The ESPHome docs Sensor Component — ESPHome say:
- device_class (Optional, string): The device class for the sensor. See Sensor - Home Assistant for a list of available options. Set to
to remove the default device class of a sensor.
This makes it sound like the ESPHome device_class
list is unified with HA’s. Navigating to that URL: https://www.home-assistant.io/integrations/sensor/#device-class it shows several valid device_class
values that don’t actually work in ESPHome.
device_class | Home Assistant | Supported in ESPHome |
None | TRUE | TRUE |
aqi | TRUE | FALSE |
battery | TRUE | TRUE |
carbon_dioxide | TRUE | TRUE |
carbon_monoxide | TRUE | TRUE |
current | TRUE | TRUE |
energy | TRUE | TRUE |
gas | TRUE | TRUE |
humidity | TRUE | TRUE |
illuminance | TRUE | TRUE |
monetary | TRUE | TRUE |
nitrogen_dioxide | TRUE | FALSE |
nitrogen_monoxide | TRUE | FALSE |
nitrous_oxide | TRUE | FALSE |
ozone | TRUE | FALSE |
pm1 | TRUE | FALSE |
pm10 | TRUE | FALSE |
pm25 | TRUE | FALSE |
power_factor | TRUE | TRUE |
power | TRUE | TRUE |
pressure | TRUE | TRUE |
signal_strength | TRUE | TRUE |
sulphur_dioxide | TRUE | FALSE |
temperature | TRUE | TRUE |
timestamp | TRUE | FALSE |
volatile_organic_compounds | TRUE | FALSE |
voltage | TRUE | TRUE |
I discovered this when I tried to use aqi
and pm25
values in the ESPHome editor:
Or try to run a validation on the yaml with one of those
device_class
es defined.
This shouldn’t be the case, right?
