I have a ESP32c3 board with 2 miflora sensors…
is this config correct? I am asking because sometime i dont have a connection to the board
esphome:
platformio_options:
board_build.f_flash: 40000000L
board_build.flash_mode: dio
board_build.flash_size: 4MB
#esp32:
# board: az-delivery-devkit-v4
# framework:
# type: arduino
esp32:
variant: ESP32C3
board: esp32-c3-devkitm-1
framework:
type: esp-idf
wifi:
ssid: "xxxx"
password: "xxxx"
ap:
ssid: "Florasensordevice"
password: "xoXHVuz3fLJh"
captive_portal:
web_server:
port: 80
mqtt:
broker: "xxxxx"
port: 1883
username: "xxx"
password: "xxx"
discovery: false
will_message:
topic: florasensordevice/status
payload: "offline"
birth_message:
payload: "online"
logger:
api:
ota:
esp32_ble_tracker:
- platform: xiaomi_hhccjcy01
mac_address: "xxxxxxx" # Replace with your sensor's MAC address
temperature:
name: "MiFlora1 Temperature"
moisture:
name: "MiFlora1 Moisture"
illuminance:
name: "MiFlora1 Illuminance"
conductivity:
name: "MiFlora1 Soil Conductivity"
battery_level:
name: "MiFlora1 Battery Level"
mac_address: "xxxxxx" # Replace with your sensor's MAC address
temperature:
name: "MiFlora2 Temperature"
moisture:
name: "MiFlora2 Moisture"
illuminance:
name: "MiFlora2 Illuminance"
conductivity:
name: "MiFlora2 Soil Conductivity"
battery_level:
name: "MiFlora2 Battery Level"
interval:
- interval: 5min
then:
- mqtt.publish:
topic: "florasensordevice/sensor1/temperature"
payload: !lambda |-
return to_string(id(miflora1_temperature).state);
- mqtt.publish:
topic: "florasensordevice/sensor1/moisture"
payload: !lambda |-
return to_string(id(miflora1_moisture).state);
- mqtt.publish:
topic: "florasensordevice/sensor1/illuminance"
payload: !lambda |-
return to_string(id(miflora1_illuminance).state);
- mqtt.publish:
topic: "florasensordevice/sensor1/conductivity"
payload: !lambda |-
return to_string(id(miflora1_conductivity).state);
- mqtt.publish:
topic: "florasensordevice/sensor1/battery"
payload: !lambda |-
return to_string(id(miflora1_battery).state);
- mqtt.publish:
topic: "florasensordevice/sensor2/temperature"
payload: !lambda |-
return to_string(id(miflora2_temperature).state);
- mqtt.publish:
topic: "florasensordevice/sensor2/moisture"
payload: !lambda |-
return to_string(id(miflora2_moisture).state);
- mqtt.publish:
topic: "florasensordevice/sensor2/illuminance"
payload: !lambda |-
return to_string(id(miflora2_illuminance).state);
- mqtt.publish:
topic: "florasensordevice/sensor2/conductivity"
payload: !lambda |-
return to_string(id(miflora2_conductivity).state);
- mqtt.publish:
topic: "florasensordevice/sensor2/battery"
payload: !lambda |-
return to_string(id(miflora2_battery).state);
