I have multiple ESP-based devices, and one of them always shows up as needing a firmware update, even if the update actually worked normally. It shows a previous installed version, even if I installed the latest.
I deleted and re-created the device, but it’s always the same. Any idea?
I’ve seen this before when the device fails to update. The top line in the device log file only shows the version of ESPHome you have installed in Home Assistant, NOT the version on the device:
INFO ESPHome 2024.3.2
To see the version that been installed on the device you need to look further down on the log file for the debug entry:
[11:35:53][D][debug:079]: ESPHome version 2024.3.2
# Enable logging
logger:
level: DEBUG
I recently had a device that was failing to update even though it looked like it succeeded, but kept getting those firmware update notices. I ended up needing to do a manual download and install it with a cable using https://web.esphome.io/
When I try to update it (although it is already updated), I get:
2024-04-19 09:25:03,054 INFO Running command 'esphome --dashboard compile /config/esphome/power-monitor-plug-heater-garage.yaml'
2024-04-19 09:25:13,269 INFO Process exited with return code 0
2024-04-19 09:25:13,278 INFO 101 GET /upload (0.0.0.0) 1.28ms
2024-04-19 09:25:13,756 INFO Running command 'esphome --dashboard upload /config/esphome/power-monitor-plug-heater-garage.yaml --device 192.168.0.219'
2024-04-19 09:25:21,960 INFO Process exited with return code 0
