Hi, my first post. I am really out of ideas…
The actual relay remains in the position I manually toggled it to from the HA dashboard but visually the toggle will switch to off after several minutes. If the relay had been turned off manually in the HA dashboard it will remain visually off and no off triggers will be shown in the HA or ESP logs.
I have no automations or any scripts running.
In the ESPhome logs I receive the following message a few minutes after I toggle on the relay:
[19:55:20][D][switch:037]: 'enable load test mode': Sending state OFF
In the home assistant switch logs it simply says:
Turned off
this is the part of the ESPhome config:
uart:
rx_pin: 17
tx_pin: 16
baud_rate: 9600
stop_bits: 1
modbus:
send_wait_time: 200ms
uart_id: mod_uart
modbus_controller:
- id: mod_con
address: 2
modbus_id: mod_bus
# command_throttle: 100ms
# setup_priority: -10
# update_interval: 300s
switch:
- platform: modbus_controller
# use_write_multiple: False
modbus_controller_id: mod_con
register_type: coil
address: 2
name: "enable load test mode"
# bitmask: 1
# force_new_range: true
- platform: sdm_meter
address: 0x2
phase_a:
current:
voltage:
active_power:
power_factor:
name: "SDM220M Power Factor"
apparent_power:
name: "SDM220M Apparent Power"
reactive_power:
name: "SDM220M Reactive Power"
phase_angle:
name: "SDM220M Phase Angle"
frequency:
name: "SDM220M Frequency"
total_power:
name: "SDM220M Total Power"
import_active_energy:
name: "SDM220M Import Active Energy"
export_active_energy:
name: "SDM220M Export Active Energy"
import_reactive_energy:
name: "SDM220M Import Reactive Energy"
export_reactive_energy:
name: "SDM220M Export Reactive Energy"
update_interval: 2000s
