Masterzz
(Igors Micko)
February 11, 2024, 3:02pm
1
After upgrade from 2023.12.5 to 2023.12.7 see some issues with sorting in dashboard.
New devices appearing in bottom of list and stay there.
Refresh/restart not changing order - they still NOT in alplabetical order, but newest last.
Does anyone also have same issue ?
tom_l
February 11, 2024, 10:32pm
2
Yes I see that. Restart the add-on and it should sort correctly.
Masterzz
(Igors Micko)
February 12, 2024, 7:35am
3
It helps … before another device added.
Later added devices again appear at bottom of list, not in right place.
tom_l
February 12, 2024, 7:53am
4
I had a search through the existing issues. There isn’t one for this. I’ll open one.
EDIT:
opened 07:59AM - 12 Feb 24 UTC
### The problem
After adding a new device it is appears at the end of the add-o… n devices dashboard.
Refreshing the page or clearing the web browser cache does not change this.
Only restarting the add-on sorts the devices correctly (alphabetically).
### Which version of ESPHome has the issue?
2023.12.9
### What type of installation are you using?
Home Assistant Add-on
### Which version of Home Assistant has the issue?
core-2024.2.1
### What platform are you using?
ESP32
### Board
QuinLED ESP32
### Component causing the issue
Nil
### Example YAML snippet
```yaml
Irrelevant.
### Anything in the logs that might be useful for us?
```txt
No.
### Additional information
_No response_
