ESPHome component for WaterFurnace Aurora geothermal heat pumps
I have a WaterFurnace 7-Series geothermal heat pump. Like most WaterFurnace owners who want integration with Home Assistant, my options were either the Symphony cloud add-on (with the existing HA cloud integration) or Cody Cutrer’s excellent waterfurnace_aurora Ruby gem, which bridges the heat pump’s maintenance port to MQTT via a Raspberry Pi.
I didn’t want a cloud dependency, and while the Ruby bridge works well, I wanted something that could run on an ESP32 and speak the ESPHome native API directly - no Pi, no MQTT broker in the middle. So I ported the protocol to C++ as an ESPHome custom component.
How it works
WaterFurnace Aurora heat pumps have an RJ45 “AID Tool” port on the ABC board that exposes an RS-485 interface. The protocol is Modbus RTU with some proprietary function codes that allow reading large batches of non-contiguous registers in a single transaction. Cody Cutrer did the hard work of reverse-engineering all of this for the Ruby gem; I just translated it into something an ESP32 can run.
The hardware is straightforward: an ESP32, a MAX485 transceiver module (the kind with exposed DE/RE pins - avoid the “automatic flow control” modules), and a standard Ethernet cable with one end cut off and wired to the transceiver. The repo has wiring diagrams. One thing to be careful of: pins 5-8 on the RJ45 port carry 24VAC - only connect pins 1-4.
What you get
The component gives you a climate entity with full thermostat control (heat, cool, auto, emergency heat, dual setpoints, fan modes). On IntelliZone 2 systems, each zone gets its own climate entity.
Beyond the thermostat, it exposes the wealth of sensor data the heat pump reports - air and water temperatures, compressor speed, power consumption broken down by component (compressor, blower, aux heat, loop pump), refrigeration pressures, water flow rate, COP, and more. There are around 55 sensors, 15 binary sensors, and various controls for things like DHW setpoints, blower speeds, and humidity targets. The full entity list is in the repo docs.
The component auto-detects your hardware configuration at startup - AXB accessory board, variable speed drive, IZ2 zones, blower type, energy monitor level - so the YAML configuration is minimal. Basically just your GPIO pins.
Firmware requirement
Your thermostat firmware needs to be AWL version 3.0 or above for full control access. Older versions will report some sensor data but won’t let you change setpoints or modes. You can check the version in the thermostat’s settings screen; your WaterFurnace dealer can update it if needed.
Energy tracking
The total power usage sensor can be fed into HA’s Riemann Sum Integral helper (kilo prefix, hours for time unit) to get kWh values for the Energy Dashboard. This is useful if you want to evaluate whether your HVAC automations are actually saving energy or just moving consumption around.
Installation
substitutions:
  friendly_name: "WaterFurnace"
  uart_tx_pin: GPIO17
  uart_rx_pin: GPIO16
  flow_control_pin: GPIO4
packages:
  waterfurnace.aurora: github://daemonp/esphome_waterfurnace_aurora/waterfurnace_aurora.yaml@master
esphome:
  friendly_name: ${friendly_name}
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
api:
ota:
wifi:
  ssid: !secret wifi_ssid
Help wanted
I’ve been running this on my 7-Series and it’s been stable, but WaterFurnace ships a lot of different configurations and I can only test against what I have. If you have a 3-Series, 5-Series, IZ2 multi-zone setup, or anything else I haven’t been able to test against, I’d genuinely like to hear whether it works correctly - or doesn’t. Issues and pull requests are welcome.
There’s also a 3D-printable project box by @benpeart if you want a tidy enclosure for the hardware.
Documentation and source: github.com/daemonp/esphome_waterfurnace_aurora
Nice advancement. I’ve been running Cody Cutrer’s code for multiple years. They say if it ain’t broke don’t fix it, but I might have to give this a try.
The timing on this is ironic — two weeks ago I was looking for an existing ESPHome GitHub project to do exactly this and couldn’t find one, so I ended up building my own solution: GitHub - espforge/esphome-waterfurnace
I’m using the Waveshare ESP32 hardware with built-in RS485, which made the wiring side of things pretty clean. I’m currently in the process of deploying it across 20+ WaterFurnace units, some of which have the iZ2 zoning system. I haven’t had a chance to do a detailed comparison of our two implementations yet, but I plan to. It might be worth combining efforts if there’s significant overlap — I’ll report back once I’ve had a chance to dig in!
I just tried to build this and when I attempt the install on an esp32 I get the error:
INFO ESPHome 2025.12.4
INFO Reading configuration /config/esphome/waterfurance-esp.yaml…
INFO Unable to import component water_heater: No module named ‘esphome.components.water_heater’
Failed config
water_heater: [source /data/packages/83f71a22/waterfurnace_aurora.yaml:123]
  Component not found: water_heater.
  - platform: waterfurnace_aurora
    name: Domestic Hot Water
    aurora_id: aurora
Configuration
substitutions:
  friendly_name: "Geothermal Heat Pump"
  # Adjust pins to match your wiring
  uart_tx_pin: GPIO17
  uart_rx_pin: GPIO16
packages:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_key
ota:
  - platform: esphome
    password: !secret ota_password
wifi:
  manual_ip:
    static_ip: 192.168.10.202
    gateway: 192.168.10.2
    subnet: 255.255.255.0
    dns1: 192.168.10.2
  ap:
    ssid: "WaterFurance Wifi Fallback Hotspot"
    password: "Use2Config"
captive_portal:
# Enable Web server.
web_server:
  port: 80
In the ESPHome editor it also shows the error
Water heater component was added in ESPHome 2026.1.0 release
Thanks, that fixed it.
Thanks to everyone who’s been testing and providing feedback, it’s been incredibly helpful.
A few things to share:
As @psyko_chewbacca pointed out (and @bkprath confirmed), the water_heater component requires ESPHome 2026.1.0+. If you’re on ESPHome 2025.12.x, you’ll get the Component not found: water_heater error. Upgrading to 2026.1.0 or later resolves this. I’ve also added version-detection code so the component handles the API changes between 2026.1.x and 2026.2+ automatically (no user intervention needed). If you need to stay on an older ESPHome version, you can comment out the water_heater: section in the package and use the legacy switch: + number: entities for DHW control instead.
What’s Landed on master Recently
  • Water Heater entity for DHW: Domestic Hot Water now shows up as a proper Water Heater card in HA with current temp, target setpoint, and mode (Off / Heat Pump), replacing the old separate switch + number approach.
  • Full Climate entity with humidity support: The climate entity now reports current humidity, supports a target humidity slider (mode-aware: humidification in heat modes, dehumidification in cool), dual setpoints in auto mode, and shows Drying as an action during active dehumidification. Emergency Heat is available via the Boost preset.
  • IZ2 multi-zone support: Up to 6 IntelliZone 2 zones, each as its own climate entity with individual temps, setpoints, modes, and fan modes. Zone 1 auto-detects whether it’s running as a standalone thermostat or through IZ2.
  • Hardware auto-detection: AXB accessory board, VS Drive (5/7-Series), IZ2 controller, blower type, energy monitor level, and pump type are all detected automatically at startup. Manual YAML overrides available if needed.
  • Adaptive 3-tier polling: Fast (5s) for temperatures and compressor state, medium (~30s) for equipment config and blower speeds, slow (~5min) for fault history. Keeps RS-485 bus load reasonable.
  • Non-blocking async Modbus: Replaced the original blocking I/O with an async state machine (IDLE → WAITING_RESPONSE → ERROR_BACKOFF), so the ESP32 never stalls waiting for a reply.
  • Humidifier/Dehumidifier mode selects: Auto or Manual for each so climate humidistat controls are seamless
I just stumbled upon this thread as I was search information on troubleshooting my newly configured aurora_mqtt_bridge solution.
I very recently replaced my dead E-Series Geothermal unit with a spanking new GeoSmart PremiumG unit (model S5AV036BD1A12CTR5B00), which is not on the list of supported unit for the “waterfurnace_aurora” project although it’s essentially a WF Series 5. I am able to retreive some sensor data.
But I have missing sensors values:
  • Compressor Heating Liquid Line Temperature
  • Compressor Saturated Condensor Discharge Temperature
  • Heat Pump Entering Water Temperature
  • Heat Pump Leaving Air Temperature
  • Heat Pump Leaving Water Temperatures
All 5 sensors report a value of -999.9 (°F, which converts roughly to -573,3 °C).
I feel there are missing data points as well as when the technician came by and plugged in is AID tool, he could see a list of thermostat signal wires states. I’m running on a Ecobee so I’m using standard HVAC/Furnace wiring. In his AID tool, he could see which signal wire was at what state. He also had a couple of other temperature values not currently reported by ‘waterfunace_aurora’.
My question is the following: Does the ESPHome solution would provide better support for my unit than the ruby-based solution?
Are there there benefits (other than power consumption) to using the ESPHome-based solution over Ccutrer’s ruby-based one?
Thanks.
To answer your direct question first: both solutions read the same Modbus registers from the Aurora ABC board, so the ESPHome component wouldn’t automagically fix the missing sensor values. The -999.9 sentinel values you’re seeing mean the ABC board itself is returning “no data” for those register addresses. That’s the same whether you’re using ccutrer’s Ruby bridge or the WaterFurnace Aurora ESPHome component.
The motivation behind the ESPHome port is more about the platform than the protocol. If you’ve already got a Pi running the Ruby bridge and it’s doing what you need, there’s nothing wrong with sticking with it. It’s really personal preference. For me, where I can, I’d rather have a $5 ESP32 on the wall than another full Linux install I have to maintain, patch, and keep an eye on. And practically speaking, I find SD cards tend to wear out over some number of years, whereas the ESP devices just tick along in the background indefinitely.
So the benefits are down to smaller footprint, zero OS maintenance, native ESPHome/HA integration (entities just appear), and long-term reliability. But if your Pi setup works for you, no pressure to switch.
Now, the more interesting problem: your missing sensors. The registers returning -999.9 are:
  • Heating Liquid Line Temp (register 1109) - AXB board
  • Saturated Condenser Discharge Temp (register 1134) - AXB board
  • Entering Water Temp (register 1111) - AXB board
  • Leaving Water Temp (register 1110) - AXB board
  • Leaving Air Temp (register 900) - main ABC board
Most of these are AXB (accessory board) registers. The -999.9 sentinel means the board is reporting “I don’t have this data” at those addresses. It’s possible the GeoSmart PremiumG maps some of these to different register addresses, or that your unit has a slightly different AXB configuration.
Since your technician’s AID tool can see those temperatures, the data is definitely on the bus. It’s just likely at different addresses than what the standard WaterFurnace register map uses.
I’m happy to add GeoSmart register support if we can figure out the register map for your unit. To do that, we’d need to capture the actual Modbus traffic. Here are a couple of approaches:
  1. Sniff the AID tool traffic - If you can get the technician to come back (or you have access to an AID tool), you could tap the RS-485 bus with a USB-to-RS485 adapter (FTDI or CH340-based, ~$5-10) while the AID tool is connected. Run a Modbus sniffer/logger (something like mbpoll in listen mode, or even just a serial terminal logging raw hex at 19200 baud, 8N1) to capture the requests the AID tool sends and the responses it gets back. That’ll tell us exactly which register addresses hold the data your unit reports.
  2. Register scan/dump - Alternatively, you could do a brute-force scan of register ranges using a simple script over RS-485. Read registers in blocks across the known address ranges (0-1200, 3000-4000) and look for values that aren’t 0x0000 or the -999.9 sentinel (0xD8F1). Comparing those against the known register map would reveal any GeoSmart-specific addresses. I can help put together a script for this if you’re interested.
If you can capture either a traffic dump or a register scan, open an issue on the GitHub repo and we can work through it together. The component is designed to be model-agnostic (it detects hardware features like VS drive, AXB, IZ2 automatically), so adding support for different register mappings is straightforward once we know what they are.
I'd been dragging my feet on the pi/mqtt implementation for my 5 Series, so I was ecstatic to see this option.
I went with the espforge/esphome-waterfurnace implementation, waveshare esp32, and a ac/dc step down converter from my stalled attempt. I beheaded a spare cat5 cable and ran it all off the AID tool port on the AWL hardware. Next will be to build a clean enclosure for it, with just the one Ethernet cable running to it.
I made this dashboard with a ton of info. So much more than the Symphony integration and with better control.
@daemonp getting ready to implement this on a 5 series. I have a honeywell wifi thermostat and a shelly temp humidity sensor, and going to add a esp floor temp sensor. does this require the waterfurnace thermostat to function? thanks
@jamezz42 Short answer: No, the original WaterFurnace communicating thermostat is not required. Your Honeywell WiFi thermostat + WaterFurnace Aurora for ESPHome is a valid setup.
A few specifics for your 5-series:
How the pieces fit together
  • Your Honeywell thermostat connects to the ABC board's 24VAC terminals and handles the basic "call for heat/cool" signals.
  • The ESPHome component connects to the AID port's RS-485 pins (1–4) and talks Modbus directly to the ABC board. These are completely independent paths.
  • Your Shelly temp/humidity sensor and planned ESP floor sensor can feed Home Assistant for dashboard/automation data.
What you'll get
  • Full monitoring: compressor speed, loop temps, pressures, COP, fault codes, energy data — all the 5-series VS drive diagnostics work regardless of thermostat type.
  • Advanced controls: DHW, ECM blower speeds, VS pump speeds, humidity targets — these write directly to ABC registers and don't depend on the communicating thermostat.
  • The ESPHome climate entity can set mode/setpoints via Modbus, though if your Honeywell is also actively calling for heat/cool via 24V AC, the two control paths can step on each other. Most people either let the Honeywell handle basic control and use ESPHome for monitoring, or switch the Honeywell to a "dumb" schedule and let HA drive setpoints through the ESPHome climate card.
What you'll miss without the WaterFurnace communicating thermostat
  • outdoor_temperature (register 742) — this reading comes from the AWL thermostat and is suppressed when not present. Your Shelly/ESP sensors can fill this gap in HA.
  • humidity (register 741) — same story. Your Shelly has you covered.
  • ambient_temperature from the ABC board may not reflect true room temp without the communicating thermostat's sensor. Again, your external sensors handle this for HA.
I haven't personally run without any 24VAC thermostat (just Modbus control), but with your Honeywell providing the basic control signals, this should work well. The component auto-detects 5-series VS drive at startup and polls the right registers.
If you run into any issues you feel free to open a github issue
Thanks so much, i got the esp to pull data from the unit last night! The installer used the honeywell to talk to a third party eco controller from eagle mountain, but i think running the whole thing with some esp sensors and realay will be much better. The installer also refused to cool the floor and only set it up for the fancoil units because they were afraid of condensation, which should be easily mitigated with a floor temp sensor and an algorithem to calculate dew point which could just shut off the pump to the floor when it approaches the dewpoint temp. anyway, if you could point me at some information on how to set up the heat and cooling calls through the modbus i would be eternally greatful and it will save me a few relays. :heart_eyes:
Thanks for creating this, it seems like a great solution since I’ve been struggling with how to best manage my existing RPI setup in the long term.
I have 2 WF units next to each other servicing different levels in my home. One is a Series 7 with 2x IZ2 zones. The other is a series 5 split system with a 2 stage compressor and an ECM blower (single zone).
Would it be possible to use 2 of the RS485 adapters and connect both WF systems to a single ESP32?
Hey @OleSam85,
Thanks for the kind words, glad it's useful!
Yes, running two WaterFurnace units on one ESP32 should work. Multiple waterfurnace_aurora: hubs are allowed. Each instance runs independently with its own UART bus and RS-485 adapter.
What you’ll need:
  • ESP32 with enough free GPIOs (avoid strapping pins GPIO0/2/5/12/15 and flash pins GPIO6-11).
  • Two separate RS-485 adapters (with DE/RE flow-control pins).
  • Two separate buses (keep each RS-485 bus short and do not tie the buses together) this way both units can use the same Modbus address (1) since they’re on physically separate networks.
  • Recommended: get one unit fully working first, then add the second.
Here’s a starter config (adapt names and pins to your setup):
esphome:
esp32:
  board: esp32dev
# Pull the component source, but DO NOT use the monolith "packages:" import
external_components:
  - source:
      type: git
      url: https://github.com/daemonp/esphome_waterfurnace_aurora
      ref: master
    components: [ waterfurnace_aurora ]
# Two separate RS-485 adapters
uart:
  - id: uart_series7
    tx_pin: GPIO17
    rx_pin: GPIO16
    baud_rate: 19200
    parity: EVEN
    stop_bits: 1
  - id: uart_series5
    tx_pin: GPIO19
    rx_pin: GPIO18
    baud_rate: 19200
    parity: EVEN
    stop_bits: 1
# Define the two separate hubs
  - id: aurora_series7
    uart_id: uart_series7
    address: 1
    update_interval: 10s
    flow_control_pin: GPIO20
    connected:
      name: "Series 7 Connected"
  - id: aurora_series5
    uart_id: uart_series5
    address: 1
    flow_control_pin: GPIO21
    connected:
      name: "Series 5 Connected"
# Climate Controls
climate:
  # Series 7 with IZ2 zones
    aurora_id: aurora_series7
    zone: 1
    zone: 2
  # Series 5
    aurora_id: aurora_series5
# MANUAL SENSOR DEFINITIONS
# (Copy the ones you need from waterfurnace_aurora.yaml and
# duplicate them for each unit, ensuring you update the aurora_id)
  # --- Series 7 Sensors ---
    entering_water_temperature:
      name: "Series 7 Entering Water Temperature"
    leaving_water_temperature:
      name: "Series 7 Leaving Water Temperature"
    total_watts:
      name: "Series 7 Total Power"
  # --- Series 5 Sensors ---
      name: "Series 5 Entering Water Temperature"
      name: "Series 5 Leaving Water Temperature"
    total_watts:
      name: "Series 5 Total Power"
binary_sensor:
  # --- Series 7 ---
    compressor_running:
      name: "Series 7 Compressor Running"
  # --- Series 5 ---
    compressor_running:
      name: "Series 5 Compressor Running"
The component will auto-detect the hardware differences on each unit (IZ2 zones on the Series 7, 2-stage compressor + ECM blower on the Series 5, etc.). You can add sensors, binary sensors, numbers, etc. by referencing the aurora_id you've defined (the connected: binary sensors will be handy for monitoring each bus).
