ESPHome Device Auto Bulk Update
A blueprint that automatically handles ESPHome device firmware updates so you don't have to. Rather than relying on the ESPHome add-on's built-in "Update All" button which can be unreliable, this automation monitors your devices and handles updates on a schedule within a time window you define.
Usage
- Enable firmware update entities for each ESPHome device β Settings β Devices & Services β ESPHome β Your Device β Enable the Firmware Update entity
- Import the Blueprint
- Create an Automation from the imported Blueprint
- Configure the sliders and options to your preference β no YAML editing required
Features
- Triggers automatically when a set number of devices have pending updates
- Daily sweep at the start of your update window catches anything missed outside the window
- Actionable notification sent before updates begin listing all affected devices by name
- Update Now button to skip the delay and update immediately
- Cancel button to abort if the timing isn't convenient
- Choice of updating all devices at once or sequentially one at a time
- Configurable delay between sequential updates
- Completion notification confirms how many devices were updated and which ones
- Cooldown period prevents the automation re-triggering immediately after updates complete
Requirements
- ESPHome integration installed and configured
- Home Assistant Companion App installed on your notification device
- Device firmware update entities must be enabled for each ESPHome device
Flow
- Triggers when device update count exceeds the threshold, or daily sweep at the start of the time window
- Checks the time window and device count conditions are met
- Sends a notification listing devices to be updated with Update Now and Cancel buttons
- Waits for the delay period listening for a button response
- If Cancel is tapped β sends a cancellation notification and stops
- If Update Now is tapped or delay expires β proceeds with updates (Notification remains open so Cancel remains active)
- Updates all devices at once or sequentially depending on mode selected
- Sends a completion notification listing updated devices
- Waits out the cooldown period before the automation can trigger again
blueprint:
name: ESPHome Device Auto Bulk Update
description: |
Automatically updates ESPHome devices when a specified number of them
have pending updates. Optionally sends a notification before updating.
DEVICE FIRMWARE ENTITIES MUST BE ENABLED
FLOW:
1. Triggers when device update count exceeds the threshold, or daily sweep at the start of the time window.
2. Checks the time window and device count conditions are met.
3. Sends a notification listing devices to be updated with Update Now and Cancel buttons.
4. Waits for the delay period listening for a button response.
7. If Cancel is tapped - sends a cancellation notification and stops.
8. If Update Now is tapped or delay expires - proceeds with updates.
9. Updates all devices at once or sequentially depending on mode selected.
10. Sends a completion notification listing updated devices.
11. Waits out the cooldown period before the automation can trigger again.
domain: automation
source_url: https://github.com/bferd/homeassistant-blueprints/blob/main/esphome_auto_bulk_update.yaml
input:
update_threshold:
name: Device Update Threshold
description: How many devices need a pending update before updates are pushed.
default: 1
selector:
number:
min: 1
max: 20
step: 1
mode: slider
update_delay:
name: Delay Before Updating
description: How many minutes to wait before pushing updates.
default: 30
selector:
number:
min: 0
max: 60
step: 1
mode: slider
unit_of_measurement: minutes
cooldown:
name: Cooldown After Update
description: Minutes to wait after updates complete before the automation can trigger again.
default: 30
selector:
number:
min: 0
max: 120
step: 1
mode: slider
time_window_start:
name: Update Window Start
description: Earliest time of day updates can be triggered.
default: "08:00:00"
selector:
time:
time_window_end:
name: Update Window End
description: Latest time of day updates can be triggered.
default: "21:00:00"
selector:
time:
notify_device:
description: Device to notify before updates are pushed.
selector:
device:
integration: mobile_app
update_mode:
description: Update all devices at once or one at a time sequentially.
default: "all_at_once"
selector:
select:
options:
- label: "All at once"
value: "all_at_once"
- label: "One at a time (Sequential)"
value: "sequential"
sequential_delay:
name: Delay Between Sequential Updates
description: Minutes to wait between each device when using sequential mode.
default: 0
selector:
number:
min: 0
max: 10
step: 1
mode: slider
variables:
update_threshold: !input update_threshold
update_delay: !input update_delay
cooldown: !input cooldown
update_mode: !input update_mode
sequential_delay: !input sequential_delay
device_list: >
{{ expand(integration_entities('esphome'))
| selectattr("entity_id", "contains", "update")
| selectattr("state", "eq", "on")
| map(attribute='entity_id') | list }}
device_names: >
| map(attribute='name') | join(', ') }}
device_count: >
| list | count }}
value_template: >
| list | count > update_threshold }}
- platform: time
at: !input time_window_start
condition:
- condition: time
after: !input time_window_start
before: !input time_window_end
- condition: template
value_template: >
- domain: mobile_app
type: notify
device_id: !input notify_device
title: "ESPHome Device Update(s)"
message: >
{{ device_count }} device(s) need updating: {{ device_names }}.
Updates will begin in {{ update_delay }} minute(s).
sticky: "true"
persistent: "true"
actions:
- action: "UPDATE_NOW_ESPHOME"
title: "Update Now"
- action: "CANCEL_ESPHOME_UPDATE"
title: "Cancel"
- wait_for_trigger:
- platform: event
event_type: mobile_app_notification_action
event_data:
- platform: event
event_data:
timeout:
minutes: "{{ update_delay }}"
continue_on_timeout: true
- if:
value_template: >
{{ wait.trigger is not none and
wait.trigger.event.data.action == 'CANCEL_ESPHOME_UPDATE' }}
then:
type: notify
title: "ESPHome Update Cancelled"
message: "ESPHome device updates have been cancelled."
else:
- if:
value_template: "{{ update_mode == 'sequential' }}"
then:
- repeat:
for_each: "{{ device_list }}"
sequence:
- action: update.install
continue_on_error: true
data: {}
entity_id: "{{ repeat.item }}"
- delay:
minutes: "{{ 0 if repeat.last else sequential_delay }}"
else:
data: {}
entity_id: "{{ device_list }}"
type: notify
title: "ESPHome Updates Complete"
message: >
{{ device_count }} device(s) have been updated: {{ device_names }}.
- delay:
minutes: "{{ cooldown }}"
mode: single
Tips, Tricks and Gotchas
- If you accidentally dismiss the notification without tapping a button, the automation will wait out the full delay and then proceed with updates automatically
- On Android, if the action buttons are not visible try long pressing or expanding the notification
- On iOS, action buttons require a long press on the notification to reveal them
- Sequential mode is gentler on your network and the ESPHome add-on β recommended if you have many devices
- If an update fails on one device in sequential mode, the automation will continue to the next device thanks to
continue_on_error - Make sure your update window is wide enough to accommodate the delay + total update time for all your devices
Changelog
- 2026-03-20: Initial release
