Hi all,
I am having issues with multiple ESPhome devices being unsuccessful to connect to my mesh wifi network (using TP-Link Deco, S4 and P9 units).
Having looked at the UART logs (bottom of the page) I see that the signal for my network (BuburuzaWifi) from the different access points is successfully picked up and the ESP tries to connect to one (by the way not the one with the strongest signal first) and fails with for various reasons every time.
I have short listed some of them (they are not all in order, see log at the bottom of the page):
[W][wifi_esp32:458]: Event: Disconnected ssid='BuburuzaWifi' bssid=00:31:92:FA:EA:96[redacted] reason='Not Authenticated'
[W][wifi_esp32:458]: Event: Disconnected ssid='BuburuzaWifi' bssid=00:31:92:FA:EA:96[redacted] reason='Authentication Failed'
[W][wifi_esp32:455]: Event: Disconnected ssid='BuburuzaWifi' reason='Probe Request Unsuccessful'
[W][wifi_esp32:458]: Event: Disconnected ssid='BuburuzaWifi' bssid=1C:3B:F3:16:F5:E6[redacted] reason='Authentication Failed'
[W][wifi_esp32:458]: Event: Disconnected ssid='BuburuzaWifi' bssid=1C:3B:F3:16:F5:E6[redacted] reason='Auth Expired'
[W][wifi_esp32:458]: Event: Disconnected ssid='BuburuzaWifi' bssid=00:31:92:FA:EB:5E[redacted] reason='4-Way Handshake Timeout'
[W][wifi_esp32:458]: Event: Disconnected ssid='BuburuzaWifi' bssid=00:31:92:FA:EA:96[redacted] reason='Auth Expired'
[W][wifi_esp32:458]: Event: Disconnected ssid='BuburuzaWifi' bssid=00:31:92:FA:EA:96[redacted] reason='Association Expired'
[W][wifi_esp32:458]: Event: Disconnected ssid='BuburuzaWifi' bssid=1C:3B:F3:16:F9:B8[redacted] reason='Auth Expired'
I don’t understand what is the problem. Is it something with the ESPhome way of handling wifi?
All my other devices (phone, tv) connect to the strongest signal very quickly and remain connected for ever.
I do have one SSID for both 2.4GHz and 5GHz but any other ESP powered devices such as Sonoff switches have no problem connecting and the connection persists for ever.
End point is that whenever the device finally manages to connect it is most often to one of the further access points as you can see below:
not to mention that even after connecting to an access point with strong signal, the connection will be dropped and then connect to a worse one off
Full log
[D][wifi:470]: Found networks:
[I][wifi:514]: - 'BuburuzaWifi' (00:31:92:FA:EA:96) [redacted]▂▄▆█
[D][wifi:515]: Channel: 3
[D][wifi:516]: RSSI: -75 dB
[I][wifi:514]: - 'BuburuzaWifi' (1C:3B:F3:16:F9:B8) [redacted]▂▄▆█
[D][wifi:516]: RSSI: -79 dB
[I][wifi:514]: - 'BuburuzaWifi' (1C:3B:F3:16:F5:E6) [redacted]▂▄▆█
[D][wifi:516]: RSSI: -34 dB
[I][wifi:514]: - 'BuburuzaWifi' (00:31:92:FA:EB:5E) [redacted]▂▄▆█
[D][wifi:516]: RSSI: -66 dB
[I][wifi:514]: - 'BuburuzaWifi' (00:31:92:FA:EB:66) [redacted]▂▄▆█
[D][wifi:516]: RSSI: -74 dB
[D][wifi:519]: - ''[redacted] (26:3B:F3:16:F5:E6) [redacted]▂▄▆█
[D][wifi:519]: - 'BuburuzaWifi_Guest'[redacted] (22:3B:F3:16:F5:E6) [redacted]▂▄▆█
[D][wifi:519]: - ''[redacted] (0A:31:92:FA:EB:5E) [redacted]▂▄▆█
[D][wifi:519]: - 'BuburuzaWifi_Guest'[redacted] (06:31:92:FA:EB:5E) [redacted]▂▄▆█
[D][wifi:519]: - ''[redacted] (0A:31:92:FA:EB:66) [redacted]▂▄▆█
[D][wifi:519]: - 'BuburuzaWifi_Guest'[redacted] (06:31:92:FA:EB:66) [redacted]▂▄▆█
[D][wifi:519]: - 'NVR083a2f08252c'[redacted] (08:3A:2F:08:25:2C) [redacted]▂▄▆█
[D][wifi:519]: - 'BuburuzaWifi_Guest'[redacted] (06:31:92:FA:EA:96) [redacted]▂▄▆█
[D][wifi:519]: - 'EE-QJF2R5'[redacted] (A8:A2:37:AF:5F:E1) [redacted]▂▄▆█
[D][wifi:519]: - 'EE WiFi'[redacted] (6A:A2:37:AF:5F:E2) [redacted]▂▄▆█
[D][wifi:519]: - ''[redacted] (6A:A2:37:AF:5F:E5) [redacted]▂▄▆█
[D][wifi:519]: - ''[redacted] (0A:31:92:FA:EA:96) [redacted]▂▄▆█
[D][wifi:519]: - ''[redacted] (26:3B:F3:16:F9:B8) [redacted]▂▄▆█
[D][wifi:519]: - 'BuburuzaWifi_Guest'[redacted] (22:3B:F3:16:F9:B8) [redacted]▂▄▆█
[D][wifi:519]: - 'NCC-1701'[redacted] (34:5D:9E:DA:C7:D9) [redacted]▂▄▆█
[I][wifi:300]: WiFi Connecting to 'BuburuzaWifi'...
[W][wifi:639]: WiFi Unknown connection status 0
[W][wifi:634]: Connecting to WiFi network failed. Are the credentials wrong?
[D][wifi:455]: Starting scan...
[D][wifi:516]: RSSI: -80 dB
[D][wifi:516]: RSSI: -36 dB
[D][wifi:516]: RSSI: -70 dB
[D][wifi:516]: RSSI: -73 dB
[D][wifi:516]: RSSI: -76 dB
[D][wifi:519]: - 'IPC_9CA3A91C2DCC'[redacted] (9C:A3:A9:1C:2D:CC) [redacted]▂▄▆█
[I][wifi:168]: Starting fallback AP!
[C][wifi:250]: Setting up AP...
[C][wifi:252]: AP SSID: 'Loft-Sensor Fallback Hotspot'
[C][wifi:253]: AP Password: 'WO1TK4iNKC5B'
[C][wifi:262]: IP Address: 192.168.4.1
[D][wifi:516]: RSSI: -38 dB
[D][wifi:516]: RSSI: -72 dB
[W][wifi:618]: Error while connecting to network.
[D][wifi:516]: RSSI: -37 dB
[D][wifi:516]: RSSI: -77 dB
[D][wifi:516]: RSSI: -81 dB
[D][wifi:516]: RSSI: -82 dB
[D][wifi:516]: RSSI: -78 dB
[I][wifi:587]: WiFi Connected!
[C][wifi:405]: Local MAC: C8:C9:A3:CB:8D:34
[C][wifi:410]: SSID: 'BuburuzaWifi'[redacted]
[C][wifi:411]: IP Address: 192.168.68.131
[C][wifi:413]: BSSID: 1C:3B:F3:16:F5:E6[redacted]
[C][wifi:414]: Hostname: 'loft-sensor'
[C][wifi:416]: Signal strength: -36 dB ▂▄▆█
[C][wifi:420]: Channel: 3
[C][wifi:421]: Subnet: 255.255.255.0
[C][wifi:422]: Gateway: 192.168.68.1
[C][wifi:423]: DNS1: 192.168.1.254
[C][wifi:424]: DNS2: 192.168.68.1
[D][wifi:596]: Disabling AP...
BuburuzaWifi: -73dB
BuburuzaWifi: -75dB
BuburuzaWifi: -78dB
BuburuzaWifi_Guest: -38dB
BuburuzaWifi_Guest: -74dB
BuburuzaWifi_Guest: -76dB
BuburuzaWifi_Guest: -80dB
BuburuzaWifi_Gue'
[C][wifi:573]: WiFi:
[C][wifi:416]: Signal strength: -37 dB ▂▄▆█
[C][wifi_signal.sensor:009]: WiFi Signal 'WiFi'
[C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[C][wifi_signal.sensor:009]: State Class: 'measurement'
[C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[C][wifi_info:009]: WifiInfo IPAddress 'IP'
[C][wifi_info:009]: Icon: 'mdi:ip-network'
[C][wifi_info:011]: WifiInfo SSID 'AP SSID'
[C][wifi_info:012]: WifiInfo BSSID 'AP BSSID'
[C][wifi_info:010]: WifiInfo Scan Results 'Networks'
[C][wifi_info:010]: Icon: 'mdi:access-point-network'
[C][wifi:416]: Signal strength: -34 dB ▂▄▆█