Note: two full instances will use more memory, but the ESP32 should handle it comfortably.
Let me know how it goes, or open a GitHub issue if you hit any snags, happy to help debug!
Hey @jamezz42,
First off, huge apologies for the delay! Your plan for the radiant floor cooling is clever. I'm just starting to think about how to lay pipes to do radiant heating and cooling in my basement.
To answer your question directly: you are still going to need physical relays. Here is a quick breakdown of why based on the Aurora protocol:
  • Physical inputs are required: The ABC board expects standard heating/cooling demands exclusively as physical 24VAC signals on terminals Y1, Y2, O, G, and W. We can read their status over Modbus (Register 31), but the protocol provides no write access.
  • The Communicating Thermostat catch: The board can use data-bus calls, but only if it's talking to a WaterFurnace Communicating Thermostat that provides the ambient room temperature. Our component acts as an AWL/Symphony gateway (we can change setpoints and modes, but we can't spoof room temp, so we can't act as the sole thermostat).
  • Manual Mode is for testing only: manual_operation (register 3002) in the code. Please don't use this for daily driving! It's a commissioning mode that forces the compressor on and bypasses crucial safeties.
The Recommended Setup
To loose the Honeywell/Eagle Mountain controller:
  1. Relays for Control: Wire a standard ESP relay board (or discrete relays) directly to the Aurora's physical Y1/Y2/O/G/W terminals.
  2. Home Assistant for Logic: Drive the relays from HA using the generic thermostat or PID integration, feeding it your custom floor, room, and dew-point sensors.
  3. Modbus for Diagnostics: Keep this component running alongside it for deep monitoring (EEV position, loop pressures, power draw, approach temps) to ensure your custom relay logic is running the equipment perfectly.
I'm going a bit insane trying to troubleshoot a weird comms problem I'm seeing.
I've tried both the daemonp variant, and the espforge variant, and the results are similar.
Waterfurnace 5 with the Desuper Heater (which may or may not be what's referred to as "Domestic Hot Water"). I've had this running off the original Cody Cultrer code on a Pi Mini and RS485->USB converter for years. But I wanted to try to get the ESP32 option running.
Got one of the Waveshare units referenced by espforge for simplicity. Wiring is all correct (since it's working on the other hardware).
Espforge's site points to a web installer which does the ESPHome install with espforge's binary. End option is to connect that to HA, and indeed it shows up in HA under the ESPHome Integration, and in ESPHome Builder. If I run it now, it works! All seems well and I'm pulling data.
If I now go to the ESPHome Builder page, edit the device (basically default preamble yaml), CHANGE NOTHING and just Install, I get nothing but CRC errors and timeouts on the RS485 comms. Totally refuses to work.
It's almost as though the version compiled on my HA box, despite apparently pointing to the same original source, is breaking something. But I'll be darned if I can figure out what.
Has anybody done this on a recent HA version (I'm on 2026.6.3)?
I am a little confused about controls. I can see all the system data andadjust the fan speed though the ESPHome web interface at the device IP address, but not through HA. The only climate entity I see is called "variable speed" and it is set to "Off" although the HVAC is actively cooling.
I have WF7 with AWL 3.6 running 3 zones:
Tstat: v0.00, AXB: yes (v2.01), VS: yes, IZ2: yes (v2.06, 3 zones), Blower: ECM, Pump: VS Pump + 26-99, Energy: 2, Hum: yes, Dehum: no
Shouldn't I see one control per zone? Or am I completely misunderstanding how the controls on this component work?
This seems like the same issue I’ve seen after a power failure. I opened this issue on github. Are you still seeing the issue?
I reverted to my old rPi-based monitor for now, and took the ESPHome component offline. I check the github every now and then for any new releases, and if I see something that looks promising I’ll try again.
