ESPHOME configuration for AEM1000 (Environmental monitoring box from ASAIR)
Has anyone came across AEM1000 (Environmental monitoring box from ASAIR)? This is basically a environmental monitoring box capable of sensing temperature, humidity, VOC, CO2 and PM2.5. The datasheet states communication through RS485/UART based on standard Modbus RTU. However, the direct UART is not available buy default I think. So, I tried to connect through RS485 transceiver module following esphome Modbus controller guide. But was not able to make it work. Is there any thing I am missing? Any help is greatly appreciated. Below is my current configuration.
# Substitutions variables
substitutions:
  devicename: aem1000
  friendly_name: Aem1000 Test
  device_description: "Senses Indoor Environment"
  project_version: "1.0.0"
  loglevel: DEBUG
# Board Configuration
esphome:
  friendly_name: ${friendly_name}
  min_version: 2024.7.0
  name_add_mac_suffix: true
  project:
    version: "${project_version}"
  on_boot:
      priority: 240
      then:
        - wait_until:
            condition:
              wifi.connected:
            timeout: 60s
esp8266:
  board: d1_mini
  restore_from_flash: true
  framework:
    version: recommended
# Enable logging
logger:
  level: ${loglevel} # Default logging level
  baud_rate: 0  # Disable logging over UART
api:
  reboot_timeout: 0s
  encryption:
    key: !secret api_encryption_key
wifi:
  networks:
    - ssid: !secret wifi_ssid
  # manual_ip:
    # static_ip: 192.168.0.59
    # gateway: 192.168.0.1
    # subnet: 255.255.255.0
  ap:
    ssid: "${devicename}"
# The captive portal is a fallback mechanism for when connecting to the configured WiFi fails.
# https://esphome.io/components/captive_portal.html
captive_portal:
# Allow provisioning WiFi via serial
# improv_serial:
# Allow Over-The-Air updates
ota:
  - platform: esphome
safe_mode:
  reboot_timeout: 10min
  num_attempts: 5
# To have a "next url" for improv serial
# web_server:
# RTC time update
time:
  - platform: homeassistant
button:
  - platform: restart
    name: "Restart - ${friendly_name}"
    entity_category: config
# UART configuration for AEM1000
uart:
  tx_pin: TX
  rx_pin: RX
  baud_rate: 9600
modbus:
  uart_id: uart_bus
modbus_controller:
- id: modbus_device
  address: 0x01   ## address of the Modbus slave device on the bus
  modbus_id: modbus1
  setup_priority: -10
# Sensor definitions
  - platform: modbus_controller
    modbus_controller_id: modbus_device
    register_type: read
    address: 0x0000
    value_type: U_WORD
    name: "AEM1000 Temperature"
    unit_of_measurement: "°C"
    accuracy_decimals: 1
    # filters:
    #   - lambda: |-
    #       return x * 0.1;
    register_type: read
    address: 0x0001
    value_type: U_WORD
    name: "AEM1000 Humidity"
    unit_of_measurement: "%"
    # filters:
    #   - lambda: |-
    #       return x * 0.1;
    register_type: read
    address: 0x0002
    value_type: U_WORD
    unit_of_measurement: "ppm"
    register_type: read
    address: 0x0003
    value_type: U_WORD
    register_type: read
    address: 0x0004
    value_type: U_WORD
    unit_of_measurement: "µg/m³"
Can you post the modbus protocol (addresses) of that device.
As per the the datasheet (link) it is 0x01 and the Modbus RTU communication register definition are
Ok.
Register_type is wrong, should be holding.
If that doesn’t resolve, post your wiring scheme.
If you have Esp32 devboard available , you reduce odds by 90%
I tried with holding but with no success. Here is my wiring is it okay?
aem1000 RS485B ->> RS485 to TTL board B-
aem1000 RS485A ->> RS485 to TTL board A+
aem1000 5V ->> D1 Mini 5V
aem1000 GND ->> D1 Mini GND
RS485 to TTL board RXD ->> D1 Mini TX
RS485 to TTL board TXD ->> D1 Mini RX
RS485 to TTL board VCC ->> D1 Mini 3V3
RS485 to TTL board GND ->> D1 Mini GND
Register_type: holding is the correct one.
In case your rs485 converter has automatic flow control (no DE/RE pins), wiring sounds correct .
Anyway, many D1 mini boards don’t have Uart working on pins Gpio1 and 3.
Uart can be mapped to tx_pin: GPIO15 and rx_pin: GPIO13 but if that rs485-module has pullups on data pins, your Esp goes to wrong boot mode at startup. Try.
Then only option is to use softwareserial through general pins like GPIO4 and 5. At baudrate 9600 it should work anyway.
Do you have long wiring?
Try also with termination resistor set with jumper P5. Rs485 standard calls termination resistor on both ends but for short distances it’s often not needed.
For my experience, half of the issues on modbus communication are coming from flimsy wiring. Make sure all wires are good and connections are solid.
What is your output in log?
