Hi all,
A few weeks ago I added my first ESPHome device, the Atom Echo. This went suprisingly werll.
So, yesterday I’ve added my Tasmota Zigbee Bridge (ZB01) with ESPHome.
Flashing succeded, And Zigbee2MQTT picks it up and all works well.
But, In ESPHome the config stays offline. (although I can re-flash it and see the logs and enter the web page). And ESPHome shows a new device that can be adopted (beeing the ZB01).
Why? and how to fix this?
The yaml in the ESPHome is as followed:
substitutions:
friendly_name: "Athom Zigbee Gateway"
room: "Hal"
device_description: "athom eth zigbee gateway"
project_name: "Athom Technology.Athom Zigbee Gateway"
project_version: "v2.0.1"
dns_domain: "iot.HIDDEN.org"
timezone: ""
# Define logging level: NONE, ERROR, WARN, INFO, DEBUG (Default), VERBOSE, VERY_VERBOSE
log_level: "DEBUG"
# wifi_fast_connect: "false"
esphome:
friendly_name: "${friendly_name}"
area: "${room}"
name_add_mac_suffix: true
project:
version: "${project_version}"
platformio_options:
# board_build.mcu: esp32dev
# board_build.variant: esp32dev
board_build.flash_mode: dio
esp32:
board: esp32dev
framework:
type: esp-idf
external_components:
- source: github://oxan/esphome-stream-server
refresh: 0s
dashboard_import:
package_import_url: github://athom-tech/esp32-configs/athom-zigbee-gateway.yaml
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
#WT32-ETH01 Ethernet
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 1
manual_ip:
static_ip: 10.8.2.62
gateway: 10.8.2.1
subnet: 255.255.255.0
# wifi:
# # This spawns an AP with the device name and mac address with no password.
# ap: {}
# # Allow rapid re-connection to previously connect WiFi SSID, skipping scan of all SSID
# fast_connect: "${wifi_fast_connect}"
# # Define dns domain / suffix to add to hostname
# domain: "${dns_domain}"
# captive_portal:
# Enable logging
logger:
baud_rate: 115200
level: ${log_level}
# Enable Home Assistant API
api:
reboot_timeout: 0s
encryption:
key: "HIDDEN"
ota:
- platform: esphome
password: "HIDDEN"
web_server:
port: 80
local: True
switch:
- platform: gpio
pin: 32
inverted: yes
restore_mode: ALWAYS_OFF
- platform: gpio
pin: 33
inverted: yes
name: "Prep the cc2652p2 for firmware update"
turn_on_action:
- script.execute: fw_update_mode
turn_off_action:
- button.press: zRST
button:
- platform: restart
name: "Restart the Device"
name: "Zigbee Module Restart"
on_press:
- switch.turn_on: zRST_gpio
- delay: 15ms
- switch.turn_off: zRST_gpio
uart:
rx_pin: GPIO14
tx_pin: GPIO12
baud_rate: 115200
stream_server:
uart_id: uart_bus
port: 8888 # optional, default is 8888
binary_sensor:
- platform: stream_server
connected:
name: "AthomZB Serial Connected"
- platform: status
entity_category: diagnostic
#mdns:
# services:
# - service: "_athomzb"
# protocol: "_tcp"
# port: 8888
# txt:
# version: 1.0
# name: AthomZB
# radio_type: znp
# baud_rate: 115200
# data_flow_control: software
light:
- platform: status_led
disabled_by_default: true
pin:
inverted: true
number: GPIO15
script:
- id: fw_update_mode
then:
- switch.turn_on: zBSL
- delay: 1s
- delay: 1s
- logger.log: "Delaying ~10 seconds for cc2652p2 to settle"
- delay: 11s
- switch.turn_off: zBSL
- logger.log: "Please try update with cc2538-bsl tool now"
- logger.log: "cc-bsl usage: cc2538-bsl.py -p socket://ip-of-gw:8888 -evw firmware.hex"
