I’m trying to make a nodemcu board with 20 ds18b20 sensors. The sensors are connected to 5V via VIN, the data is connected to D1. I installed a 4.7K pullup between vin and D1. The remaining pin is connected to GND.
Everything works fine, until I add more than 8 sensors. It does not matter which ninth sensor I add, after sensor 8 I get this message on startup:
[dallas.sensor:077]: Found no sensors!
I’ve tried using the 3.3V, but then it stops working already after 6 sensors. I’ve switched from a 1A power supply to 1.5A, but this doesn’t make any difference.
The sensors I use are the waterproof ds18b20 variant with 1 meter cable per sensor. The sensors are connected in a star pattern.
Any hints, or am I running into the limits?
