Recently flashed a second ESP32 with ESPHome and a config near identical to my first device, but it’s not showing up. If I pull up the logs for both devices, they’re both reporting values and getting IP addresses. Any ideas?
The configuration I setup for the device that IS in Home Assistant is the following:
esphome:
platform: ESP32
board: esp32dev
# Enable Home Assistant API
api:
logger:
ota:
password: ""
wifi:
ssid: ""
password: ""
# Handle a moving average of vibrations
# Avoids `turning on` when bumping the dryer
- platform: pulse_counter
name: "Dryer Vibration Pulse Rate"
internal: false # It may be easier to expose this when setting up and testing
icon: mdi:vibrate
state_class: measurement
force_update: true
update_interval: 250ms # 4x a second
pin:
number: GPIO23
mode: INPUT
filters:
- median:
window_size: 31
send_every: 4 # Every 1 second
send_first_at: 3
- platform: wifi_signal
name: "Dryer WiFi Signal"
binary_sensor:
device_class: vibration
filters:
- delayed_on_off: 60s # Avoid debounce shaking from washing machine in close proximity
lambda: |-
if (id(dryer_pulse_rate).state >= 120) {
// Dryer is running
return true;
} else {
// Dryer is off
return false;
Then the config for the device that ISN’T showing up is:
esphome:
platform: ESP32
board: esp32dev
api:
logger:
ota:
password: ""
wifi:
ssid: ""
password: ""
# Avoids `turning on` when bumping the washer
name: "Washer Vibration Pulse Rate"
icon: mdi:vibrate
force_update: true
pin:
number: GPIO23
mode: INPUT
filters:
- median:
window_size: 31
send_first_at: 3
name: "Washer WiFi Signal"
binary_sensor:
filters:
- delayed_on_off: 60s # Avoid debounce shaking from Dryer in close proximity
lambda: |-
if (id(washer_pulse_rate).state >= 120) {
// Washer is running
return true;
} else {
// Washer is off
return false;
