I guess I should replace the library with “SparkFun BQ27441 LiPo Fuel Gauge Arduino Library”, but the documentation is not really clear on that point. When I try to compile, I see:
thanks for the advice, I was able to get to the command line of the host i’m running HA on. I’m running home assistant OS on a NUC. I then went into the container running ESPHome with:
docker exec -it addon_a0d7b954_esphome bash
When I ran pio pkg install "SparkFun BQ27441 LiPo Fuel Gauge Arduino Library" I got: Error: No such command "pkg
I then tried pio platform install "SparkFun BQ27441 LiPo Fuel Gauge Arduino Library", that gave this error:
Platform Manager: Installing SparkFun BQ27441 LiPo Fuel Gauge Arduino Libraryge Arduino Library"
Error: Please upgrade to the PlatformIO Core 6
Upon closer inspection of the ESPHome log, I saw this warning:
Library Manager: Installing Installing SparkFun BQ27441 LiPo Fuel Gauge Arduino Library
Warning! Please upgrade to the PlatformIO Core 6
So on the command line, I see it as a error, but in the ESPHome log, it’s just a warning
I though I was using the latest version of ESPHome, because I use it as a add-on and always update when there is a update available.Turned out I was on version 2022.3, while the latest version is 2022.10
I didn’t had a update button in the add-on, so I eventually uninstalled the plugin and re-installed it. That worked, and now my problem seems to have been solved!
I am just trying to implement the BQ27441 into my first EPSHome project, and I get the following error:
[C][spi:023]: Setting up SPI bus...
E (16330) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (16330) task_wdt: - loopTask (CPU 1)
E (16330) task_wdt: Tasks currently running:
E (16330) task_wdt: CPU 0: IDLE0
E (16330) task_wdt: CPU 1: IDLE1
E (16330) task_wdt: Aborting.
abort() was called at PC 0x4015920c on core 0
ELF file SHA256: 0000000000000000
Backtrace: 0x4008920c:0x3ffbf8b0 0x40089489:0x3ffbf8d0 0x4015920c:0x3ffbf8f0 0x40087885:0x3ffbf910 0x40170f13:0x3ffbc160 0x4015ab17:0x3ffbc180 0x4008bc59:0x3ffbc1a0 0x4008a49a:0x3ffbc1c0
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
[I][logger:258]: Log initialized
[C][ota:469]: There have been 1 suspected unsuccessful boot attempts.
[D][esp32.preferences:113]: Saving 1 preferences to flash...
[D][esp32.preferences:142]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[I][i2c.arduino:175]: Performing I2C bus recovery
I have my SparkFun connected to GPIO 21 and 22. Below is the code I am using:
I am using the WaveShare e-paper board to then display weather info on an e-ink display. I use the SparkFun to charge the LiPo battery and also wanted to show the battery status on the display. But as soon as I uncomment the sensor part it crashes with the error above. I am using the same BQ27441.h file as above.
Anybody who can help or guide me in the right direction?
