ESPHome custom Garage Door integration
Good Morning,
my Plan ist to integrate my toggle Button (up - stop - down - stop - up) operated Garage Doors into Homeassistant. For me it was essential to get two additional States:
  • opening / closing / stopped
  • Percentage of opening
My Idea was to get the opening / closing and percentage State of the Door from an encoder. State of the Encoder will be reset if Door hits Endstops to calibrate the Values on each complete cycle. The Encoder will finally be attached to the Motor shaft of the Garage Door by a toothed Belt.
First i asked a question about a new “on_stopped” trigger for Rotary Encoder integration of ESPHome on GitHub, but got helped to archivew this goal on another way. Feature Request is here.
Nagyrobi then asked me a question on how i wanted to properly combine that with a cover component - and here we are.
At first i planned to use the single entities and build a custom Card, but is there a better way to do this?
Here is the Code:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "gapzG2GR1h0OjvKWxKzDqjt0tUJoghl+a1kmTBpuVeg="
ota:
  password: "1a8050b50419c4c4e88fb2b20738e4cf"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Testdevice Fallback Hotspot"
    password: "O4Pr0bsQvYvt"
captive_portal:
output:
  - platform: gpio
    pin: 32
button:
  - platform: output
    output: output1
    duration: 500ms
binary_sensor:
  - platform: gpio
    pin:
      number: 33
      inverted: true
      mode:
        input: true
        pullup: true
    on_press:
      - sensor.rotary_encoder.set_value:
          value: 500
  - platform: gpio
    pin:
      number: 25
      inverted: true
      mode:
        input: true
        pullup: true
    on_press:
          value: 0
  - platform: rotary_encoder
    min_value: 0
    max_value: 500
    on_clockwise:
      - sensor.template.publish:
          state: 1
      - script.execute: stopped
    on_anticlockwise:
          state: -1
    pin_a:
      number: 12
      mode:
        input: true
        pullup: true
    pin_b:
      number: 14
      mode:
        input: true
        pullup: true
    filters:
    - lambda: |-
        auto first_mass = 100;
        auto first_value = 500;
        auto second_mass = 0;
        auto second_value = 5;
        auto r = map (x, first_value, second_value, first_mass, second_mass);
        if (r >0) return r;
        return 0;
    unit_of_measurement: "%"
script:
  - id: stopped
    mode: restart
    then:
      - delay: 500ms
          state: 0
Have you had a look at the cover component? It would be the same for a Garage door.
Yeah i did, but didnt find a Way to use my absolute position for the cover component. But perhaps im missing something here.
