I bought an esp32-C6 from Seeed studio. I realize that it is not fully supported. I can get it working. It is on the network. But I can’t get any readings from my LD2410. Any advice would be appreciated. I am using the latest version of Home Assistant and ESPHome. Here is my yaml:
esphome:
friendly_name: esp1
esp32:
board: esp32-c6-devkitm-1
flash_size: 4MB
variant: ESP32C6
framework:
type: esp-idf
version: latest
logger:
web_server:
port: 80
# Enable Home Assistant API
api:
encryption:
key: "Secret"
ota:
- platform: esphome
password: "Secret"
wifi:
networks:
- ssid: my_ssid
password: Secret
manual_ip:
static_ip: 192.168.1.131
gateway: 192.168.1.1
subnet: 255.255.255.0
captive_portal:
uart:
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 256000
ld2410:
uart_id: LD2410_UART
throttle: 1500ms
select:
- platform: ld2410
distance_resolution:
name: "distance resolution"
baud_rate:
light_function:
out_pin_level:
name: out pin level
binary_sensor:
- platform: gpio
pin: GPIO18
device_class: motion
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
out_pin_presence_status:
name: out pin presence status
switch:
- platform: ld2410
engineering_mode:
- platform: ld2410
light:
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
g0:
move_energy:
name: g0 move energy
still_energy:
name: g0 still energy
g1:
move_energy:
name: g1 move energy
still_energy:
name: g1 still energy
g2:
move_energy:
name: g2 move energy
still_energy:
name: g2 still energy
g3:
move_energy:
name: g3 move energy
still_energy:
name: g3 still energy
g4:
move_energy:
name: g4 move energy
still_energy:
name: g4 still energy
g5:
move_energy:
name: g5 move energy
still_energy:
name: g5 still energy
g6:
move_energy:
name: g6 move energy
still_energy:
name: g6 still energy
g7:
move_energy:
name: g7 move energy
still_energy:
name: g7 still energy
g8:
move_energy:
name: g8 move energy
still_energy:
name: g8 still energy
number:
- platform: ld2410
timeout:
light_threshold:
name: light threshold
max_move_distance_gate:
name: max move distance gate
max_still_distance_gate:
name: max still distance gate
g0:
move_threshold:
name: g0 move threshold
still_threshold:
name: g0 still threshold
g1:
move_threshold:
name: g1 move threshold
still_threshold:
name: g1 still threshold
g2:
move_threshold:
name: g2 move threshold
still_threshold:
name: g2 still threshold
g3:
move_threshold:
name: g3 move threshold
still_threshold:
name: g3 still threshold
g4:
move_threshold:
name: g4 move threshold
still_threshold:
name: g4 still threshold
g5:
move_threshold:
name: g5 move threshold
still_threshold:
name: g5 still threshold
g6:
move_threshold:
name: g6 move threshold
still_threshold:
name: g6 still threshold
g7:
move_threshold:
name: g7 move threshold
still_threshold:
name: g7 still threshold
g8:
move_threshold:
name: g8 move threshold
still_threshold:
name: g8 still threshold
Do you have a LD2410B or LD2410C? If so, they have bluetooth so you can try connecting to them via the HLK Radar Tool app from a phone to see if they are powering up and working.
Other things to check:
the LD2410 is powered using 5V and not 3.3V
the TX pin from the ESP32 board is connected to the RX pin on the LD2410
the RX pin from the ESP32 board is connected to the TX pin on the LD2410
Thanks for the suggestions. I have the LD2410 (not B or C) so no bluetooth. Ecoardo got his working by turning off the bluetooth on the esp32-c6. I am pretty sure the connections are correct. Right now I am trying to get it working using a RaspberryPi Zero W that I already have.
I also by mistake got the wifi6 ESP32 C6 board, thanks to this post and the code from Edoardo, I now have a working LD2410 Presence sensor in my Home Assistant
Hello all, I’m running an esp32 c6 over thread for 2 servo motors… based on your experience, do you think it is still able to control 2 more devices LD2410?
