[ESPHome] Control iPod through 30pin Connector & Serial Commands
Video
I’ve been sitting on this project for a while. I had the basic commands (play / pause / next / previous / vol + / vol - ) complete for about 3 years. I had previously purchased the ipod breakout board in 2018 :sweat_smile:
With the help of some folks on Discord, I was finally able to push this project over the finish line. I had a major breakthrough with the serial commands.
There were a lot of legacy resources to sift through on the Wayback Machine along the way. A lot of these resources from iPod Linux, Make Magazine, and the arduino forums were from 2004 - 2011 – most of these websites aren’t functional anymore due to redesigns.
I had also made the ESPHome based iPod Dock IR Remote. It’s useful but different. With this you can scroll through playlists and in theory automate selecting different playlists. I’m sure someone will think of something cool!
Hardware:
Please note: while doing the research a while ago, I learned that using an ESP32 instead of ESP8266 was necessary due to the ESP32 being better at issuing the serial commands at a higher baud rate. I haven’t tried it since, let me know if you find otherwise.
Connecting it up:
ESP32 connection iPod 30 pin Breakout Board
Ground jumper wire Pin 15
RX2 [GPIO16] jumper wire Pin 10
TX2 [GPIO17] jumper wire Pin 13
x 500k ohm Resistor Pin 11 to Pin 21 with resistor in between
Between Pin 11 and Pin 21 on the iPod breakout board, you need to add one 500k ohm resistor.
Baud Rate:
19200
ESPHome YAML:
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
wifi:
  ssid: 'name'
  password: 'password'
api:
# Enable logging
logger:
ota:
uart:
  tx_pin: GPIO17
  rx_pin: GPIO16
  baud_rate: 19200
switch:
  - platform: uart
    name: "iPod Play/Pause Toggle"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x01, 0xFA, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB] # from https://git.cbps.xyz/yuno/Open_Dock/src/branch/wifi-control/main.py
  - platform: uart
    name: "iPod Volume Up"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x02, 0xF9, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB] # from https://git.cbps.xyz/yuno/Open_Dock/src/branch/master/opendock.py
  - platform: uart
    name: "iPod Volume Down"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x04, 0xF7, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB] # from https://git.cbps.xyz/yuno/Open_Dock/src/branch/master/opendock.py
  - platform: uart
    name: "iPod Next Track"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x08, 0xF3, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB] # from https://git.cbps.xyz/yuno/Open_Dock/src/branch/master/opendock.py
  - platform: uart
    name: "iPod Prev Track"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x10, 0xEB, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB] # from https://git.cbps.xyz/yuno/Open_Dock/src/branch/master/opendock.py
#### not working now
  - platform: uart
    name: "iPod - Turn Off"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x02, 0x00, 0x00, 0x00, 0x04, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB]
  - platform: uart
    name: "iPod - Turn On"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x02, 0x00, 0x00, 0x00, 0x08, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB]
# iPod Navigation Control
  - platform: uart
    name: "iPod Menu Button"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x5, 0x02, 0x00, 0x00, 0x00, 0x40, 0xB9, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB]
  - platform: uart
    name: "iPod Select Button"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x5, 0x02, 0x00, 0x00, 0x00, 0x80, 0x79, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB]
  - platform: uart
    name: "iPod Scroll Up"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x6, 0x02, 0x00, 0x00, 0x00, 0x00, 0x01, 0xF7, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB]
  - platform: uart
    name: "iPod Scroll Down"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x02, 0xFA, 0xFF, 0x55, 0x6, 0x02, 0x00, 0x00, 0x00, 0x00, 0x02, 0xF6, 0xFF, 0x55, 0x03, 0x02, 0x00, 0x00, 0xFB]
## voice recording ... only supported on certain iPods
  - platform: uart
    name: "iPod Voice Record 1"
    data: [0xFF, 0x55, 0x03, 0x00, 0x01, 0x01, 0xFB]
  - platform: uart
    name: "iPod Voice Record 2"
Next Steps:
  • Design and 3D print a dock
  • add a camera on top of it to view the screen remotely
  • design a great Home Assistant dashboard interface
  • There is an Advanced iPod Remote – like when you plug an iPod into a car and you can control it from a car stereo headunit. That is an interesting next step because you can pull all the data from the device to see what playlists are available or the currently playing song and pass the data into Home Assistant. It’d be cool to see this as a Media Player source in HA.
    • Also In theory you could recreate the iPod interface
Inspiration & Research Sources:
https://finsprings.org/iPodSerial.pdf
Hi, Thanks for doing this!
I was just wondering whether this solution works on all 30 pin iPods that are dock compatible? Have a broken dock with a fairly clean breakout board I’m looking to repurpose.
Curious about inverting it to work with other devices too but I guess the audio wouldn’t transmit back to the dock very cleanly (iirc it’s analogue audio rather than digital so it’d have to come from a headphone jack I guess)
I tried it on a 5th gen and 7th gen iPod. In theory everything 3rd gen and up should work from everything I’ve read. Let me know if you try it, happy to help you troubleshoot.
I always thought it would be cool to have an audio connection coming out of the 30 pin connector and make a 3d printed dock. Maybe add a camera looking at the screen and a user could control it remotely from the HA Dashboard.
There’s also another Advanced Mode for docking iPods (think like when you plug in an iPod to a car headunit and it shows the image on the screen but you can scroll through the songs on the stereo) - I thought it would be cool to implement that in home assistant and send back the currently playing song artist and title data onto the HA dashboard.
