ESPhome e-paper font brightness vs line brightness (or saturation?)
I am facing bug (probably), when fonts are displayed not so bright on my ESPhome e-paper displays.
In same time, how you can see, horizontal line is displayed correctly in full black color.
The only difference is that line is made with for it.line(), and icons and text is displayed with it.print()
Since I am making this line 4px high by drawing 4 lines i tried:
  • Put 4 it.print() on top of each other
  • Setting COLOR_ON for it.printf() function
But nothing helps. What can cause such problem?
Thank you in advance for any help.
If anyone is interested, here is full code. I am going in the future write post about some solutions I used in here
esphome:
  platform: ESP32
  board: esp32dev
  on_boot:
    priority: 600
    then:
      - deep_sleep.prevent: deep_sleep_1
wifi:
  ssid: "-"
  password: "-"
  fast_connect: true
  # ap:
  #   ssid: "Display Eink Fallback Hotspot"
  #   password: "-"
captive_portal:
# mqtt:
#   broker: 192.168.0.195
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "-"
ota:
  password: "-"
#web_server:
#  port: 80
deep_sleep:
  run_duration: 5min
  sleep_duration: 10min
time:
  - platform: homeassistant
binary_sensor:
    entity_id: input_boolean.e_paper_display_sleep_enable
    internal: true
    on_state:
      then:
        - component.update: main_display
        - if:
            condition:
              binary_sensor.is_on: sleep_enabled
            then:
              - deep_sleep.enter: deep_sleep_1
text_sensor:
    entity_id: weather.gismeteo
    internal: true
    entity_id: sensor.eink_weather_day1_icon
    internal: true
    entity_id: sensor.eink_weather_day2_icon
    internal: true
    entity_id: sensor.eink_weather_day3_icon
    internal: true
  - platform: adc
    pin: 34
    attenuation: 11db
    update_interval: 15s
    internal: false
    name: "Outside Temperature"
    entity_id: sensor.outside_sensor_temperature
    internal: true
    icon: "mdi:weather-sunny"
    name: "Living Room Temperature"
    entity_id: sensor.living_room_temperature
    internal: true
    name: "Living Room Humidity"
    entity_id: sensor.living_room_humidity
    internal: true
    name: "Kitchen Temperature"
    entity_id: sensor.kitchen_temperature
    internal: true
    name: "Kitchen Humidity"
    entity_id: sensor.kitchen_humidity
    internal: true
    name: "Bedroom Temperature"
    entity_id: sensor.bedroom_temperature
    internal: true
    name: "Bedroom Humidity"
    entity_id: sensor.bedroom_humidity
    internal: true
    name: "Bathroom Temperature"
    entity_id:  sensor.bathroom_temperature_2
    internal: true
    name: "Bathroom Humidity"
    entity_id: sensor.bathroom_humidity
    internal: true
    entity_id: sensor.eink_weather_day1_temp_max
    internal: true
    entity_id: sensor.eink_weather_day1_temp_min
    internal: true
    entity_id: sensor.eink_weather_day2_temp_max
    internal: true
    entity_id: sensor.eink_weather_day2_temp_min
    internal: true
    entity_id: sensor.eink_weather_day3_temp_max
    internal: true
    entity_id: sensor.eink_weather_day3_temp_min
    internal: true
    entity_id: input_text.ping
    internal: true
    on_value:
      then:
        - if:
            condition:
            then:
# text_sensor:
#   - platform: homeassistant
#     name: "Ping Pong"
#     id: ping_pong
#     entity_id: input_text.ping
#     internal: true
font:
  - file: "OpenSans-SemiBold.ttf"
    glyphs: "-°0123456789/"
  - file: 'materialdesignicons-webfont.ttf'
    glyphs:
      - "\U000F0590" # weather-cloudy
      - "\U000F0F2F" # weather-cloudy-alert
      - "\U000F0E6E" # weather-cloudy-arrow-right
      - "\U000F0591" # weather-fog
