Goal: more intelligent awake time.
When all MQTT data has been published, do something (in this case, enter deep sleep).
I have a few sensors connected to an ESP8266 D1 Mini and I’m using a basic deep sleep config to reduce the effect of self heating on the temperature sensor. I currently have run_duration
set to 1s, but I’d like to find a way to make this parameter a bit smarter.
Can somebody please help me find a way to configure the ESP to enter deep sleep as soon as all sensors have returned data and reported to the MQTT broker, OR, the ESP times out after having been awake for 1 second (run_duration
)? I’m not experienced with Lambda functions, but I assume that and a script is what will be needed. Although, a YAML approach would be far easier and preferred.
My code:
# Define variables
substitutions:
# Device Properties
devicename: dev-air-quality
friendly_name: Dev-Air-Quality
device_topic: AirQuality
device_sleephelper_topic: admin/esphome_disable_deep_sleep
# Sleep Properties
sleep_time: 2min
run_time: 1s
# The sensor will report data on boot, and then again for each sensor on their independent update_interval parameters until put to sleep again.
# Set update interval to a longer time than run_time to ensure only 1 data update per wake.
# I suspect that the update interval still has to be shorter than sleep time though. Otherwise, the device seems to wake up and not publish.
global_update_interval: $sleep_time
# Pinout
# Wake D0 # GPIO16 - Wake (deep sleep) - high at boot.
pin_i2c_scl: D1 # GPIO5
pin_i2c_sda: D2 # GPIO4
# Reserved D3 # GPIO0 - biased high - connected to flash button
# Reserved D4 # GPIO2 - biased high - connected to on-board LED
pin_rx: D5 # GPIO14
pin_tx: D6 # GPIO12
pin_dht: D7 # GPIO13
# D8 # GPIO15 - biased low
# RX # GPIO3
# TX # GPIO1 - debug output at boot
# A0 # ADC0
# Define Device
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Over-The-Air flashing
ota:
#safe_mode: True
password: !secret ota_password
# Power
deep_sleep:
sleep_duration: $sleep_time
run_duration: $run_time
# Wireless Access
wifi:
power_save_mode: LIGHT #There are other options. Just checking if this helps with self heating.
fast_connect: true # Skip wifi scan to save time.
ssid: !secret wifi_ssid
# Set a static IP address.
manual_ip:
static_ip: 192.168.86.200
gateway: 192.168.86.1
subnet: 255.255.255.0
# If changing the name or the IP address of the device, this provides the old address so that ESPHome knows which device to overwrite.
use_address: "192.168.86.200"
# Home Assistant Connection
# Enable MQTT
mqtt:
broker: !secret mqtt_broker
port: !secret mqtt_port
username: !secret mqtt_user
password: !secret mqtt_password
discovery: true
discovery_retain: true
# Set empty birth and will messages to avoid showing unavailable during sleep
birth_message:
will_message:
topic_prefix: $device_topic
on_message:
- topic: $device_sleephelper_topic
qos: 0 #1
payload: 'on'
then:
- deep_sleep.prevent: deep_sleep_control
qos: 0 #1
payload: 'off'
then:
- deep_sleep.enter: deep_sleep_control
# Communication Protocols
i2c:
sda: $pin_i2c_sda
scl: $pin_i2c_scl
scan: False # Save time by skipping the I2C scan on startup since all addresses are known. Defaults to True
frequency: 50kHz # Defaults to 50kHz, SCD30 can't handle more than 100kHz.
# Functionality
# Air Quality, Temperature and Humidity.
# DHT11 Temperature and Humidity Sensor
- platform: dht
model: DHT22 #DHT11
pin: $pin_dht
temperature:
name: "$friendly_name Temperature"
humidity:
name: "$friendly_name Humidity"
update_interval: $global_update_interval
# CO2, Temperature and Humidity
- platform: scd30
i2c_id: bus_i2c
address: 0x61
automatic_self_calibration: true
co2:
accuracy_decimals: 1
temperature:
name: "$friendly_name Temperature SCD"
accuracy_decimals: 2
filters:
- offset: 0
humidity:
name: "$friendly_name Humidity SCD"
#temperature_offset: 1.5 °C
# TVOC, Estimated CO2
- platform: sgp30
i2c_id: bus_i2c
address: 0x58
store_baseline: yes
eco2:
tvoc:
