I see my Dallas sensors in ESPHome logs sending values, but those sensors are not visible to HA as entities?
I have made every restart and reinstall, nothing helps.
config:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
# encryption:
# key: "KJcZbr8WENLFOnKtnemb7GaCN7sT2Rr+JvTb6BhHW4M="
ota:
password: "aabc8fb86a6982135df0371d3972dd56"
wifi:
ssid: Antsumaja
password: xxxxxxxx
# ssid: !secret wifi_ssid
# password: !secret wifi_password
# Optional manual IP
manual_ip:
static_ip: 192.168.1.40
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Esp32-1-Wire Fallback Hotspot"
password: "ZlwJStbemSmo"
captive_portal:
dallas:
pin: 23
update_interval: 10s
# Individual sensors
- platform: dallas
address: 0xAF0416A0C0D7FF28
- platform: dallas
address: 0xBB0516A0B4DAFF28
- platform: dallas
address: 0x160416A0BD02FF28
- platform: dallas
address: 0xe30416A098FCFF28
Log:
INFO Reading configuration /config/esphome/esp32-1-wire.yaml...
INFO Starting log output from 192.168.1.40 using esphome API
INFO Successfully connected to 192.168.1.40
[13:16:36][I][app:102]: ESPHome version 2022.5.0 compiled on May 19 2022, 12:52:32
[13:16:36][C][wifi:491]: WiFi:
[13:16:36][C][wifi:353]: Local MAC: 34:86:5D:3B:62:F8
[13:16:36][C][wifi:354]: SSID: 'Antsumaja'[redacted]
[13:16:36][C][wifi:355]: IP Address: 192.168.1.40
[13:16:36][C][wifi:357]: BSSID: 20:B0:01:E6:17:DD[redacted]
[13:16:36][C][wifi:358]: Hostname: 'esp32-1-wire'
[13:16:36][C][wifi:360]: Signal strength: -67 dB ▂▄▆█
[13:16:36][C][wifi:364]: Channel: 11
[13:16:36][C][wifi:365]: Subnet: 255.255.255.0
[13:16:36][C][wifi:366]: Gateway: 192.168.1.1
[13:16:36][C][wifi:367]: DNS1: 0.0.0.0
[13:16:36][C][wifi:368]: DNS2: 0.0.0.0
[13:16:36][C][logger:274]: Logger:
[13:16:36][C][logger:275]: Level: DEBUG
[13:16:36][C][logger:276]: Log Baud Rate: 115200
[13:16:36][C][logger:277]: Hardware UART: UART0
[13:16:36][C][dallas.sensor:075]: DallasComponent:
[13:16:36][C][dallas.sensor:076]: Pin: GPIO23
[13:16:36][C][dallas.sensor:077]: Update Interval: 10.0s
[13:16:36][D][dallas.sensor:082]: Found sensors:
[13:16:36][D][dallas.sensor:084]: 0xe30416a098fcff28
[13:16:36][D][dallas.sensor:084]: 0x160416a0bd02ff28
[13:16:36][D][dallas.sensor:084]: 0xbb0516a0b4daff28
[13:16:36][D][dallas.sensor:084]: 0xaf0416a0c0d7ff28
[13:16:36][C][dallas.sensor:089]: Device 'Temp-04'
[13:16:36][C][dallas.sensor:089]: Device Class: 'temperature'
[13:16:36][C][dallas.sensor:089]: State Class: 'measurement'
[13:16:36][C][dallas.sensor:089]: Unit of Measurement: '°C'
[13:16:36][C][dallas.sensor:089]: Accuracy Decimals: 1
[13:16:36][C][dallas.sensor:097]: Address: 0xaf0416a0c0d7ff28
[13:16:36][C][dallas.sensor:098]: Resolution: 12
[13:16:36][C][dallas.sensor:089]: Device 'Temperature-1'
[13:16:36][C][dallas.sensor:097]: Address: 0xbb0516a0b4daff28
[13:16:36][C][dallas.sensor:089]: Device 'Temperature-2'
[13:16:36][C][dallas.sensor:097]: Address: 0x160416a0bd02ff28
[13:16:36][C][dallas.sensor:089]: Device 'Temperature-3'
[13:16:36][C][dallas.sensor:097]: Address: 0xe30416a098fcff28
[13:16:36][C][captive_portal:088]: Captive Portal:
[13:16:36][C][mdns:084]: mDNS:
[13:16:36][C][mdns:085]: Hostname: esp32-1-wire
[13:16:36][C][ota:085]: Over-The-Air Updates:
[13:16:36][C][ota:086]: Address: 192.168.1.40:3232
[13:16:36][C][ota:089]: Using Password.
[13:16:36][C][api:138]: API Server:
[13:16:36][C][api:139]: Address: 192.168.1.40:6053
[13:16:36][C][api:143]: Using noise encryption: NO
[13:16:41][D][dallas.sensor:144]: 'Temp-04': Got Temperature=23.5°C
[13:16:41][D][sensor:125]: 'Temp-04': Sending state 23.50000 °C with 1 decimals of accuracy
[13:16:41][D][dallas.sensor:144]: 'Temperature-1': Got Temperature=23.2°C
[13:16:41][D][sensor:125]: 'Temperature-1': Sending state 23.18750 °C with 1 decimals of accuracy
[13:16:41][D][dallas.sensor:144]: 'Temperature-2': Got Temperature=23.2°C
[13:16:41][D][sensor:125]: 'Temperature-2': Sending state 23.25000 °C with 1 decimals of accuracy
[13:16:41][D][dallas.sensor:144]: 'Temperature-3': Got Temperature=22.9°C
[13:16:41][D][sensor:125]: 'Temperature-3': Sending state 22.93750 °C with 1 decimals of accuracy
[13:16:51][D][dallas.sensor:144]: 'Temp-04': Got Temperature=23.5°C
[13:16:51][D][sensor:125]: 'Temp-04': Sending state 23.50000 °C with 1 decimals of accuracy
[13:16:51][D][dallas.sensor:144]: 'Temperature-1': Got Temperature=23.2°C
[13:16:51][D][sensor:125]: 'Temperature-1': Sending state 23.18750 °C with 1 decimals of accuracy
[13:16:51][D][dallas.sensor:144]: 'Temperature-2': Got Temperature=23.2°C
[13:16:51][D][sensor:125]: 'Temperature-2': Sending state 23.25000 °C with 1 decimals of accuracy
[13:16:51][D][dallas.sensor:144]: 'Temperature-3': Got Temperature=22.9°C
[13:16:51][D][sensor:125]: 'Temperature-3': Sending state 22.93750 °C with 1 decimals of accuracy
