Hi all,
I am having an issue with getting a automation to work in esphome.
The gist of what I am is doing is automated stair lighting. I have the lights working as i want but I am struggling with one aspect.
I want the lights to come on top to bottom when the top sensor is activated then go off top to bottom when the bottom sensor is activated and vice versa.
Now I achieved this with out issue but what I also want is if the top sensor is activated then activated again before the bottom sensor the lights go off bottom to top, and this is where I am struggling.
The code I have that works is:
light:
- platform: fastled_clockless
chipset: WS2812B
pin: D7
num_leds: 70
rgb_order: GRB
effects:
- addressable_color_wipe:
name: Color Wipe Up On
colors:
red: 100%
green: 100%
blue: 100%
num_leds: 1
add_led_interval: 15ms
name: Color Wipe Up Off
colors:
- red: 0%
green: 0%
blue: 0%
num_leds: 1
name: Color Wipe Down On
colors:
red: 100%
green: 100%
blue: 100%
num_leds: 1
reverse: true
name: Color Wipe Down Off
colors:
- red: 0%
green: 0%
blue: 0%
num_leds: 1
reverse: true
binary_sensor:
- platform: gpio
pin:
number: D1
mode: INPUT_PULLUP
filters:
- invert
on_press:
if:
condition:
- light.is_off: strip
then:
- light.turn_on:
effect: color wipe down on
- wait_until:
binary_sensor.is_on: strip_sensor_up
- light.turn_on:
effect: color wipe down off
- light.turn_off: strip
- platform: gpio
pin:
number: D2
mode: INPUT_PULLUP
filters:
- invert
on_press:
if:
condition:
then:
- light.turn_on:
effect: color wipe up on
- wait_until:
- light.turn_on:
effect: color wipe up off
The code that doesn’t work is
- platform: gpio
pin:
number: D2
mode: INPUT_PULLUP
filters:
- invert
on_press:
if:
condition:
then:
- light.turn_on:
- delay: 3s
- if:
condition:
then:
- light.turn_on:
- delay: 10s
- if:
condition:
binary_sensor.is_on: strip_sensor_down
then:
- light.turn_on:
- delay: 10s
If i have hold the binary sensors on within the 3s delay it behaves as I want, but if they are pressed after the 3s delay nothing happens.
Hopefully you understand what I am trying to do.
Any help appreciated
