This is my first ESPHome device and there is something I can’t understand. I defined a button to action a task, and this button is being triggered by HA without my control.
The button is defined as below:
on_press:
- remote_transmitter.transmit_pronto:
transmitter_id: rf_tx
data: >-
And the logging in the Activity tab shows something like below:
There are 3 events generated by me pressing the button, and they are showing By Daniel.
But the other events were generated by themselves. I can see two events per triggering, one with an orange badge and another without badge.
I have looked at events in the developer tools, but I can’t find any thing that explain this behavior. I don’t have any automation in HA nor in the ESPHome yml.
The full code for the ESPHome device is:
esphome:
friendly_name: RF Proxy Blinds
name_add_mac_suffix: false
min_version: 2026.5.0
esp32:
board: m5stack-atom
framework:
type: esp-idf
logger:
api:
encryption:
key: *****
ota:
- platform: esphome
password: *****
wifi:
ap:
ssid: *****
password: *****
use_address: *****
captive_portal:
network:
enable_ipv6: false
remote_transmitter:
pin: GPIO26
carrier_duty_percent: 100%
button:
- platform: factory_reset
entity_category: diagnostic
disabled_by_default: true
- platform: restart
entity_category: config
icon: "mdi:restart"
on_press:
data: >-
After experimenting a lot, I could make a link between the device re-connecting to HA and the button being triggered.
The log from ESPHome’s device shows the following each time the button is triggered:
INFO Processing unexpected disconnect from ESPHome API for rf-proxy-blinds @ xx.xx.xx.xx
WARNING Disconnected from API
INFO Successfully resolved rf-proxy-blinds @ xx.xx.xx.xx in 0.000s
INFO Successfully connected to rf-proxy-blinds @ xx.xx.xx.xx in 0.013s
INFO Successful handshake with rf-proxy-blinds @ xx.xx.xx.xx in 0.062s
