ESPHOME: Connection error occurred: EOF received
Hello, my ESP cant connect, i get:
INFO ESPHome 2023.8.0b2
INFO Reading configuration /config/esphome/display.yaml...
INFO Starting log output from 192.168.1.72 using esphome API
WARNING 192.168.1.72: Connection error occurred: EOF received
WARNING Can't connect to ESPHome API for 192.168.1.72: Connection closed (APIConnectionError)
INFO Trying to connect to 192.168.1.72 in the background
my YAML:
esphome:
  friendly_name: display
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "***"
ota:
  password: "***"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Display Fallback Hotspot"
    password: "***"
  manual_ip:
    static_ip: 192.168.1.72
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    dns1: 192.168.1.1
    dns2: 8.8.4.4
captive_portal:
font:
  - file: 'fonts/Roboto-Medium.ttf'
  - file: 'fonts/Roboto-Regular.ttf'
    glyphs:
      ['0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D',
       'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R',
       'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z', ' ', 'a', 'b', 'c', 'd', 'e',
       'f', 'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's',
       't', 'u', 'v', 'w', 'x', 'y', 'z', 'å', 'ä', 'ö', 'à', 'è', 'ì', 'ò',
       'ù']
  - file: 'fonts/Roboto-Bold.ttf'
    glyphs:
      ['&', '@', '!', ',', '.', '"', '%', '(', ')', '+', '-', '_', ':', '°', '0',
       '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E',
       'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S',
       'T', 'U', 'V', 'W', 'X', 'Y', 'Z', ' ', 'a', 'b', 'c', 'd', 'e', 'f',
       'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't',
       'u', 'v', 'w', 'x', 'y', 'z','å', 'ä', 'ö', '/','º','µ','³']
    glyphs:
  - file: 'fonts/materialdesignicons-webfont.ttf'
    glyphs: [
      # Weather
      "\U000F0590", # mdi-weather-cloudy
      "\U000F0594", # mdi-weather-night
      "\U000F0591", # mdi-weather-fog
      "\U000F0592", # mdi-weather-hail
      "\U000F0593", # mdi-weather-lightning
      "\U000F067E", # mdi-weather-lightning-rainy
      "\U000F0595", # mdi-weather-partly-cloudy
      "\U000F0596", # mdi-weather-pouring
      "\U000F0597", # mdi-weather-rainy
      "\U000F0598", # mdi-weather-snowy
      "\U000F067F", # mdi-weather-snowy-rainy
      "\U000F0599", # mdi-weather-sunny
      "\U000F059B", # mdi-weather-sunset-down
      "\U000F059C", # mdi-weather-sunset-up
      "\U000F059D", # mdi-weather-windy
      "\U000F059E", # mdi-weather-windy-variant
    glyphs: [
      # Weather
    glyphs: [
      # Wifi
      "\U000F092F", # mdi-wifi-strength-outline
      "\U000F091F", # mdi-wifi-strength-1
      "\U000F0922", # mdi-wifi-strength-2
      "\U000F0925", # mdi-wifi-strength-3
      "\U000F0928", # mdi-wifi-strength-4
    glyphs: [
      # Sun
      "\U000F059A", # mdi-weather-sunset
      # Moon
      "\U000F0F64", # mdi-moon-new
      "\U000F0F67", # mdi-moon-waxing-crescent
      "\U000F0F61", # mdi-moon-first-quarter
      "\U000F0F68", # mdi-moon-waxing-gibbous
      "\U000F0F62", # mdi-moon-full
      "\U000F0F66", # mdi-moon-waning-gibbous
      "\U000F0F63", # mdi-moon-last-quarter
      "\U000F0F65", # mdi-moon-waning-crescent
      # Rooms
      "\U000F09A0", # mdi-shower
      "\U000F09A1", # mdi-shower-head
      "\U000F04B9", # mdi-sofa
      "\U000F0C99", # mdi-microwave
      "\U000F0FD1", # mdi-bed-king-outline
      "\U000F106E", # mdi-bed-single-outline
      "\U000F0322", # mdi-laptop
      "\U000F07F4", # mdi-television-classic
    glyphs: [
      "\U000F18D6", # mdi-sun-thermometer
      "\U000F1A5F", # mdi-pool-thermometer
      "\U000F0606", # mdi-pool
      "\U000F1A73", # mdi-pv
    glyphs: [
time:
  - platform: homeassistant
    timezone: Europe/Rome
    on_time:
      # Every 1 minutes
      - seconds: 0
        then:
          - component.update: epaperdisplay
    entity_id: sensor.moon
    internal: true
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
    entity_id: sensor.foxess_ambient_temperature
    entity_id: sensor.foxess_solar_power
    entity_id: sensor.wf_192_168_1_156_orp
    entity_id: sensor.wf_192_168_1_156_ph
text_sensor:
spi:
  clk_pin: 14
  mosi_pin: 13  #DIN
display:
  - platform: waveshare_epaper
    cs_pin: 15
    dc_pin: 12
    update_interval: 120s
    busy_pin: 16
    reset_pin: 4
    model: 4.20in
    lambda: |-
      /* V Linie */
      it.line(120, 0, 120, 300);
      /* H Linie */
      it.line(120, 75, 400, 75);
      it.line(0, 150, 400, 150);
      it.line(120, 225, 400, 225);
      /* Uhr */
      it.strftime(60, 40 , id(roboto_bold_35), TextAlign::BASELINE_CENTER , "%H:%M", id(homeassistant_time).now());
      /* Aussentemperatur */
      it.printf(155,55, id(display_font_50), TextAlign::BASELINE_CENTER, "\U000F18D6");
      it.printf(240,45, id(roboto_bold_27), TextAlign::BASELINE_CENTER, "%.1f°C", id(temp_aussen).state);
      /* Wassertemperatur */
      it.printf(155,130, id(display_font_50), TextAlign::BASELINE_CENTER, "\U000F1A5F");
      it.printf(240,125, id(roboto_bold_27), TextAlign::BASELINE_CENTER, "%.1f°C", id(temp_aussen).state);
      /* PH */
      it.printf(155,205, id(display_font_50), TextAlign::BASELINE_CENTER, "\U000F0606");
      it.printf(155,220, id(roboto_reg_15), TextAlign::BASELINE_CENTER, "PH");
      it.printf(240,200, id(roboto_bold_27), TextAlign::BASELINE_CENTER, "%.1f", id(pool_ph).state);
      /* ORP */
      it.printf(155,280, id(display_font_50), TextAlign::BASELINE_CENTER, "\U000F0606");
      it.printf(155,295, id(roboto_reg_15), TextAlign::BASELINE_CENTER, "ORP");
      it.printf(240,275, id(roboto_bold_27), TextAlign::BASELINE_CENTER, "%.1fmV", id(pool_orp).state);
      /* PV */
      it.printf(20,120, id(display_font_30), TextAlign::BASELINE_CENTER, "\U000F1A73");
      it.printf(75,120, id(roboto_bold_27), TextAlign::BASELINE_CENTER, "%.1fkw", id(pv_anlage).state);
      /* WIFI SIGNAL */
      if(id(wifisignal).has_state()) {
        int wifi_x = 60;
        int wifi_y = 80;
        if (id(wifisignal).state >= -50) {
          // Excellent
          it.print(wifi_x, wifi_y, id(wifi_font_30), TextAlign::BASELINE_CENTER, "\U000F0928");
          ESP_LOGI("WiFi", "Exellent");
        } else if (id(wifisignal).state  >= -60) {
          // Good
          it.print(wifi_x, wifi_y, id(wifi_font_30), TextAlign::BASELINE_CENTER, "\U000F0925");
          ESP_LOGI("WiFi", "Good");
        } else if (id(wifisignal).state  >= -75) {
          // Fair
          it.print(wifi_x, wifi_y, id(wifi_font_30), TextAlign::BASELINE_CENTER, "\U000F0922");
          ESP_LOGI("WiFi", "Fair");
        } else if (id(wifisignal).state  >= -100) {
          // Weak
          it.print(wifi_x, wifi_y, id(wifi_font_30), TextAlign::BASELINE_CENTER, "\U000F091F");
          ESP_LOGI("WiFi", "Weak");
        } else {
          // Unlikely working signal
          it.print(wifi_x, wifi_y, id(wifi_font_30), TextAlign::BASELINE_CENTER, "\U000F092F");
          ESP_LOGI("WiFi", "Unlikely");
Network issues interrupted the transfer.
Could also be that the ESP is crashing (low memory? memory access violation). It’s happened so me when I put stupid code in my sketches haha.
I have the same error
Logger: aioesphomeapi.connection
Source: runner.py:186
First occurred: 09:52:25 (29 occurrences)
Last logged: 13:09:48
plafond-slaapkamer @ 192.168.180.136: Connection error occurred: plafond-slaapkamer @ 192.168.180.136: EOF received
bulb-kamer-voor @ 192.168.180.173: Connection error occurred: bulb-kamer-voor @ 192.168.180.173: EOF received
bulb-kamer-achter @ 192.168.180.137: Connection error occurred: bulb-kamer-achter @ 192.168.180.137: EOF received
s0tool-watermeter @ 192.168.180.220: Connection error occurred: s0tool-watermeter @ 192.168.180.220: EOF received
but from what I check it’s related to the esphome connection with HA.
3 of these devices are LibreTiny(beta) devices, and there is a really long delay when I change the light status in HA. while using the webinterface the acction always is instant. If it was a network issue I would assume the webinterface also to have issues but it doesn’t.
The last device is a watermeter which I updated most recently.
It could still be network, but would that explain why the webinterface shows no issues?
Out of RAM crashes in the ESP often causes these issues. Webinterface consumes a ton of memory in the ESP.
Attach a serial console and watch the logs. Correlate the disconnect you see in HA with what is displayed on the serial console at the time. If you don’t get anything useful increase the logger: level to VERY_VERBOSE and try again
