Hi all,
My home mesh has started to fail, so I am in the process of installing a new Ubiquiti UniFi setup. One of the advantages of doing this is you can create additional WiFi networks per AP, which means you can manually spread your IOT nodes between APs instead of having them clump onto a specific one, as they are wont to do.
So this means I am having to reflash my devices because of the new SSID. But I am running into the same problem I had when upgrading from 1.13.6 to 1.14.1: the nodes no longer connect to the WiFi. Here’s what I did so far.
First, I took a new Sonoff Basic R3, and flashed it manually as a test, on my bench. It worked OK.
Encouraged, I flashed one of the Sonoff Basic R2 1.0 modules that I have as a light switch. It failed to connect to the network, so I pulled it out of the wall, and tried to flash it manually. It takes the bin ie it’s programmable, but it won’t connect to the network.
I tried flashing it with the Test bin I had put onto the R3. Still no dice.
Then I went into my backup folder and found an old bin from 1.13.6, and flashed that onto the Sonoff Basic R2 1.0. It worked, the device connects to the old network.
So on the plus side, I still have a working device, but I’m not able to segregate it off onto its own IOT network. Also, I am very afraid to flash the rest of my devices, as some of them are extremely hard to reach (up in the roof), and I am a fat old man with no wish to die, yet.
I remember with the 14.1 upgrade there was some signal strength setting you could try to make the device connect, which sometimes worked and sometimes didn’t. Does anyone remember what that was?
Alternatively, and preferably, is there some setting in 1.20.4 that solves this problem?
Thank you.
EDIT: I remembered the setting, it was:
output_power: 17.5db
However, that did not solve the problem.
