Hi, Out of ~30 devices some of them do not reconnect to the Home Assistant after the WiFi router is rebooted.
They connect to the WiFi just fine, they reply to pings, I am also able to see the LOGS / fw-update them, but are not available in the Home Assistant, so the API it not pairing somehow , until I remove them and reconnect the Integration. They do self restart after a while, because of lack of API connection, to no avail.
This started after the API encryption update and switched to the encryption key.
WiFi access is over a WiFi Mesh, with ASUS routers.
