Esphome crashes on a Shelly Plug S
Hey there,
i want to flash a Shelly Plug S with esphome. So far so easy. I have found the followoing template and pinout: Esphome Devices - Shelly Plug S and compiled it to this easy sketch:
substitutions:
    ip: 10.0.3.33
    node_name: schlafzimmer_fernseher
esphome:
  build_path: ./build/${node_name}
  platform: ESP8266
  board: esp8285
  arduino_version: 2.4.2
wifi:
  ssid: TE-IOT
  manual_ip:
    static_ip: ${ip}
    gateway: 10.0.3.1
    subnet: 255.255.255.0
api:
  password: !secret api_password
logger:
ota:
  password: !secret ota_password
status_led:
  pin:
    number: GPIO2
    inverted: True
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      mode: INPUT_PULLUP
      inverted: True
    internal: true
    on_press:
      then:
        switch.toggle: relay
output:
  - platform: gpio
    pin: GPIO00
    inverted: true
switch:
  - platform: gpio
    pin: GPIO15
    name: "Schlafzimmer Fernseher"
    on_turn_on:
      - output.turn_on: led
    on_turn_off:
      - output.turn_off: led
and uploaded it to the Plug S without any problems. After the first reset the esp is stuck in a boot loop and just spits out a stack trace:
[15:19:36]3ffffe80: 4b873397 03b687e7 3c313d92 3516eeee
[15:19:36]3ffffe90: 3fffd848 40002364 00000007 00000000
[15:19:36]3ffffea0: 40001db4 00000078 00000000 00000010
[15:19:36]3ffffeb0: 00000000 3fffff20 3fffff20 3fffff46
[15:19:36]3ffffec0: 40002514 3fffdd3c 00000002 3fffffb0
[15:19:36]3ffffed0: 3fffefc0 00000008 00000008 00000001
[15:19:36]3ffffee0: 00000000 2843a5ac 00000000 3ffffe78
[15:19:36]3ffffef0: 00000008 40002394 0000002c ffffffff
[15:19:36]3fffff00: 3fffff20 3fffff20 00000004 4010f120
[15:19:36]3fffff10: 00000000 400042db 3fffff90 000000df
[15:19:36]3fffff20: 40004b31 00000004 0005605c 00000000
[15:19:36]3fffff30: 4010f19a 00000001 00000000 3ffffec2
[15:19:36]3fffff40: 3ffe8530 00001df8 200305e9 401000b8
[15:19:36]3fffff50: 3fffffb0 00000000 00000009 4010f51d
[15:19:36]3fffff60: de833936 ffffffff 00000000 1c05fafe
[15:19:36]3fffff70: 9eb68100 97d99d18 6fdf36c4 260657f4
[15:19:36]3fffff80: eed83624 c77a4d3b 72298e6c 99a8c426
[15:19:36]3fffff90: 2b8b2401 1c0240a6 7079cd66 a9a2e726
[15:19:36]3fffffa0: de97420b ed4cd72e 96f0202c 56c26f84
[15:19:36]<<<stack<<<
[15:19:36]
[15:19:36]--------------- CUT HERE FOR EXCEPTION DECODER ---------------
[15:19:36]
[15:19:36] ets Jan 8 2013,rst cause:2, boot mode:(3,6)
[15:19:36]
[15:19:36]load 0x4010f000, len 3584, room 16
[15:19:36]tail 0
[15:19:36]chksum 0xb0
[15:19:36]csum 0xb0
[15:19:36]v2843a5ac
[15:19:36]~ld
I already have recompiled and reflashed it but it does not change anything.
Does anyone has an idea?
