ESPHome Device not Triggering Automation
Hi! I have a question regarding ESPHome triggering an automation. This is my first ESPHome project so I’m a novice. I have a doggy door that also has a physical button I can press to open it, so naturally I threw on a Zigbee button pusher (fingerbot) to push the button. Now to trigger this I have set up 2 pressure mats via ESPHome (one outside and one inside). I also set up a zigbee button (mainly just to test it myself).
Now the problem I am having is the outdoor mat works great. The mat senses pressure, and the automation gets triggered and the door opens. However, the indoor one (which has the same code) does not, which is strange as it previously did work just fine.
I’ve tried restarting Home Assistant, deleting the automation and writing it again, updating the ESPHome device with the most recent software, but it refuses to trigger. I’ve also used the indoor mat in other automations to test if it would trigger and it does not. I’ve checked the ESPhome Logs and the device is registering “On/Off” (see pictured below) but for some reason Home Assistant is not picking it up to use in automations.
I’ve copied below my automation code, if it helps at all. Any help on how to resolve this would be greatly appreciated! Thank you in advance.
alias: Open Doggy Door Via Mat (Button)
description: ""
  - device_id: 0x0x0x0x0x0x0x0x0x
    domain: zha
    platform: device
    type: remote_button_short_press
    subtype: remote_button_short_press
  - type: turned_on
    platform: device
    entity_id: binary_sensor.doggy_door_pressure_mat_outside
    domain: binary_sensor
  - type: turned_on
    platform: device
    for:
      hours: 0
      minutes: 0
      seconds: 2
condition:
  - condition: state
    entity_id: input_boolean.doggy_door
    state: "on"
  - condition: state
    entity_id: input_boolean.doggy_door_wifi
    state: "off"
  - condition: state
    entity_id: timer.doggy_door_timer
    state: idle
    enabled: false
  - type: toggle
    entity_id: switch.switch
    domain: switch
  - service: light.turn_on
      rgb_color:
        - 255
        - 43
        - 5
mode: single
It doesn’t look as though it is staying on for 2 sec. The trace will be more detailed.
Thank you. However the 2 second condition isn’t what is preventing the automation from triggering, even if its set to zero it will not trigger.
However (as I should have checked before), the entity state for this ESPHome device is unavailable. Per the logs it went unavailable randomly yesterday, any idea how to remedy this?
