Esphome esp01 error Wi-Fi Serial not detected
Hi when i try to prepare my esp01 for first use in web.esphome.io i get a error called Improv Wi-Fi Serial not detected
anyone know how i can fix it
INFO Reading configuration /config/esphome/tmp-sensor.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing tmp-sensor (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
Library Manager: Installing ottowinter/ESPAsyncTCP-esphome @ 1.2.3
INFO Installing ottowinter/ESPAsyncTCP-esphome @ 1.2.3
Unpacking  [####################################]  100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/noise-c @ 0.1.4
INFO Installing esphome/noise-c @ 0.1.4
Library Manager: Installing esphome/libsodium @ 1.10018.1
INFO Installing esphome/libsodium @ 1.10018.1
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- ESPAsyncTCP-esphome @ 1.2.3
|-- ESPAsyncWebServer-esphome @ 2.1.0
|   |-- Hash @ 1.0
|   |-- ESP8266WiFi @ 1.0
|-- DNSServer @ 1.1.1
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.4
|   |-- libsodium @ 1.10018.1
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/api/api_connection.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/api/api_server.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/api/list_entities.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/api/proto.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/api/user_services.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/esp8266/core.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/esp8266/gpio.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/esp8266/preferences.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/logger/logger.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/md5/md5.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/mdns/mdns_component.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/network/util.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/socket/socket.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/wifi/wifi_component.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/application.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/color.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/component.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/component_iterator.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/controller.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/entity_base.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/helpers.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/log.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/scheduler.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/esphome/core/util.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/src/main.cpp.o
Generating LD script /data/tmp-sensor/.pioenvs/tmp-sensor/ld/local.eagle.app.v6.common.ld
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/libc03/ESPAsyncTCP-esphome/AsyncPrinter.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/libc03/ESPAsyncTCP-esphome/ESPAsyncTCP.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/libc03/ESPAsyncTCP-esphome/ESPAsyncTCPbuffer.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/libc03/ESPAsyncTCP-esphome/SyncClient.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/libc03/ESPAsyncTCP-esphome/tcp_axtls.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/libaf0/Hash/Hash.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/BearSSLHelpers.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/CertStoreBearSSL.cpp.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/libc03/libESPAsyncTCP-esphome.a
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/ESP8266WiFi.cpp.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/libaf0/libHash.a
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/WiFiClient.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/WiFiServer.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/WiFiUdp.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/ESP8266WiFi/enable_wifi_at_boot_time.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib22c/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib22c/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib22c/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/lib67b/libESP8266WiFi.a
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib22c/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib22c/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib22c/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib22c/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/libecb/DNSServer/DNSServer.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib3ff/ESP8266mDNS/ESP8266mDNS.cpp.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/libecb/libDNSServer.a
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib3ff/ESP8266mDNS/LEAmDNS.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib3ff/ESP8266mDNS/LEAmDNS_Control.cpp.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/lib22c/libESPAsyncWebServer-esphome.a
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib3ff/ESP8266mDNS/LEAmDNS_Helpers.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib3ff/ESP8266mDNS/LEAmDNS_Structs.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib3ff/ESP8266mDNS/LEAmDNS_Transfer.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_core/ed25519/core_ed25519.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_hash/crypto_hash.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_stream/crypto_stream.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/crypto_verify/sodium/verify.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/sodium/codecs.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/sodium/core.c.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/lib3ff/libESP8266mDNS.a
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/sodium/runtime.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium/sodium/utils.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/ref/dh-curve25519.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/ref/hash-blake2b.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/ref/hash-blake2s.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/ref/hash-sha256.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/sodium/dh-curve25519.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/sodium/hash-blake2b.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/backend/sodium/hash-sha256.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/blake2/blake2b.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/blake2/blake2s.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/chacha/chacha.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/donna/curve25519-donna.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/donna/poly1305-donna.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/sha2/sha256.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/sha2/sha512.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/crypto/x25519/x25519.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/cipherstate.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/dhstate.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/errors.c.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/lib6a3/libsodium.a
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/handshakestate.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/hashstate.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/internal.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/names.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/patterns.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/rand_os.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/rand_sodium.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/randstate.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/signstate.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/symmetricstate.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/noise-c/protocol/util.c.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/libFrameworkArduinoVariant.a
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/Crypto.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/Esp-frag.cpp.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/lib1c6/libnoise-c.a
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/Esp-version.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/Esp.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/FS.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/FSnoop.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/HardwareSerial.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/IPAddress.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/LwipDhcpServer-NonOS.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/LwipDhcpServer.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/LwipIntf.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/LwipIntfCB.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/MD5Builder.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/Print.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/Schedule.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/StackThunk.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/Stream.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/StreamSend.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/Tone.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/TypeConversion.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/Updater.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/WMath.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/WString.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/abi.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/aes_unwrap.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/base64.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/cbuf.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/cont.S.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/cont_util.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_app_entry_noextra4k.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_eboot_command.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_features.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_flash_quirks.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_flash_utils.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_i2s.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_main.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_non32xfer.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_noniso.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_phy.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_postmortem.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_si2c.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_sigma_delta.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_spi_utils.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_timer.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_vm.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_waveform_phase.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_waveform_pwm.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_wiring.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_wiring_analog.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_wiring_digital.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_wiring_pulse.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_wiring_pwm.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/core_esp8266_wiring_shift.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/crc32.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/debug.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/exc-c-wrapper-handler.S.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/exc-sethandler.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/flash_hal.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/gdb_hooks.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/heap.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/hwdt_app_entry.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/libb64/cdecode.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/libb64/cencode.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/libc_replacements.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/mmu_iram.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/reboot_uart_dwnld.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/spiffs/spiffs_cache.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/spiffs/spiffs_check.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/spiffs/spiffs_gc.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/spiffs/spiffs_hydrogen.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/spiffs/spiffs_nucleus.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/spiffs_api.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/sqrt32.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/stdlib_noniso.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/time.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/uart.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/umm_malloc/umm_info.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/umm_malloc/umm_integrity.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/umm_malloc/umm_local.c.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/umm_malloc/umm_malloc.cpp.o
Compiling /data/tmp-sensor/.pioenvs/tmp-sensor/FrameworkArduino/umm_malloc/umm_poison.c.o
Archiving /data/tmp-sensor/.pioenvs/tmp-sensor/libFrameworkArduino.a
Linking /data/tmp-sensor/.pioenvs/tmp-sensor/firmware.elf
RAM:   [====      ]  41.3% (used 33820 bytes from 81920 bytes)
Flash: [=====     ]  47.0% (used 481697 bytes from 1023984 bytes)
Building /data/tmp-sensor/.pioenvs/tmp-sensor/firmware.bin
esp8266_copy_factory_bin(["/data/tmp-sensor/.pioenvs/tmp-sensor/firmware.bin"], ["/data/tmp-sensor/.pioenvs/tmp-sensor/firmware.elf"])
======================== [SUCCESS] Took 154.08 seconds ========================
INFO Successfully compiled program.
INFO Resolving IP address of tmp-sensor.local
ERROR Error resolving IP address of tmp-sensor.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: https://esphome.io/components/wifi.html#manual-ips)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
same here. which board do are using?
I’m getting the same error. Were you able to solve it?
Same problem here
Same answer. What board and how are you connecting it to the PC?
same problem here. I use esp 8266 esp01 + esp8266 serial wifi wireless esp-01 adapter module 3.3V and usb serial adapter ch340G 3.3V usb to ttl-uart
Dam i just picked up a ESp-01 and BOOM the same problem. Did Anyone figure this out?
