adri_4555
(adrisg)
October 21, 2024, 10:49am
1
Since the last update, my ESPHome devices have been unable to connect to my Wi-Fi network without manually entering the CaptivePortal. Even after rebooting, I have to repeatedly enter the Wi-Fi network generated by the device and try to reconnect…
esphome:
friendly_name: Tira Led Funkos
esp8266:
board: esp07
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret api_encryption_key
ota:
platform: esphome
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Funkos-led-strip"
password: !secret wifi_ap_password
captive_portal:
output:
- platform: esp8266_pwm
pin: GPIO4
min_power: 0
pin: GPIO12
min_power: 0
pin: GPIO14
min_power: 0
pin: GPIO13
min_power: 0
pin: GPIO5
min_power: 0
light:
- platform: rgbww
red: output_R
green: output_G
blue: output_B
warm_white: output_T
cold_white: output_W
cold_white_color_temperature: 6535 K
warm_white_color_temperature: 2000 K
color_interlock: True
default_transition_length: .4s
binary_sensor:
- platform: gpio
internal: true
pin:
number: GPIO0
inverted: true
mode:
input: true
pullup: True
on_release:
then:
light.toggle: strip_led
ddaniel
(Daniel Dekovic)
October 21, 2024, 11:08am
2
Try setting static ip in yaml file.
adri_4555
(adrisg)
October 21, 2024, 11:36am
3
One of the devices that also disconnects has a static IP set.
This is the yml config file, also in previous versions it was working perfectly.
I have also tried putting the keys directly in the device’s yml and it still doesn’t work.
wifi_ssid: "Villa_Polvoretes"
wifi_password: "password"
wifi_ap_password: "12345678"
api_encryption_key: "key"
ota_password: "otapassword"
adri_4555
(adrisg)
October 21, 2024, 8:55pm
5
These are the logs that the terminal throws
e[0;32m[I][wifi:313]: WiFi Connecting to 'Villa_Polvoretes'...e[0m
e[0;33m[W][wifi_esp8266:505]: Event: Disconnected ssid='Villa_Polvoretes' bssid=e[5m02:EB:D8:25:5B:66e[6m reason='Auth Expired'e[0m
e[0;33m[W][wifi:653]: Error while connecting to network.e[0m
e[0;36m[D][wifi:697]: Retrying with hidden networks...e[0m
nickrout
(Nick Rout)
October 22, 2024, 2:45am
6
Without the colour codes would have been better.
If you google
esphome “Auth Expired”
you’ll fine plenty of results, like this one ESPHome - Wifi - Auth Expired
