HelL5toKe
(Matthew)
December 31, 2023, 12:13am
1
Hi there team, I am wanting to use these sensors with esphome and esp32…
I have been playing around with the other Dfrobot sensor SEN0395 which is supported by esphome and with a few hilink sensors, all have their pros, and cons.
the SEN0521 sensor is a 5ghz sensor and is included in the tuya zigbee presence sensors that I own, these sensors are not so good as zigbee sensors as if you have 10 or more the network can become unstabe due to to many mesages. I would really like to convert these sensors to esp32/wifi so they can join my other esp32 sensors and remove them from the zigbee.
the benifits I have found with the 5ghz sensor is its a little more stable and has very few false triggers whilst still picking up stationary objects very well. I would be very happy to be able to have these work in esphome.
So with all that said, I dont know how to go about converting the .cpp and .h files provided by dfrobot for Arduino:
into a working esphome yaml.
I tried for quite a bit of time to search google and work with chatgpt to acheive this but its above my head and chatgpt seemed to have the right idea but kept making incorrect and inconsistant yaml config.
I wondering if anyone here can help or point me in the right direction.
Thanks!
HelL5toKe
(Matthew)
January 6, 2024, 9:41pm
2
for anyone that wants this to I did manage to get this working, here is the esphome config.
HelL5toKe
(Matthew)
January 6, 2024, 9:42pm
3
substitutions:
friendly_name: Computer Presence Sensor
hidden_ssid: "false"
factory_reset_disabled: "false"
esphome:
friendly_name: ${friendly_name}
esp32:
board: esp32dev
logger:
level: VERBOSE
baud_rate: 0
api:
encryption:
key:
ota:
password:
wifi:
ssid:
password:
manual_ip:
static_ip: 192.168.40.94
gateway: 192.168.40.1
subnet: 255.255.255.0
captive_portal:
mqtt:
broker: 192.168.1.5
username: esphome
password: esphome
client_id: ${name}
topic_prefix: esphome/${name}
discovery: false
light:
- platform: status_led
pin: GPIO14
internal: False
restore_mode: ALWAYS_OFF
- platform: binary
restore_mode: RESTORE_DEFAULT_OFF
output: mmwave_led_output
entity_category: config
disabled_by_default: True
output:
type: binary
write_action:
- switch.turn_off: mmwave_sensor
- delay: 1s
- if:
condition:
lambda: !lambda return state;
then:
- uart.write: "setLedMode 1 0"
else:
- uart.write: "setLedMode 1 1"
- delay: 1s
- uart.write: "saveConfig"
- delay: 3s
- switch.turn_on: mmwave_sensor
external_components:
- source:
type: git
url: https://github.com/ssieb/custom_components
components: [ serial ]
uart:
rx_pin: GPIO16
tx_pin: GPIO17
baud_rate: 115200
debug:
direction: BOTH
dummy_receiver: true
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
binary_sensor:
- platform: gpio
device_class: occupancy
pin:
number: GPIO32
mode: INPUT_PULLDOWN
- platform: gpio
pin:
number: GPIO25
device_class: motion
filters:
- delayed_off: !lambda 'return id(pir_off_latency).state * 1000.0;'
filters:
- delayed_off: !lambda 'return id(occupancy_off_latency).state * 1000.0;'
lambda: |-
if ( id(mmwave).state or id(pir_motion_sensor).state) {
return true;
else if (id(mmwave).state == 0 and id(pir_motion_sensor).state == 0) {
return false;
else {
return id(occupancy).state;
switch:
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
turn_on_action:
- uart.write: "sensorStart"
- delay: 1s
turn_off_action:
- uart.write: "sensorStop"
- delay: 1s
name: UART presence output
internal: false
optimistic: true
turn_on_action:
- delay: 1s
- uart.write: "setUartOutput 1 1"
- delay: 1s
- delay: 3s
turn_off_action:
- delay: 1s
- uart.write: "setUartOutput 1 0"
- delay: 1s
- delay: 3s
name: UART target output
internal: false
optimistic: true
assumed_state: false
turn_on_action:
- delay: 1s
- uart.write: "setUartOutput 2 1 1 1"
- delay: 1s
- delay: 3s
turn_off_action:
- delay: 1s
- uart.write: "setUartOutput 2 0"
- delay: 1s
- delay: 3s
number:
name: mmWave Start Distance
icon: mdi:arrow-collapse-left
min_value: 0
max_value: 1
initial_value: 0
optimistic: true
step: .1
restore_value: true
unit_of_measurement: m
mode: slider
set_action:
- delay: 1s
- uart.write: !lambda |-
std::string mss = "setRange " + to_string(id(mmwave_start_distance).state) + " " + to_string(id(mmwave_stop_distance).state);
return std::vector<unsigned char>(mss.begin(), mss.end());
- delay: 3s
- delay: 2s
name: mmWave Stop Distance
icon: mdi:arrow-collapse-right
min_value: 1
max_value: 11
initial_value: 4
optimistic: true
step: .5
restore_value: true
mode: slider
set_action:
- delay: 1s
- delay: 3s
- delay: 2s
name: mmWave off latency
icon: mdi:clock-end
min_value: 1
max_value: 60
initial_value: 15
optimistic: true
step: 1
restore_value: true
unit_of_measurement: seconds
mode: slider
set_action:
- delay: 1s
std::string mss = "setLatency " + to_string(id(mmwave_on_latency).state) + " " + to_string(id(mmwave_off_latency).state);
- delay: 3s
- delay: 2s
name: mmWave on latency
icon: mdi:clock-start
min_value: 0
max_value: 60
initial_value: 0
optimistic: true
step: 0.5
restore_value: true
mode: slider
set_action:
- delay: 1s
- delay: 3s
- delay: 2s
name: mmWave sensitivity
icon: mdi:target-variant
min_value: 0
max_value: 9
initial_value: 7
optimistic: true
step: 1
restore_value: true
set_action:
- delay: 1s
- uart.write:
!lambda std::string mss = "setSensitivity " + to_string((int)x);
- delay: 1s
- delay: 1s
name: Occupancy off latency
icon: mdi:clock-end
min_value: 1
max_value: 60
initial_value: 15
optimistic: true
step: 1
restore_value: true
mode: slider
name: PIR off latency
icon: mdi:clock-end
min_value: 1
max_value: 60
initial_value: 10
optimistic: true
step: 1
restore_value: true
mode: slider
button:
- platform: restart
internal: false
name: Restart mmWave sensor
internal: true
on_press:
- uart.write: "resetSystem"
icon: mdi:restart
on_press:
- button.press: restart_mmwave
- button.press: restart_internal
- platform: safe_mode
internal: false
disabled_by_default: false
name: Factory reset mmWave
icon: mdi:cog-counterclockwise
on_press:
- delay: 1s
- uart.write: "resetCfg"
- delay: 3s
Nice one. Thanks for sharing it for the next person.
BTW you need to format your code a special way to make it easy for others to read. The trick is here.
Before we begin…
This forum is not a helpdesk
The people here don’t work for Home Assistant, that’s an open source project. We are volunteering our free time to help others. Not all topics may get an answer, never mind one that helps you solve your problem.
[image]
This also isn’t a general home automation forum, this is a forum for Home Assistant and things related to it. Any question about Home Assistant, and about using things with Home Assistant, is welcome here. We can’t help you with e…