      - "\U000F0592" # weather-hail
      - "\U000F0F30" # weather-hazy
      - "\U000F0898" # weather-hurricane
      - "\U000F0593" # weather-lightning
      - "\U000F067E" # weather-lightning-rainy
      - "\U000F0594" # weather-night
      - "\U000F0F31" # weather-night-partly-cloudy
      - "\U000F0595" # weather-partly-cloudy
      - "\U000F0F32" # weather-partly-lightning
      - "\U000F0F33" # weather-partly-rainy
      - "\U000F0F34" # weather-partly-snowy
      - "\U000F0F35" # weather-partly-snowy-rainy
      - "\U000F0596" # weather-pouring
      - "\U000F0597" # weather-rainy
      - "\U000F0598" # weather-snowy
      - "\U000F0F36" # weather-snowy-heavy
      - "\U000F067F" # weather-snowy-rainy
      - "\U000F0599" # weather-sunny
      - "\U000F0F37" # weather-sunny-alert
      - "\U000F14E4" # weather-sunny-off
      - "\U000F059A" # weather-sunset
      - "\U000F059B" # weather-sunset-down
      - "\U000F059C" # weather-sunset-up
      - "\U000F0F38" # weather-tornado
      - "\U000F059D" # weather-windy
      - "\U000F059E" # weather-windy-variant
    glyphs:
    glyphs:
      - "\U000F04B3" # mdi-sleep-off
      - "\U000F0E0A" # mdi-water-outline
      - "\U000F058C" # mdi-water
    glyphs:
      - "\U000F0766" # mdi-circle-outline
      - "\U000F0A9E" #
      - "\U000F0A9F" #
      - "\U000F0AA0" #
      - "\U000F0AA1" #
      - "\U000F0AA2" #
      - "\U000F0AA3" #
      - "\U000F0AA4" #
      - "\U000F0AA5" # mdi-circle-slice-8
      - "\U000F04B9" # mdi-sofa
      - "\U000F1319" # mdi-kettle-steam
      - "\U000F02E3" # mdi-bed
      - "\U000F09A0" # mdi-shower
spi:
  clk_pin: 13
  mosi_pin: 14
display:
  - platform: waveshare_epaper
    cs_pin: 15
    busy_pin: 25
    reset_pin: 26
    dc_pin: 27
    #model: 4.20in
    model: 7.50inV2
    #update_interval: 10min
    #update_interval: 7s
    update_interval: never
    rotation: 270°
    lambda: |-
      int pointer = 0;
      int sectionHeight = 100;
      int afterLineHeight = 0;
      int bigFontHeight = 70;
      int humidityFontHeight = 50;
      //range make_range(int lower, int upper) {
      //  if(upper < lower) {
      //    return std::make_pair(upper,lower);
      //  return std::make_pair(lower,upper);
      std::map<int, std::string> humidity_icons_map {
        { 0, "\U000F0766" },
        { 1, "\U000F0766" },
        { 2, "\U000F0766" },
        { 3, "\U000F0766" },
        { 4, "\U000F0766" },
        { 5, "\U000F0766" },
        { 6, "\U000F0766" },
        { 7, "\U000F0766" },
        { 8, "\U000F0766" },
        { 9, "\U000F0766" },
        { 10, "\U000F0A9E" },
        { 11, "\U000F0A9E" },
        { 12, "\U000F0A9E" },
        { 13, "\U000F0A9E" },
        { 14, "\U000F0A9E" },
        { 15, "\U000F0A9E" },
        { 16, "\U000F0A9E" },
        { 17, "\U000F0A9E" },
        { 18, "\U000F0A9E" },
        { 19, "\U000F0A9E" },
        { 20, "\U000F0A9F" },
        { 21, "\U000F0A9F" },
        { 22, "\U000F0A9F" },
        { 23, "\U000F0A9F" },
        { 24, "\U000F0A9F" },
        { 25, "\U000F0A9F" },
        { 26, "\U000F0A9F" },
        { 27, "\U000F0A9F" },
        { 28, "\U000F0A9F" },
        { 29, "\U000F0A9F" },
        { 30, "\U000F0A9F" },
        { 31, "\U000F0AA0" },
        { 32, "\U000F0AA0" },
        { 33, "\U000F0AA0" },
        { 34, "\U000F0AA0" },
        { 35, "\U000F0AA0" },
        { 36, "\U000F0AA0" },
        { 37, "\U000F0AA0" },
        { 38, "\U000F0AA0" },
        { 39, "\U000F0AA0" },
        { 40, "\U000F0AA0" },
        { 41, "\U000F0AA0" },
        { 42, "\U000F0AA0" },
        { 43, "\U000F0AA0" },
        { 44, "\U000F0AA1" },
        { 45, "\U000F0AA1" },
        { 46, "\U000F0AA1" },
        { 47, "\U000F0AA1" },
        { 48, "\U000F0AA1" },
