noxx
(Ralf B)
August 23, 2023, 7:20pm
1
is it possible to set the update intervall between
8:00 - 22:00 to 60s
22:00 - 8.00 to 300s
display:
- platform: waveshare_epaper
cs_pin: 15
dc_pin: 12
update_interval: 30s
busy_pin: 16
reset_pin: 4
model: 4.20in
lambda: |-
You’d set update_interval:
to never
and then use component.update
to refresh it using a on_time:
or interval:
trigger which has the necessary conditions.
Not sure if the same can be done for full_update_every
noxx
(Ralf B)
August 24, 2023, 5:43am
3
noxx:
update_interval
thx. at the moment in dont know exactly what you mean.
is this perhaps possible?
if (id(homeassistant_time).now().hour > 8 & < 22) {
update_interval: 60s
} else {
update_interval: 300s
Edit: not possible
error: unable to find numeric literal operator ‘operator""s’
display:
cs_pin: 15
dc_pin: 12
busy_pin: 16
reset_pin: 4
model: 4.20in
lambda: |-
if (id(homeassistant_time).now().hour > 8 & id(homeassistant_time).now().hour < 22) {
} else {
noxx
(Ralf B)
August 24, 2023, 8:46am
4
seems that this works:
time:
- platform: homeassistant
timezone: Europe/Berlin
on_time:
- seconds: 0
minutes: /1 # Update jede Minute
hours: 8-22
then:
- component.update: epaperdisplay
- seconds: 0
minutes: /30 # Update alle 30 Minuten
hours: 0-7, 23
then:
