Specify multiple wifi networks - it will connect to the strongest one. This is handy if you have a portable item that you move between different locations, it will connect to the “strongest” one. i.e. the one it can see.
Turn on captive portal. Then if it can’t connect to wifi you will be able to connect to the device in AP mode and set the credentials. Note however these credentials are not saved between reboots.
For version 2, where is the folder located if I want to include my own?
“CSS and JS URL’s are set to empty value, so no internet access is needed for this device to show it’s web interface. V2 embeds the css within the js file so is not required, however you could include your own CSS.”
You can change things I believe - this is the docs:
At the bottom you can see stuff about including your own stylesheets etc for v1, or modifying the .js file for v2. I’m not enough of a web programmer to know what can be modified.