        { 49, "\U000F0AA1" },
        { 50, "\U000F0AA1" },
        { 51, "\U000F0AA1" },
        { 52, "\U000F0AA1" },
        { 53, "\U000F0AA1" },
        { 54, "\U000F0AA1" },
        { 55, "\U000F0AA1" },
        { 56, "\U000F0AA1" },
        { 57, "\U000F0AA2" },
        { 58, "\U000F0AA2" },
        { 59, "\U000F0AA2" },
        { 60, "\U000F0AA2" },
        { 61, "\U000F0AA2" },
        { 62, "\U000F0AA2" },
        { 63, "\U000F0AA2" },
        { 64, "\U000F0AA2" },
        { 65, "\U000F0AA2" },
        { 66, "\U000F0AA2" },
        { 67, "\U000F0AA2" },
        { 68, "\U000F0AA2" },
        { 69, "\U000F0AA2" },
        { 70, "\U000F0AA3" },
        { 71, "\U000F0AA3" },
        { 72, "\U000F0AA3" },
        { 73, "\U000F0AA3" },
        { 74, "\U000F0AA3" },
        { 75, "\U000F0AA3" },
        { 76, "\U000F0AA3" },
        { 77, "\U000F0AA3" },
        { 78, "\U000F0AA3" },
        { 79, "\U000F0AA3" },
        { 80, "\U000F0AA3" },
        { 81, "\U000F0AA4" },
        { 82, "\U000F0AA4" },
        { 83, "\U000F0AA4" },
        { 84, "\U000F0AA4" },
        { 85, "\U000F0AA4" },
        { 86, "\U000F0AA4" },
        { 87, "\U000F0AA4" },
        { 88, "\U000F0AA4" },
        { 89, "\U000F0AA4" },
        { 90, "\U000F0AA4" },
        { 91, "\U000F0AA4" },
        { 92, "\U000F0AA4" },
        { 93, "\U000F0AA4" },
        { 94, "\U000F0AA4" },
        { 95, "\U000F0AA4" },
        { 96, "\U000F0AA5" },
        { 97, "\U000F0AA5" },
        { 98, "\U000F0AA5" },
        { 99, "\U000F0AA5" },
        { 100, "\U000F0AA5" },
      std::map<std::string, std::string> weather_icon_map
        {"cloudy", "\U000F0590"},
        {"cloudy-alert", "\U000F0F2F"},
        {"cloudy-arrow-right", "\U000F0E6E"},
        {"fog", "\U000F0591"},
        {"hail", "\U000F0592"},
        {"hazy", "\U000F0F30"},
        {"hurricane", "\U000F0898"},
        {"lightning", "\U000F0593"},
        {"lightning-rainy", "\U000F067E"},
        {"night", "\U000F0594"},
        {"clear-night", "\U000F0594"},
        {"night-partly-cloudy", "\U000F0F31"},
        {"partly-cloudy", "\U000F0595"},
        {"partlycloudy", "\U000F0595"},
        {"partly-lightning", "\U000F0F32"},
        {"partly-rainy", "\U000F0F33"},
        {"partly-snowy", "\U000F0F34"},
        {"partly-snowy-rainy", "\U000F0F35"},
        {"pouring", "\U000F0596"},
        {"rainy", "\U000F0597"},
        {"snowy", "\U000F0598"},
        {"snowy-heavy", "\U000F0F36"},
        {"snowy-rainy", "\U000F067F"},
        {"sunny", "\U000F0599"},
        {"sunny-alert", "\U000F0F37"},
        {"sunny-off", "\U000F14E4"},
        {"sunset", "\U000F059A"},
        {"sunset-down", "\U000F059B"},
        {"sunset-up", "\U000F059C"},
        {"tornado", "\U000F0F38"},
        {"windy", "\U000F059D"},
        {"windy-variant", "\U000F059E"},
      // EXAMPLE_FROM_PHOTO_STARTS
      it.print(0, 0, id(icon_font_weather_middle), TextAlign::TOP_LEFT, weather_icon_map[id(weather_home_hourly).state].c_str());
      it.printf(it.get_width(), -30, id(outside_font), TextAlign::TOP_RIGHT,  "%.1f°C", id(outside_temperature).state);
      pointer += 100;
      it.line(0, pointer + 4, it.get_width(), pointer + 4);
      it.line(0, pointer + 5, it.get_width(), pointer + 5);
      it.line(0, pointer + 6, it.get_width(), pointer + 6);
      it.line(0, pointer + 7, it.get_width(), pointer + 7);
      it.print(it.get_width()/6, pointer, id(icon_font_weather_big), TextAlign::TOP_CENTER, weather_icon_map[id(eink_weather_day1_icon).state].c_str());
      it.print(it.get_width()/6 * 3, pointer, id(icon_font_weather_big), COLOR_ON, TextAlign::TOP_CENTER, weather_icon_map[id(eink_weather_day2_icon).state].c_str());
