Hi @NathanCu, here are the logs:
The service homeassistant.turn_on does not support entities input_boolean.loadshedunknown
12:05:05 PM β (WARNING) Home Assistant Core Integration - message first occurred at 10:26:52 AM and shows up 8841 times
Error evaluating condition in 'geyserautomationson': In 'condition': In 'and' (item 2 of 2): In 'state': In 'state' condition: unknown entity automation.geyser_up_on1
12:05:05 PM β (WARNING) Automation - message first occurred at 10:26:52 AM and shows up 7254 times
Template variable warning: 'None' has no attribute 'state' when rendering '{{ states.sensor.power_total_wemos.state }},{{ states.sensor.derivedgeyseruppower.state }},{{ states.sensor.derivedgeyserdownpower.state }},{{ states.sensor.wemosem3_consumo_actual.state }},{{ states.sensor.charger_adjust.state}},{{ states.sensor.backup_adjust.state }},{{states.sensor.batta_monthly.state}},{{states.sensor.battb_monthly.state}},{{states.sensor.battall_monthly.state}},{{states.counter.battery_cycle.state}},{{states.counter.battery_cycle_b.state}},{{states.sensor.allbatteries.state}},{{states.counter.lawnsincenov22.state}},{{states.sensor.non_geyser_kwh_meter_monthly.state}},{{states.sensor.geysers_total_monthly_limit.state}},{{states.sensor.filtered_battery_voltage.state}},{{states.sensor.filtered_battery_level.state}},{{states.sensor.filtered_battery_level2.state}},{{states.sensor.monthly_energywemos.state}}'
12:05:00 PM β (WARNING) helpers/template.py - message first occurred at 10:27:00 AM and shows up 101 times
Error fetching ipp data: Invalid response from API: Timeout occurred while connecting to IPP server.
12:02:55 PM β (ERROR) Internet Printing Protocol (IPP) - message first occurred at 10:57:53 AM and shows up 6 times
Watchdog heartbeat timeout: TimeoutError()
11:40:57 AM β (WARNING) runner.py
Error while getting Updates: urllib3 HTTPError ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
11:15:22 AM β (ERROR) /usr/local/lib/python3.11/site-packages/telegram/ext/updater.py - message first occurred at 10:38:19 AM and shows up 4 times
Error doing job: Task exception was never retrieved
10:59:59 AM β (ERROR) setup.py - message first occurred at 10:26:53 AM and shows up 2 times
Unable to set up dependencies of device_tracker. Setup failed for dependencies: zone
10:59:59 AM β (ERROR) setup.py - message first occurred at 10:26:11 AM and shows up 4 times
YAML file /config/logbooks.yaml contains duplicate key "exclude". Check lines 0 and 69
10:41:52 AM β (WARNING) util/yaml/loader.py - message first occurred at 10:26:11 AM and shows up 2 times
Entity sensor.geysers_total_daily_limit from integration utility_meter has state class total_increasing, but its state is not strictly increasing. Triggered by state 2.97 (2.98) with last_updated set to 2023-11-16T08:26:15.795888+00:00. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
10:30:10 AM β (WARNING) Sensor - message first occurred at 10:30:10 AM and shows up 2 times
async_update_selects failed
10:27:01 AM β (ERROR) yTubeMediaPlayer (custom integration)
The unit of sensor.geyser_3d_avg (W) cannot be converted to the unit of previously compiled statistics (None). Generation of long term statistics will be suppressed unless the unit changes back to None or a compatible unit. Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
10:26:54 AM β (WARNING) Sensor - message first occurred at 10:26:54 AM and shows up 3 times
restarted: Error executing script. Service not found for call_service at pos 5: Unable to find service counter.increment
10:26:54 AM β (ERROR) Automation
Referenced entities media_player.study_speaker are missing or not currently available
10:26:54 AM β (WARNING) helpers/service.py
TemplateError('ValueError: Template error: int got invalid input 'unavailable' when rendering template '{{ states.sensor.sunsynk_battery_power.state | int *2 }}' but no default was specified') while processing template 'Template<template=({{ states.sensor.sunsynk_battery_power.state | int *2 }}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.ss_battpower'
10:26:52 AM β (ERROR) Template - message first occurred at 10:26:52 AM and shows up 44 times
Error while processing template: Template<template=({{ states.sensor.sunsynk_pv.state | int *2 }}) renders=2>
10:26:52 AM β (ERROR) helpers/template.py - message first occurred at 10:26:52 AM and shows up 42 times
Error doing job: Exception in callback _async_at_core_state.<locals>._matched_event(<Event homeassistant_start[L]>) at /usr/src/homeassistant/homeassistant/helpers/start.py:37
10:26:52 AM β (ERROR) components/sensor/__init__.py - message first occurred at 10:26:52 AM and shows up 2 times
sensor.sunsynk_stats_last_update rendered invalid timestamp: 0
10:26:52 AM β (WARNING) Sensor
Setup failed for device_tracker: (DependencyError(...), 'Could not setup dependencies: zone')
10:26:31 AM β (ERROR) setup.py - message first occurred at 10:26:11 AM and shows up 2 times
Zigbee channel 11 utilization is 98.43%!
10:26:31 AM β (WARNING) components/zha/core/gateway.py - message first occurred at 10:26:31 AM and shows up 2 times
Entity sensor.wemosem2_amperaje (<class 'homeassistant.components.mqtt.sensor.MqttSensor'>) is using native unit of measurement 'A' which is not a valid unit for the device class ('power') it is using; expected one of ['kW', 'W']; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mqtt%22
10:26:26 AM β (WARNING) Sensor - message first occurred at 10:16:20 AM and shows up 8 times
Multiple Tasmota devices are sharing the same topic 'cmnd/xboxroom/'. Offending devices: 'Tasmota' (192.168.68.136), 'Tasmota' (192.168.68.160)
10:26:17 AM β (WARNING) Tasmota
Can't connect to ESPHome API for watermeter @ 192.168.68.132: Error connecting to ('192.168.68.132', 6053): [Errno 111] Connect call failed ('192.168.68.132', 6053) (SocketAPIError)
10:26:16 AM β (WARNING) runner.py - message first occurred at 10:26:16 AM and shows up 4 times
Error while setting up yamaha platform for media_player
10:26:16 AM β (ERROR) Media player
Invalid XML returned for request http://192.168.68.144:80/YamahaRemoteControl/desc.xml: b'File Not Found\n\nURI: /YamahaRemoteControl/desc.xml\nMethod: GET\nArguments: 0\n'
10:26:16 AM β (ERROR) /usr/local/lib/python3.11/site-packages/rxv/rxv.py
Error while setting up ytube_music_player platform for media_player
10:26:15 AM β (ERROR) Media player
Couldn't connect using mysql://****:****@core-mariadb/homeassistant?charset=utf8 DB_URL: (MySQLdb.OperationalError) (1698, "Access denied for user 'khazi'@'172.30.32.1'") (Background on this error at: https://sqlalche.me/e/20/e3q8)
10:26:15 AM β (ERROR) SQL
Error while setting up scrape platform for sensor
10:26:15 AM β (ERROR) Sensor
Login client response error: 403, message='Forbidden', url=URL('http://192.168.68.1/cgi-bin/luci/;stok=/login?form=login')
10:26:15 AM β (ERROR) TP-Link Deco (custom integration)
Setup of application_credentials is taking longer than 300 seconds. Startup will proceed without waiting any longer
10:26:07 AM β (ERROR) setup.py - message first occurred at 10:26:07 AM and shows up 12 times
Timed out adding entities for domain input_select with platform input_select after 500s
10:26:07 AM β (WARNING) input_select
10:26:07 AM β (ERROR) /usr/src/homeassistant/homeassistant/runner.py
Connection closed: Cannot write to closing transport
10:26:07 AM β (WARNING) runner.py
Timed out adding entities for domain sensor with platform filter after 500s
10:26:07 AM β (WARNING) Sensor - message first occurred at 10:26:07 AM and shows up 2 times
Setup of platform template is taking longer than 60 seconds. Startup will proceed without waiting any longer.
10:26:07 AM β (ERROR) Sensor
Timed out adding entities for domain group with platform group after 500s
10:26:07 AM β (WARNING) Group
Setup of sensor platform filter is taking over 10 seconds.
10:26:07 AM β (WARNING) Sensor - message first occurred at 10:16:32 AM and shows up 7 times
Setup of input_button is taking over 10 seconds.
10:26:07 AM β (WARNING) runner.py - message first occurred at 10:16:32 AM and shows up 16 times
Automation with alias 'dstv_cluster_on' could not be validated and has been disabled: extra keys not allowed @ data['action'][4]['seconds']. Got 2 offset None should be format 'HH:MM', 'HH:MM:SS' or 'HH:MM:SS.F' for dictionary value @ data['action'][4]['delay']. Got None
10:26:07 AM β (ERROR) Automation - message first occurred at 10:26:07 AM and shows up 8 times
Could not convert state: (<class 'str'>) to number
10:25:12 AM β (ERROR) filter - message first occurred at 10:16:20 AM and shows up 2 times
The 'include' option near /config/configuration.yaml:60 is deprecated, please remove it from your configuration
10:16:21 AM β (WARNING) History - message first occurred at 10:16:21 AM and shows up 2 times
The moon platform for the sensor integration does not support platform setup. Please remove it from your config.
10:16:20 AM β (ERROR) Sensor
Ended unfinished session (id=53 from 2023-11-16 07:39:47.026116)
10:16:15 AM β (WARNING) Recorder
Lovelace is running in storage mode. Define resources via user interface
10:16:13 AM β (WARNING) Dashboards
The esphome one is not appearing this time device_tracker.yaml is empty.
Configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant: !include homeassistant_data.yaml
sensor: !include sensors.yaml
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
google_assistant:
project_id: casanuestra
service_account: !include casanuestra-ed08b622201b.json
report_state: true
counter: !include counters.yaml
panel_iframe:
music_assistant:
title: "REDACTED"
url: "REDACTED"
icon: mdi:music
tts:
- platform: google_translate
time_memory: 300
service_name: google_translate_say
frontend:
extra_module_url:
- /local/community/lovelace-card-mod/card-mod.js
lovelace:
resources:
- url: /local/community/mini-graph-card/mini-graph-card-bundle.js
type: module
- url: /local/comunity//mini-media-player/mini-media-player-bundle.js
type: module
utility_meter: !include utility_meter.yaml
input_number: !include input_number.yaml
group: !include groups.yaml
automation: !include_dir_merge_list automations/
script: !include scripts.yaml
scene: !include scenes.yaml
device_tracker: !include device_tracker.yaml
mqtt: !include mqtt_broker.yaml
zone: !include zones.yaml
input_boolean: !include booleans.yaml
notify: !include notifiers.yaml
telegram_bot: !include telegram_bot.yaml
conversation:
#speedtestdotnet: !include speedtester.yaml
media_player: !include media_players.yaml
recorder: !include recorders.yaml
history: !include histories.yaml
person: !include persons.yaml
logbook: !include logbooks.yaml
template: !include sunsynk.yaml
python_script:
wake_on_lan:
