EspHome Controlling fan using potenziometer and automations or lambdas
Hi to all sirs,
my name is Emilio and I am new to HASS and EspHome.
I am trying to control a fan using a potentiometer as input to ESP32. I am making test to undestund…
  • I declared a LEDC output component to drive with a PWM signal a MOSFET that feed a DC fan.
    I can now control the fan inside Home assistant moving the fan control slider.
  • I have also connected a potentiometer to one analog input of the ESP32 and i can read the voltage.
  • Now my next step is to take the values caming from the potentiometer (0-3.3 Volts) multiply these values for 30.3 in order to have a 0-100 range and feed the ledc output in order to control the fan turning manually the potentiometer.
    I understood it can be done using automation or lambda, but i cannot undestund how…
  • the automation is to be done inside the analog component (that controls the output) or inside the output that receive the values from the analog component. ???..
    Can someoe give me a very simple example abot this ?
    Thank you so much,
    Emilio.
My actual code (not working…)
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "tester Fallback Hotspot"
    password: "xxxxxxxxxx"
captive_portal:
# Web server
web_server:
  port: 80
# Status led
status_led:
  pin:
    number: GPIO13
    inverted: yes
# One Wire devices
dallas:
  - pin: GPIO27
    update_interval: 1s
# Sensori
  - platform: dallas
    address: 0x02051691e093ff28
  - platform: dallas
    address: 0xb405168640fbff28
  - platform: dht
    pin: GPIO26
    temperature:
    humidity:
    update_interval: 1s
  # Analog IN
  - platform: adc
    pin: GPIO34
    attenuation: auto
    update_interval: 1s
    on_value_range:
      - above: 0.0
        then:
        - output.set_level:
            level: !lambda |-
              return(id(pot).value;)
# PWM Output
output:
  - platform: ledc
    pin: GPIO33
    frequency: 4882
    inverted: true
  - platform: ledc
    pin: GPIO32
    frequency: 4882
    inverted: true
  - platform: ledc
    pin: GPIO25
    frequency: 4882
    inverted: true
# FAN
fan:
  - platform: speed
    output: pwm_peltier
  - platform: speed
    output: pwm_fan_hot
  - platform: speed
    output: pwm_fan_cold
        - output.set_level:
            level: !lambda |-
              return(id(pot).value * 33 | float(0);) # or * 100 - see below
Depending on your platform your ADC may return the voltage (between or-3.3) or a value between 0 and 1.
If you haven’t confirmed what yours does then read the note in the ADC sensor for more info
Actually - set level in lambda can accept a value in the range 0-1 as a float - so something more like:
    on_value_range:
      - above: 0.0
        then:
          id(pwm_peltier).set_level(id(pot).value);
Also you are only setting the speed on a value above zero, does this mean you never want it to stop?
Hi to all and thank you for your answers,
I tried the two modifications but i had no good results.
I also commented the lines about the fan settings in order to not interfere with the control by potentiometer, but again the output is not modified by the potentiometer.
The values the potentiometer reports are float number from 0.00 to 3.15 Volt.
I tried this code but the output stays off:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
wifi:
  ap:
    ssid: "sun-water Fallback Hotspot"
    password: "xxxxxxxx"
captive_portal:
# Web server
web_server:
  port: 80
# Status led
status_led:
  pin:
    number: GPIO13
    inverted: yes
# One Wire devices
dallas:
  - pin: GPIO27
    update_interval: 1s
# Sensori
  - platform: dallas
  - platform: dallas
  - platform: dht
    pin: GPIO26
    temperature:
    humidity:
    update_interval: 1s
  # Analog IN
  - platform: adc
    pin: GPIO34
    attenuation: auto
    update_interval: 1s
    on_value_range:
      - above: 0.0
        then:
        - output.set_level:
            level: !lambda |-
              return(id(pot).state * 0.317);
# PWM Output
output:
  - platform: ledc
    pin: GPIO33
    frequency: 4882
    inverted: true
  - platform: ledc
    pin: GPIO32
    frequency: 4882
    inverted: true
  - platform: ledc
    pin: GPIO25
    frequency: 4882
    inverted: true
# FAN
fan:
  # - platform: speed
  #   output: pwm_peltier
  #   name: "Peltier"
  #   id: peltier
  - platform: speed
    output: pwm_fan_hot
  - platform: speed
I have to use “state” instead of “value” for ADC readings
