switch - Toggle the device display on/off
- 8 Binary Sensors - Status flags (regenerating, bypass active, display off, etc.)
Sensors Include
- Current flow rate (GPM)
- Soft water remaining (gallons)
- Daily water usage
- Salt level (lbs and %)
- Days until regeneration
- Total gallons treated (lifetime)
- Total regenerations
- Battery level
- And many more…
Quick Start
esp32_ble_tracker:
scan_parameters:
active: true
on_ble_advertise:
- then: [] # Required for auto-discovery
ble_client:
- mac_address: "00:00:00:00:00:00" # Auto-discovery will find it
external_components:
- source:
type: git
url: https://github.com/jtubb/esphome-culligan-water-softener
ref: main
components: [ culligan_water_softener ]
culligan_water_softener:
ble_client_id: culligan_ble_client
auto_discover: true
password: 1234 # Default password
- platform: culligan_water_softener
culligan_water_softener_id: water_softener
current_flow:
name: "Water Softener Flow"
soft_water_remaining:
name: "Soft Water Remaining"
brine_level:
battery_level:
Requirements
- ESP32 (tested with ESP32-S3)
- Culligan water softener with “CS_Meter_Soft” Bluetooth name
- ESPHome with ESP-IDF framework
Links
- GitHub: GitHub - jtubb/esphome-culligan-water-softener
- Full documentation and example configurations in the repository
- Partner Lovelace Card - GitHub - jtubb/culligan-water-softener-card: ISA-101 compliant Home Assistant Lovelace card for Culligan water softeners
