Working on ESPHome on Home Assistant
I have several Kauf bulbs I want to integrate… but I cannot get the DNS working.
In Settings | Device & services
I see my Kauf bulb (1) and the need for an Encryption Key (2). I tried the below encryption key but that does not work.
Here is my ESPHome yaml file.
esphome:
friendly_name: Ford
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "mNB9NxzzzzzzzzzzzzzzzzzzzzzzzzzUGrkicWPsU="
ota:
- platform: esphome
password: "0731dxxxxxxxxxxxxxxxxxx997832f8e"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Ford Fallback Hotspot"
password: "0wdfMVasdasdfrdfuuof"
captive_portal:
I then run Install for that Kauf lamp, which all seems good until the DNS part.
INFO ESPHome 2024.7.3
INFO Reading configuration /config/esphome/ford.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing ford (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.3
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
Compiling .pioenvs/ford/src/main.cpp.o
Linking .pioenvs/ford/firmware.elf
RAM: [= ] 12.4% (used 40624 bytes from 327680 bytes)
Flash: [===== ] 49.3% (used 904361 bytes from 1835008 bytes)
Building .pioenvs/ford/firmware.bin
Creating esp32 image...
Successfully created esp32 image.
esp32_create_combined_bin([".pioenvs/ford/firmware.bin"], [".pioenvs/ford/firmware.elf"])
Wrote 0xee330 bytes to file /data/build/ford/.pioenvs/ford/firmware.factory.bin, ready to flash to offset 0x0
esp32_copy_ota_bin([".pioenvs/ford/firmware.bin"], [".pioenvs/ford/firmware.elf"])
========================= [SUCCESS] Took 7.72 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of ford.local
ERROR Error resolving IP address of ford.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
Excerpted here:
I tried to add the following, but it did not help.
mdns:
disabled: false
I have a pfSense firewall with Avahi installed and I am able to resolve ford.local (10.0.0.157).
Any thoughts on what I am doing wrong?
Thanks in advance!
Paul.
