ESPHome device shows offline but connected when I check my router
I’ve had two devices that had problems after updating to 2024.5.0.
One of them was an assistant/smart speaker that refused to play mp3s until I changed the esp-idf framework it was using from recommended to 4.4.6 (undoing the change of recommended version to 4.4.7 that came olong with 2024.5.0)
The other seems more similar to what you’ve described… its a cb3s based IR ‘blaster’ that was refusing to stay connected to both wifi and API after udpating.
I found that some kind of yaml size limitation was reduced with the udpate, and it behaved just fine after I removed some of the IR remote buttons I had defined.
How easy it is’ll depend on the yaml you’re using, but is it possible to cut a chunk out of the devices yaml and see what it does? Just as a test, it might show something similar. Be sure to keep a copy of your original yaml somehow though, so you can put it all back.
it is a pretty big yaml file, but that is due to the fact it has both a ledstrip and a LD2410 connected, of which the latter really needs to ton of stuff configured, but I could indeed check what I can remove from the yaml and retry again. But it seems to me this is something they need to fix in ESPHome itself instead of us deleting stuff in order to make it work normally again :sweat_smile:
I don’t mean to suggest permanently removing functionality, just trying it as a quick test.
If you find similar, it would seem to be something thats changed for the worse and undoing/redoing whatever it is might make most sense.
It might be a way to narrow it down a little.
Better yet, you can install and run older ESPHome versions at the same time. I have 2024.4 and 2023.9 both installed on my Home Assistant.
I have to do this because some of my Sonoff devices will not connect to WiFi if compiled using 2024.4, but they do if compiled with 2023.9.
Nice trick, seems to work a treat. Thanks for sharing.
That is pretty nice! maybe I should look into how to do this too until it is solved. But wouldn’t some nodes keep saying it has updates ready to install? or can you specify which node uses which version?
in any case, for now I created an issue with ESPHome about this, let’s see what they respond :slight_smile: Device offline but reachable after update to ESPHome 2024.5.0 · Issue #5808 · esphome/issues · GitHub
Please respond here as well. I also raised an issue with the ESPHome developers and was quickly dismissed. (Disregarded actually).
Yes, but IF IT’S WORKING … DON’t FIX (update) IT.
What I do now is to turn off the firmware update entity. I will update the existing and working devices only as needed.
In the Updates section of Settings, click on the device icon.
Click on the gear icon:
From here, disable the firmware entity. Now you will never see the update notification.
Turn_Off_ESPHome_Device_Updates-3
yeah they pointed to another topic about this and did nothing in both mine or the other topic so far…
I do agree with many in here that it is concerning that so many people are talking about this issue and to see no response at all or any mentioning about it in the updates from the devs
Did you disable the firmware entity as I showed above?
You may also need to refresh your browser and erase the cache (ctrl-F5).
it seems the latest version did fix the device. Lesson learned, always backup bin files of working versions to revert back to…
I am having this issue with the latest ESP Home 2024.6.6 Any one else? I have 5 units all with the latest firmware. They all report to Home Assistant and I can see their logs. But 3 of them show as offline
Same issue, all of my ESP32 devices show offline in esphome but logs can be updated and OTA updates work fine. Sensor data is sent fine to home assistant as well.
On latest home assistant 2024.7.0 and ESP home 2024.6.6.
I am having this issue when i try to update to ESPHome 2024.6.6
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Library Manager: Installing ShiftRegister74HC595 @ 1.2
Warning! Could not find the package with 'ShiftRegister74HC595 @ 1.2' requirements for your system 'linux_aarch64'
has anyone encountered this problem?
No and it is in noway related to the topic you just replied to :yawning_face:
You can read how to ask a good question and (after reading) open a new topic with your problem :point_down:
seriously? maybe you look at the first post, who started this topic before you jump in to answer…
Yes, the problem in this topic is:
ESPHome device shows offline but connected when I check my router :warning:
The only thing and you and the the thread starter in 2021 had in common was the use of the same hardware component (shift register). Maybe you even use a esp8266 too - we don’t know as you didn’t provide the basics (yaml etc.) needed to get a qualified answer (beside posting at the wrong location) :wink:
Again! Try the link on how to help us help you :pray:
I don’t understand why you insist on this topic?
Why open another topic as long as it is very possible to find an answer here, as long as the person who opened this topic uses the same library and the same configuration as me.
Because this topic is about pears and you have troubles with your apples :pear: :arrows_counterclockwise: :apple:
For now we have no clue about what you are using or how your configuration looks like. It really comes down to you helping us :sos:
