Folks, it must be something rather simple I am missing. LilyGO T-QT ESP32-S3 display with ADS1115 and pressure sensor connected.
ESP read the values and passes to HA. Display is working and showing time. But not the pressure value which is successfully passed to HA. Any suggestions where I made a mistake?
spi:
clk_pin: GPIO3
mosi_pin: GPIO2
i2c:
- id: bus_a
sda: GPIO38
scl: GPIO39
scan: true
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
name: "Water Filter Pressure 1"
unit_of_measurement: "PSI"
device_class: "pressure"
accuracy_decimals: 1
filters:
- calibrate_linear:
method: least_squares
datapoints:
# V PSI
- 0.4 -> 0
- 0.8 -> 13
- 1.7 -> 50
- 4.5 -> 99 # assumed
- clamp:
min_value: -1
max_value: 151
font:
- file: "fonts/OCRAEXT.ttf"
- file: "gfonts://Roboto"
switch:
- platform: gpio
pin:
number: GPIO10
mode:
output: True
name: "Display Backlight"
entity_category: diagnostic
time:
- platform: homeassistant
timezone: Australia/Perth
display:
- platform: st7789v
model: Custom
width: 128
height: 128
offset_width: 0
offset_height: 0
cs_pin: GPIO5
dc_pin: GPIO6
reset_pin: GPIO1
rotation: 180
lambda: |-
it.strftime(0, 0, id(fontocra), TextAlign::TOP_LEFT, "%H:%M", id(home_time).now());
it.line(0, 50, 128, 50);
it.printf(0, 90, id(roboto), "P1: %1", id(pressure_ch1).state);
Thank you in advance.
