Hi everyone, i have set up a home assistant container in true nas scale, using the official true nas image. I have a problem with esphome integration, my old devices (i used them in HassOS) are now not available, if i remove them and add via UI setting up DEVICE_IP:6053
i get “Unknown error occurred”
On my windows pc i can ping devices by ip/node-name.local, so they are running fine.
Looking into the logs every time i try to add a device i get
2024-04-10 01:38:59.980 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry stanza-pc-lampadari for esphome
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 551, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/esphome/__init__.py", line 43, in async_setup_entry
zeroconf_instance = await zeroconf.async_get_instance(hass)
File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 146, in async_get_instance
return cast(HaZeroconf, (await _async_get_instance(hass)).zeroconf)
File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 161, in _async_get_instance
zeroconf = HaZeroconf(**zcargs)
File "/usr/local/lib/python3.12/site-packages/zeroconf/_core.py", line 180, in __init__
listen_socket, respond_sockets = create_sockets(interfaces, unicast, ip_version, apple_p2p=apple_p2p)
File "/usr/local/lib/python3.12/site-packages/zeroconf/_utils/net.py", line 358, in create_sockets
listen_socket = new_socket(ip_version=ip_version, apple_p2p=apple_p2p, bind_addr=('',))
File "/usr/local/lib/python3.12/site-packages/zeroconf/_utils/net.py", line 248, in new_socket
s.bind(bind_tup)
OSError: [Errno 98] Address in use
Any ideas?
