I ahve a problem with the xiaomi temperature and humidity BLE sensor from xiaomi.
I’ve done all esphome configuration and upload into a ESP32 controller, this by logs finds and send infos about temperature, humidity and battery from the sensor in hassio, but hassio itself does not update values on frontend accordingly to what EspHome sends to him.
any helps? thanks a lot.
I have the same setup with esp32 and I just checked on my phone and can see values in Lovelace changing as my morning heating is on, I haven’t bothered to see if there’s much lag.
If you look at /developer-tools/state , do you see the numbers changing there?
(I should probably update my home assistant, no idea why it doesn’t auto update)