      it.print(it.get_width()/6 * 5, pointer, id(icon_font_weather_big), TextAlign::TOP_CENTER, weather_icon_map[id(eink_weather_day3_icon).state].c_str());
      pointer += 140;
      it.printf(it.get_width()/6, pointer, id(weather_font_minmax), TextAlign::BOTTOM_CENTER,  "%.0f°/%.0f°", id(eink_weather_day1_temp_min).state,  id(eink_weather_day1_temp_max).state);
      it.printf(it.get_width()/6 * 3, pointer, id(weather_font_minmax), COLOR_ON, TextAlign::BOTTOM_CENTER,  "%.0f°/%.0f°", id(eink_weather_day2_temp_min).state,  id(eink_weather_day2_temp_max).state);
      it.printf(it.get_width()/6 * 5, pointer, id(weather_font_minmax), TextAlign::BOTTOM_CENTER,  "%.0f°/%.0f°", id(eink_weather_day3_temp_min).state,  id(eink_weather_day3_temp_max).state);
      //it.line(0, pointer + 4, it.get_width(), pointer + 4);
      //it.line(0, pointer + 5, it.get_width(), pointer + 5);
      //it.line(0, pointer + 6, it.get_width(), pointer + 6);
      // EXAMPLE_FROM_PHOTO_ENDS
      // LOGO
      it.print(0, pointer + sectionHeight/2, id(icon_font_main), TextAlign::CENTER_LEFT, "\U000F04B9");
      // HUMIDITY
      it.print(it.get_width()/2 - 50, pointer + sectionHeight/2, id(icon_font_main), TextAlign::CENTER, humidity_icons_map[id(living_room_humidity).state].c_str());
      it.print(it.get_width()/2 - 50, pointer + sectionHeight/2, id(little_icon_font), COLOR_OFF, TextAlign::CENTER, "\U000F058C");
      it.print(it.get_width()/2 - 50, pointer + sectionHeight/2, id(little_icon_font), TextAlign::CENTER, "\U000F0E0A");
      // TEMPERATURE
      it.printf(it.get_width(), pointer, id(big_font), TextAlign::TOP_RIGHT, "%.1f°C", id(living_room_temperature).state);
      pointer += sectionHeight;
      it.line(0, pointer, it.get_width(), pointer);
      // LOGO
      it.print(0, pointer + sectionHeight/2, id(icon_font_main), TextAlign::CENTER_LEFT, "\U000F1319");
      // HUMIDITY
      it.print(it.get_width()/2 - 50, pointer + sectionHeight/2, id(icon_font_main), TextAlign::CENTER, humidity_icons_map[id(kitchen_humidity).state].c_str());
      // TEMPERATURE
      it.printf(it.get_width(), pointer, id(big_font), TextAlign::TOP_RIGHT, "%.1f°C", id(kitchen_temperature).state);
      // LOGO
      it.print(0, pointer + sectionHeight/2, id(icon_font_main), TextAlign::CENTER_LEFT, "\U000F02E3");
      // HUMIDITY
      it.print(it.get_width()/2 - 50, pointer + sectionHeight/2, id(icon_font_main), TextAlign::CENTER, humidity_icons_map[id(bedroom_humidity).state].c_str());
      // TEMPERATURE
      it.printf(it.get_width(), pointer, id(big_font), TextAlign::TOP_RIGHT, "%.1f°C", id(bedroom_temperature).state);
      // LOGO
      it.print(0, pointer + sectionHeight/2, id(icon_font_main), TextAlign::CENTER_LEFT, "\U000F09A0");
      // HUMIDITY
      it.print(it.get_width()/2 - 50, pointer + sectionHeight/2, id(icon_font_main), TextAlign::CENTER, humidity_icons_map[id(bathroom__humidity).state].c_str());
      // TEMPERATURE
      it.printf(it.get_width(), pointer, id(big_font), TextAlign::TOP_RIGHT, "%.1f°C", id(bathroom_temperature).state);
      pointer += 30;
      it.strftime(it.get_width()/2, pointer, id(date_font), TextAlign::TOP_CENTER, "%B %d", id(homeassistant_time).now());
      it.strftime(it.get_width()/2, pointer + 45, id(date_font), TextAlign::TOP_CENTER, "%A", id(homeassistant_time).now());
      it.strftime(it.get_width(), it.get_height(), id(date_font), TextAlign::BOTTOM_RIGHT, "%H:%M:%S", id(homeassistant_time).now());
      if (!id(sleep_enabled).state) {
        it.print(0, it.get_height(), id(little_icon_font), TextAlign::BOTTOM_LEFT, "\U000F04B3");
Edit: Added two extra comments in code: EXAMPLE_FROM_PHOTO_STARTS and EXAMPLE_FROM_PHOTO_ENDS if someone really want to look into code, they will help navigate to problem example part
